Question about Brother MFC 490cw Color Inkjet Multi-Function Printer
Connection i was just give this printer. i have no manual. how do i connect it to my computer?
  • 44 Answers
Can you provide me with model number of that printer you are trying to connect. model number should be either on the front or on a label in the back.
I will precisely explain once model number is in hand.
Posted on May 29, 2010
I need manual.
What question has the best chance to get a correct answer?
I need a manual
or
For my Epson ink jet printer Stylus Photo R320 I need a user manual. The printer is connected to a Windows computer running Windows 7.
Please when you want a manual give some details, like what device, what brand, and model. And if it has a operations system give that too. For a car is the year of build important.
Mar 30, 2015 | Televison & Video
Network Setup for Pixma MP970
it indeed is a bit of a complex problem as you may have a firewall program and it may be blocking the connection also.
Best to try following the manual, or we could do a remote support session tomorrow and figure it out.
the network setup guide is available in the downloads section of this webpage
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=15481
Aug 05, 2008 | Canon Pixma MP500 All-In-One InkJet...
How i solve the blank print on a3 paper on autocad
It seems you are using a print server to connect the printer 1280 to your LAN. Uninstall the printer software and printer server driver. Connect the print server to the network and first re-install the print server driver. Then connect the printer to the print server and install the printer software. Refer user manual for assistance. Bot the print server and printer software should be compatible with your operating system.
Jan 07, 2015 | HP DeskJet 1280 InkJet Printer
Ricoh 2022 giving error code 392 what should I do
If you are happy with my response please give me 4-thumbs up. Thank-you.
Enclosed is a link to the user manuals.
Last set has error codes.
Message 3xx is interface problem. That is the communication from your printer to your computer. If this message exists and does not go away. You nned to check the connections to the computer hardware.
Good luck.
http://www.ricoh-usa.com/downloads/local/manuals/multifunction_bw/aficio2022-27.pdf
Aug 04, 2011 | Ricoh Aficio 2022 All-In-One Laser Printer
MY Officejet HP j3680 will not scan
Thank you for posting to Fixya.com and it is my pleasure to guide you.
Are you trying to start scan on the Printer control panel or from the HP Solution Center on the computer?
Is the paper or document loaded straight in the loader? Besure the paper is pressed firm, not crumbled, against the bottom.
Does the HP Solution Center on the computer fail to start? If it does, restart the software and or the pc and then trying again.
If pressing the printer control panel does nothing, does it give an error message? The manual has Solve printing problems page 116 Maintain and troubleshoot
Are the connections solid from the printer to the pc? USB connection, One computer connected with a USB cable to the rear USB 2.0 high-speed port on the device. Pull out the cable then reinsert it, pressing firmly on the cable on both the printer and pc.
Unplug the electrical cable and then plug it back in to recyle the printer to like new setup.
I have also located manuals for your reference. Click or copy paste the links and save to you computer.
User Guide 9.45M http://h10032.www1.hp.com/ctg/Manual/c01181836.pdf
Setup Guide 826.99k http://h10032.www1.hp.com/ctg/Manual/c01181771.pdf
Good luck and please post back that you are successful and give thumbs up if my solution has worked for you. If I can be more helpful just reply.
Jun 21, 2011 | HP J3680 Officejet All In One Printer
I have a citizen 3550 printer how can i hook it up to my computer to print out misc. things instead of using you conventional printer?
To help you in the furture I have found the manual for reference. Click the link or copy paste it to download it. http://www.posguys.com/download/iDP3550UME_09E.pdf
From the manual for the Interface Cables, the manual has pictures.
4.2 Connecting the Interface Cable
1. Turn off the power. (Mating side included)
2. Check the top and bottom of the cable terminals, and connect to the interface connector.
3. Secure the cable terminals.
Serial interface: Tighten screws to secure.
Parallel interface : Turn clamps to secure.
4. Connect the interface cable to the computer.
4.3 Connecting the Drawer Kick-Out Connector
2. Check the top and bottom of the drawer kick-out cable connector and connect it to the drawer kick-out connector located at the lower section of the printer.
3. Screw the grounding cable of the drawer to the grounding terminal located at the lower section of the printer.
CAUTION: • Connect only the prescribed drawer (Solenoid) to the drawer kick -out connector.
Jun 21, 2011 | Citizen iDP-3550 Matrix Printer
How to network two computers and one printer trough a netgear FS105 switch?
Connect your two computers to netgear swtich with Ethenret lan cable into LAN port.
Then set ip address in both computer in network adapter property same subnet mask and gateway ip is different .
Means if you give ip 192.168.1.10 to 1 computer you can give ip 192.168.1.11 to another computer.
Then both computer are in network.
Then if your printer is network printer then you can connect your printer with lan cable to switch then set ip ion printer same way.
But if you haven;t network printer then you can connect printer into 1 computer then share your printer in contol panel->printer and faxes if you use windows then right click on printer icn then click on share so you can use it in network.
Let me know if you need further assistance.
Thanks for using FixYa.
Apr 13, 2010 | NetGear FS105 5x10/100 Mbps Networking...
No connection There is no computer connection.
Hello !
Give this a try;
Go to Printers and Faxes and delete your printer icon.
Disconnect the USB cable.
Restart your computer.
Reconnect the USB to your computer.
Your computer should see your printer. If it does not, move the USB cable to another port on your computer. It's also possible that your USB cable is faulty - replace the cable.
Install the printer driver.
Hope that helps.
Oct 15, 2009 | HP Office Equipment & Supplies
How do i get my hp deskjet f300 back on line
12/5/2011
Simply turn your computer off.
Then pull out printer cable connected to your computer/laptop.
Then turn your printer off.
Turn your computer back on.
Then connect printer cable to your computer/laptop.
Turn your printer on.
Check your printer device - should say "Ready."
Works like a charm! \ (^ ^) /
Jul 09, 2009 | HP DeskJet F380 All-In-One Printer
Hello
give mail id i will send the installation manual with diagrams ok
Mar 15, 2008 | Computers & Internet
Brother MFC 490cw Color Inkjet Multi-Function Printer Logo
79 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
