I tried to install myOne Touch Software but it would not install. There did not appear any on-screen instructions. I recently about three months ago bought a new lap top. It is the windows/vista model. Does the fact that I now have vista make it impossible to install the cd I have? I would appreciate your help.
    Genius:
  • 3,422 Answers
HI,
Have you installed this software before?If yes then please uninstall the software first and the install the software.If this is the first time you are installing it then it is possible that the software is not compatible o vista.It only work on xp.So to fix this you will have to get vista supported version.
I hope i am clear.
Goodluck,
Please don't forget to rate the solution as fixya.
Posted on Apr 08, 2008
  • 3,037 Answers
Can you give tell me the exact version of the one touch software please
Here is a vista update for certain versions
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=ot3-emc-vista&vgnextoid=b6623428ab622110VgnVCM100000f5ee0a0aRCRD
Please let me know about the version so I can further help you with your problem
  • 790 Answers
Hello ,
Guess the software is not vista compatible ...
    Genius:
  • 1,226 Answers
Hello
There is possibility that the CD rom is Not function properly. or the cd installer is not readable. however you can check the DVD/CD rom by inserting othe disc that is clean and new. please see the documentation of your Myone touch if it is compatible in VISta.
melnavz
SOURCE:
Why the one touch evolve screen comes on but will not power up
corrupted software. You have to get your software installed but first you should try three finger hard reset which might fix the problem.
good luck
May 11, 2014 | Alcatel Cell Phones
My ipod touch [4th generation] screen is stuck on the usb cord pointing toward the itunes logo
The solution is: 1. Turn of your iPod. 2. While holding down the 'Home' button, connect to iTunes WARNING: Doing this will return your iPod back to original 'out of the box' settings and you will lose everything. On the bright side, you get a 'fresh' start and it will auto update to the most recent software version.
ipod touch 4 gen
Aug 19, 2012 | Apple iPod touch 4th Generation MP3 Player
Touch screen not responding
Yeah, I recently bought a nokia n97, and already it is freezing. I lock the keypad, and then unlock to try and write a text, nothing. so i lock again and unlock nothing... I do this three or so times before it works:(. My phone was locked when somebody tried to call me, and as the screen was frozen, I could not answer....
HELP ME PLEASE.... I only got the phone about 2 months ago... This happens around 5 times a day.... There is a chip in the screen, could this be the problem? thanks
Dec 05, 2009 | Nokia N97 Cell Phone
Black squiggle lines appearing on screen
what happens if you connect the remote to the computer without any batteries are you having the same problem if so try a firmware upgrade if you still have the same issue it's certainly defective contact Logitech to find out how to get it replaced
Jun 08, 2009 | Logitech Harmony One Advanced Universal...
Touch screen not working....
Maybe the touch screen is inoperative with your uncorrect use. If u have tried to fetch out the battery and switch on.
Mar 07, 2009 | Handmark Software MobileLists (950142) for...
My touch screen has froze up & know matter what i do i can't the proble
Assuming that you cannot switch it off and on again, try removing the battery for a couple of minutes before re installing. Failing that a cold reboot my work ..... with the unit switch off press and hold the bottom right corner of the touch screen and the press the power button. The Zumo splash screen should appear....continue to hold the botton right corner until the reset default screen instrution appear and follow them. This has work in the passed.
If you have recently download a latest software via the Garmin web updater this can sometimes cause conflicts and you may need to re-install a prervious version. from the Garmin link attached.
http://www.gpsinformation.org/perry/zumo/
Sep 07, 2008 | Garmin zumo 550 GPS Receiver
Code 10
1. Download the updated firmware at www.memorexelectronics.com.
2. Unzip the file, then double click setup.exe in the Desktop folder to install the
software to your computer.
3. Connect the player to the computer using the supplied USB cable and the
installation screen will appear. (If the installation screen does not appear, unplug
the USB cable and turn off the unit. Connect to the computer again and press and
hold the Power On/Off/Stop button until the installation screen appears.)
4. Follow the on-screen instructions to install the driver.
5. When finished, click START and locate the newly installed software “Beam
Cadillac” and select “Firmware Download”.
Aug 13, 2008 | Memorex MMP3774 MP3 Player
I have a Palm TX. 3Years old. 6 Months ago had to calibrate Touchscreen every day. 2 months ago had to calibrate touch screen 2/3 times a day. Recently can't calibrate touch screen. Targets go into loop...
Same happened to my 3 month old TX. I just recharged it, and all was OK! Sounds strange at first, but in my hometown, it is very humid, so maybe it got some moist inside and that caused some variations in the power or battery or voltage... dunno, maybe you need some cleaning, or try to calibrate while plugged.
Hope to be useful!
Jul 03, 2008 | Palm TX Handheld
Open Questions:
BITDEFENDER TEch sUPPoRt pHoNe +{18OO.8O3..1O69 nUmber king Usa BITDEFENDER USA phone number is ranked #2 out of 2 because 7,728 BITDEFENDER USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:8O31069 is to reach t he BITDEFENDER USA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, BITDEFENDER USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. BITDEFENDER USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact BITDEFENDER USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling BITDEFENDER USA Calling BITDEFENDER USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from BITDEFENDER USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with BITDEFENDER USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare BITDEFENDER USA's phone numbers against each other. Contacting BITDEFENDER USA in General While I8OO8O31O69 is BITDEFENDER USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8O31O69 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach BITDEFENDER USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact BITDEFENDER USA.
Oct 22, 2019 | BitDefender Computers & Internet
Computers & Internet Logo
55 people viewed this question
Ekse
Marvin
Marvin
