Question about Proscan PS52800 52" Rear Projection Television
T.v. woun't turn on it only makes a chirping sound when plugged i
T.v. was on made a popping sound then went off . now only when plugged back in makes a chirping sound near the power intake.tried unplugging and replugging and still the same results. even after using a alternate circuit.
    Brigadier General:
  • 4,090 Answers
Please refrain from turning this set on!
The popping is caused by exploding capacitors from high voltage fault. Chirping is from some other parts that are now receiving too much voltage and are complaining. The next step is FIRE. This set will require major surgery. It is not a DIY. Cost in vicinity of $3-400 Unless you have extended warranty. If you recently experienced a storm then try claiming fusion on your household insurance. get repairs to state FUSION.. at least part of it will be paid for you.
Please rate my help++++Thanks for using FIXYA
Posted on May 29, 2010
Car Alarm not chirping when turning on/off
Check the battery
They only last 3 to 4 years in some cases
(cars battery)
That will make the chirp if the module voltage is low
Next would be to have the modules checked for codes
& or diagnosed to find a problem
Nov 25, 2014 | Cars & Trucks
YAESU FT 8800 WILL POWER UP AFTER USING CHIRP PROGRAMING
it sounds like you loaded corrupt data into the memory registers or god forbid, let the magic smoke out of the CPU, and we all know with out the magic smoke it wont work anymore. disconnect the programming cable plug the mic back in and pull out the owners manual and look up how to do a factory reset, and perform one EXACTLY as instructed. if this doesn't fix the issue the radio is going to need service. You don't mention if you used a factory cable or after market programming cable. Ive never used Chirp software, so I cant comment on it, in fact, Ive never heard of it before and I run Yaesu equipment in my mobiles and for my handhelds.
Sep 28, 2014 | Yaesu FT-8800R VHF/UHF Dual Band Mobile...
Why is my 2001 Yukon making a chirping noise
I would check the freon level, because that would be the cheapest fix. If it's not the freon, it could be the AC compressor. If the compressor is locked up, it could make a screeching noise. As far as your brakes, I'd use some brake cleaner. Most likely (unless you've driven it tens of thousands of miles already) they are just dirty. Dust collects quickly on brakes. Hope this helps!
Jun 04, 2014 | 2001 GMC Yukon XL
Turn on TV no sound or picture just chirps
Get the chirping TV repair kit from www.TvRepairKits.com to fix this problem
Apr 07, 2009 | Philips Magnavox 51MP392H Rear Projection...
No picture, no sound, just chirping noise coming from back
NO - - signal did nothing to the set... Sounds like a shorted HOT (horizontal output transistor) and the feedback your hearing (chirp) is on the horz. transformer as it tries repeatedly to startup... Don't allow it to do that for too long...
Bill
Mar 30, 2008 | Philips 60PP9352 60" Rear Projection...
When tv turned screen is blank and chirping sound comes from back
A chirping sound usually means that one of the secondary supplies has shorted, most likely the horizontal output transistor. The power supply "chirps", which is the sound it makes when it protects itself from drawing too much current. The set should be serviced by someone with experience in Philips projection TV'.
Jun 21, 2007 | Philips 43PP9202 43" Rear Projection...
RCA F27667 No Picture / Chirping sound
I will bet you 10 to 1 that the flyback transformer and the horizontal output transistor is bad. an no at this point the set is not worth fixing.
Sep 28, 2006 | RCA F27667 27" TV
Proscan PS52800 52" Rear Projection Television Logo
180 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
