Question about Garden
How do you tighten the drive belt on a riding mower
  • 66 Answers
No...it should be pre-set and at most tightened with the idler pulley that is spring loaded
Posted on May 30, 2010
5 Suggested Answers
  • 18 Answers
SOURCE: motion drive belt on craftsman riding mower
there is no adjustment..it is set by the spring that engages ur drive belt....
Posted on Sep 03, 2008
  • 42 Answers
SOURCE: how to replace drive belt
here is a diagram that will hopefully help you. let me know if it helps, or if you need further assistance. thanks.
convert?ilfn=d%3a%5cempartweb_52%5ccatalog%20data%5cemp_img%5chus%5cimages%5c33%5c28%5c0009.tif&ilsc=16&iliv=0&ilbr=0&ilif=g&ilre=8
Posted on Mar 15, 2009
woobie dog
  • 1273 Answers
SOURCE: How do I tighten the mower belt on a lt1000?
It is kept tight by a tensioning pully. If it is loose, replace it.
regards, --W/D--
Posted on Jul 21, 2009
daneinwv
  • 124 Answers
SOURCE: Hi, Just replaced the drive belt on a Husqvarna
My name is Dane and I am going to help you solve your problem.
I looked up your mower and I believe you should be using drive belt# 5321701-40. That is a 112" belt. Here is a link to the parts manual and a drawing of the belt routing. As long as that is the belt you have, and replaced it correctly it should be fine. You are correct, when you put the mower in gear, the pulley system will put more tension on it.
http://weborder.husqvarna.com/order_static/doc/HIPL/HIPL2003/HIPL2003_1063048-61.pdf
Well, I hope I've helped. If you found this information useful, please leave me some THUMBS UP if you think I'm deserving! :-) Thank you! Dane
Posted on Dec 05, 2010
Testimonial: "Thankyou Dane, You are a true proffessional!"
How to adjust tighten drive belt on Poulan riding mower with 18 hp b&s motor 42 deck
Probably needs a new belt.You can buy a belt dressing and spray the belt once in a while. Its a special sticky spray for belts that slip.
That will keep you going for a little while.
Apr 11, 2015 | Poulan Garden
How do I tighten drive belt on a LT2000 craftsman mower
you don't. you replace it or find out why it's loose. could have a broken tension spring.
Oct 08, 2014 | Garden
Drive belt comes out
There is an adjustment to tighten up the drive belt tensioner pulley. You should be able too see it after you remove the safety shield. Tighten adjustment nut to snug belt.
Apr 20, 2014 | Troy-Bilt 12AVB29Q711 TB260 21-Inch 160cc...
How do I tighten the blade drive belt on a Murray Sentinal Ride on Mower? 145 IC / 102. A drive belt diagram would be appreciated. Regards & thanks for any assistance, Rex
http://www.ereplacementparts.com/ model number Is something like 40566x50c if 2000 model, all your schematics are there. Yours henry
Oct 12, 2010 | Garden
Tighten belts on my Yard machine ride on lawn mower
There is rarely any adjustment to tighten the belts on a riding mower. The belts are tensioned by an idler pulley which is controlled by a idler pulley spring. Almost all riding mower belts must be accurate to the hundredth of an inch or no less than accurate to 1/8th inch. It is very rare for a belt to be in full inch increments. This is why automotive or general purpose belts will not work on a riding mower. I know it is tempting to try to get by with a $10 belt rather than spending $35 or more for the correct belt. Trust me, you will only waste your money trying to get by with the inferior belts. Riding mower belts and extra heavy duty and generally will not stretch at all. Generally they will have 5 or more strands of a Kevlar type material so that stretching is virtually non existent. If the belt will not tighten then it is most likely not the correct belt. If the belt is in fact the proper belt and still is too loose, then you should look for pulley wear or weak tension springs. Metal pulleys do wear and tension spring do loose tension.
Sep 12, 2009 | Mtd Garden
Broken belt
This is actually pretty simple:
Remove Pto guard on mower deck
Stand mower up on back stands
Pull the friction disc away from the drive disc
slip new belt in between the friction disc and drive disc pushing all the way through
release friction disc allowing to come back in contact with drive disc
loop belt around engine pulley
let mower back down
route belt around mower pulley
loosen guides on idler pulley
route belt through idler pulley
with engine off move pto lever to tighten mower belt
adjust guides on idler pulley allowing 1/8" from belt
tighten bolt on idler pulley
release pto tension
install mower pto guard
and you should be ready to mow
Aug 14, 2009 | Garden
Husqvarna yth2448 riding mower
you probably need to adjust the tension. if you look somwhere near the drive belt then you see a spring. tighten the spring to tighten the belt.
Jun 20, 2009 | Husqvarna Zero Turn Mower Z5426
Cant get mower to go in to drive or revers
check that belt is on the drive train pulleys. belt maybe stretched. look for adjuster to tighten slack out of belt tighten in small increments. hope this helps
Oct 24, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Motion drive belt on craftsman riding mower
Sep 02, 2008 | Garden
Garden Logo
93 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
