Question about Yamaha DV-C6660 Multi-disc DVD Player
Tray wont open yamaha dv-c6760 - Yamaha DV-C6660 Multi-disc DVD Player
3 Suggested Answers
megatronix
  • 57 Answers
SOURCE: BLOCKED MESSAGE ON YAMAHA DV-S5450 DVD PLAYER
The DV-S5450 may use a belt-loading mechanism. The belt is typically black rubber band with a diameter of approximately 2 cm. It is commonly found in front-loading CDROMs for computers also. Often, as a result of age, usage, humidity, etc the belt snaps, rendering the loading impossible. The loading motor doesn't just pop the tray in or out. It also engages a clutch assembly that raises an inserted disk or lowers a disk to be ejected; this explains why you can't simply force out the tray. Clearly in your case all the electronic signals are there and the loading motor does turn.
Solution: switch off and unplug the unit and then open it up. Do a quick inspection to see if you can locate the broken rubber band. If you can, remove it and take it along with you to the nearest repair shop for exact replacement. If you are finicky around technical work, simply a competent person do it for you. Good luck.
Posted on Jan 18, 2008
crazyhcris82
  • 34 Answers
SOURCE: yamaha dv-c6760 we can only see the top half of our subtitles
Hello shell
I do not believe your problem is with the DVD player. It most likely is with your TV. What happens alot is the picture on a TV is set to a different aspect ratio(ie:4:3,16:9). and sometimes it stretches or zooms the picture, allowing part to be cut off the edge of the screen. This aspect ratio problem can have two causes now that I think of it. The TV or the DVD player. To determine and fix, follow these steps.
PART 1-determining problem-
1 Watch regular TV for awhile and get some infomercials(yes, you have to watch Billy Mayes) on the bottom and edges of the screen, are there words and 800 numbers cut off, if so, your problem is with the TV and skip now to part 2(not step 2)
2 If you can see the whole number and everything , determine if your TV auto adjusts or not. Switch to your DVD player and see if the screens seems to move(shrink or enlarge). If it does shrink or enlarge, your problem is with the DVD player and you can now proceed to part 2.
PART 2-solving problem-
1 By now, you have determined whether the problem is with your tv or dvd player. From this point on "it, it's will refer to whichever has the problem
2 Go into it's menu
3 search for "picture" "video" or "setup"
4 Search for "aspect ratio" or anything containing "4:3" "16:9" or the words "stretch" "zoom" or "widescreen"
5 Set to 4:3 (sometimes 4:3 has multiple options such as stretch, zoom, and normal, if so, select normal)
6 ***OPTIONAL*** If you want widescreen, select 16:9(again if multiple choices, choose normal)
7 Insert or select a DVD and test your subtitles
If this does not work, please post a comment and I will help you further.
Hope this helps and please don't forget to rate
-Chris
Posted on May 04, 2009
My DVD tray on my Yamaha DV C6480 (it holds 5 DVDs) got stuck in the half open half closed position. It may have come off the track. I opened the case and reinstalled the DVD Tray. Now the tray...
This happens to us all the time. Here is the note I keep on how to fix it quickly:
When tray gets messed up, the drive wheel (with pegs that interlock with pegs on the tray) needs to be such that the tray slides in and out freely. Push tray all the way in. Turn on.
Hope that gives a hint.
Nov 04, 2010 | Yamaha DV-C6480 Multi-disc DVD Player
The dvd is stuck mid way not opening or closing
Try unpluging unit, then plug back in and press open/eject.Also look for a tiny hole on front door used to insert paperclip end, push in this will open tray.
Sep 04, 2009 | Yamaha DV-C6280 DVD Player
Jammed tray
try checking the tray for something that jams the tray.
May 27, 2009 | Yamaha DV-C6660 Multi-disc DVD Player
Yamaha dv-c6760 we can only see the top half of our subtitles
Hello shell
2 Go into it's menu
-Chris
May 03, 2009 | Yamaha DV-C6770 Multi-disc DVD Player
Yamaha S661 Player wont play multi region
This one is for S530, S540, S550, S557, S560, S600, S657. It's worth a try. Tell me if it works.
  1. Open the disc tray
  2. Press 9, 9, 9, 9, 0
  3. Press ENTER
  4. Close the disc tray
Apr 13, 2009 | Yamaha DVD-S661 HDMI DVD Player
DV-S555 wont always open
I sounds as if the guide tracks on each side are sticking. Be vary careful and put a little bit of tuner cleaner and lub on the tracks and this will usually fix the problem. Do not spray it into the tray for it may mess up your lens. Hope this helps.
Jan 07, 2009 | Onkyo DV-S555
We have a yamaha dvd player, model number dv-s5450 and it won't play our dvds. Sometimes it works but sometimes it won't even read them, tried cleaning lasers with laser cleaner and that didn't work any...
I had a similar problem...the machine, which had been great up until then, started to be very fussy when loading a disc; using a lens cleaner did not help at all.
I opened the disc tray and used a can of "air duster" with the straw attachment blowing in lots of air into every little nook and cranny that I could reach, especially in and around the actual lens area. The liquified gas under pressure must have been too cold as, at first, there was no improvement whatsoever when I tried playing a disc. However, the next day the player was working perfectly again.
It is worth a try.
Nov 19, 2008 | Yamaha DV-S5450 DVD Player
Jan 18, 2008 | Yamaha DV-S5450 DVD Player
Pioneer muti-disk dv-c503 dvd/cd player carousel wont saty open
When i put a cd into the tray the door will close. It will say its loading but then the cd tray will reopen again not allowing the cd to play.
Nov 26, 2007 | Pioneer DV-C503 Multi-disc DVD Player
Yamaha DV-C6660 Multi-disc DVD Player Logo
88 people viewed this question
Top Yamaha Televison & Video Experts
Larry Stiles
Larry Stiles
Electro Med Services...
Are you a Yamaha Televison and Video Expert? Answer questions, earn points and help others
