Television will not come on. The red light power button blinks three times and then nothing.
  • mjwells58 Apr 08, 2008
    I have a Panasonic PT-56WX33G HDTV 56" Projection. The power button blinks red three times and the TV does not come on.
    Genius:
  • 3,422 Answers
The only solution to fix this problem is to call a tech.
Few troubleshooting steps you can try:
1)Do a hard reset by unpluging all the cords for 4hrs and then plug it back.
2)The whacking test is to just bang or smack the set with your hand on the back, side, top, etc., to see if there are loose connections or cold solder joints inside that are acting up. If so, the banging should knock them back to normal and the set should restore. You might have to use some creative banging and some have had to put a book or magazine under one corner to torque the chassis enough to get it to work reliably.
Goodluck,
Please don't forget to rate the solution as fixya..
Posted on Apr 08, 2008
  • Priya darshan Apr 08, 2008
    .There are some of the fuses which has to be replaced but you may also have problem with convergence IC's.
  • 552 Answers
If your set is a sony, then hereis some info. I can only give general info because I do not know what you have.
  • 0 times, Diagnosis: Power does not turn on. Possible causes include: Power cord is not plugged in, Fuse is burned out (F6001) (G board). Symptoms of the problem: Power does not come on, No power is supplied to the unit, AC power supply is faulty.
  • 2 times, Diagnosis: B overcurrent (OCP). Possible causes: H. OUT (Q8024) is shorted. (D board), +B PWM (Q8035, 8038) is shorted. (D board) Symptoms of the problem: Power does not come on, Load on power line is shorted.
  • 3 times, Diagnosis: +B overvoltage (OVP). Possible causes: IC501 is faulty (G board), IC5002 is faulty (G board). Symptoms of the problem: TV has entered standby mode.
  • 4 times, Diagnosis: Vertical deflection stopped. Possible causes: +- 15V is not supplied. (D board), IC8003 is faulty. (A board) Symptoms of the problem: TV has entered standby state after horizontal raster, Vertical deflection pulse is stopped, Power line is shorted or power supply is stopped.
  • 5 times, Diagnosis: white balance failure (Not balanced) Possible causes: Video out (IC7101, 7201, 7301) is faulty (CR, CG, CB board), CRT drive (IC309) is faulty (A board), G2 is improperly adjusted. Symptoms of the problem: No raster is generated, CRT cathode current detection reference pulse output is small.
  • 6 times, Diagnosis: LOW B OCP/OVP (Overcurrent/over voltage). Possible causes: +5 line is overloaded. (A, B boards), +5 line is shorted. (A, B boards). Symptoms of the problem: No picture.
  • 7 times, Diagnosis: Horizontal deflection stopped. Possible cause: Q8035, 8038 is shorted. (D board)
  • 8 times, Diagnosis: high voltage error. Possible cause: T8005 is faulty. (D board)
  • 9 times, Diagnosis: Audio error. Possible causes: +- 19V line is shorted. (A, B boards), IC708 is faulty. (A board), PS701 or PS702 is opened. (A board). Symptoms of the problem: No sound
  • Hjalmer Lamminen
    Hjalmer Lamminen Apr 08, 2008
    The above post is from me.
  • 3,037 Answers
Not knowing your exact model, the following information may be a little off but will work all the same
I think you may have a few problems here. If you are comfortable with soldering, check the following parts first:
R7060 and R7066. These are .27 ohm resistors that feed the convergence ICs. They may be open. If they are open, the convergence ICs are probably bad and need to be replaced. These are STK390-110. These should be readily available on-line for about $20-$25 each.
Let me know if you need any further help and remember that working on a tv can be dangerous and can result in a large electrical shock.
  • 1 more comment
  • Benjamin Patri
    Benjamin Patri Apr 08, 2008
    The above is exactly the information you need, it is for panasonic, the red light is an indicator that there is a problem and blinking three times means that most likely the ICs need to be replaced and if that doesn't help, then it would be the board, but most likely the ICs. Are you experienced with opening a tv at all and know what to look for? I can get you pictures or further information on the matter if you wish. Thank you
    Please keep me updated
  • Benjamin Patri
    You do not need to call a tech to fix this problem, you just need to know how to handle electrical devices and how to solder new ICs onto the board. Let me know if you have any questions
  • Benjamin Patri
    Benjamin Patri Apr 17, 2008
    Were you able to fix this using my information?
Sony KV32FS120 Trinitron TV No picture or sound when power button on remote is turned off. Red light at front of TV blinks nine times per cycle.
Once your television blinks about 9 times then it means there is a problem somewhere most likely the lamp of the television. Another source of this problem is also a bad capacitor from either the main panel or the power panel.
If your remote turns off actually it is because there is nothing to operate on the television, so once your television starts the blinking light, the remote will not be able to operate the television, once you unplug the television and plug it back then press the power button, the remote will do the same.
Until the television is fixed is when the remote will work normally.
Take care and good luck
Dec 31, 2010 | Televison & Video
The tv doesn't turn on seems to power up then nothing the red light blinks 3 times
Hi gibbo, my name is John. Welcome to FixYa. the three blinks is a code that some Sony has to trouble-shoot certain issues with the unit. The three blinks indicate that you have a problem in the power supply circuit. Thanks for choosing FixYa. Happy Holidays........John
Dec 19, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
I have a sony 50". in the power button, a red
i have a sony 57". in the power button, a red blinking light blinks 11 times.
KDP57W5655
Nov 28, 2010 | Sony KP-51WS500 51" Rear Projection...
No picture or sound
Does anything start to work? Any of the three fans start to turn, Lamp ignite, etc., when you press the power button or does nothing happen before the Red LED starts blinking. How many times does the RED LED blink?
Jul 25, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
Sony kde37xs955 green light blinks 9 and red light blinks 6
hi..
It's in standby mode.
Do a reset and see what happens
While holding down the reset button on the remote
Press the power button on the tv
(The tv will turn itself off the back on)
Now release the reset button
It sounds like the lamp needs replaced....
thank u!!
rate me!!!
Apr 10, 2009 | Sony WEGA KDE-42XBR950 42 in. HDTV Plasma...
Blinking Red Lights
Sound like an error code 14 (Audio supply) is beeing blinked...
You probably would want a qualified technician to take a look at it.
Jan 16, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
I'm having a problem with my Panasonic PT-53wx52
If the front power light is blinking three times then your TV has a problem with the convergence. You can get the correct replacement parts and full step by step photo instructions from www.TvRepairKits.com
Oct 30, 2008 | Panasonic PT-53WX52 53" Rear Projection...
Tv wont turn
The blinking red light at the the front of the television is the "Diagnostic STANDBY/TIMER LED".
This little red light will blink 2, 4, or 5 times and then stay off for three-seconds. And blink again for 2, 4, or 5 times. This cycle repeats. The most common diagnostic code is the 4-blink code.
When the red LED blinks 4-times, it means one of two possible causes:
1) +13V is not supplied on the A-board. Or, 2) IC502 is faulty.
It is best to take this television set to a repair facility and ask that the +13V power supply be repaired.
The copper tracks and integrated circuit pads are very thin and delicate on the KV-24FV12 circuit board, and will easily lift off of the circuit board, if the incorrect desoldering tool is used. Unless one has a good quality PACE vacuum desoldering unit, one should not attempt to repair the television.
Aug 17, 2008 | Sony KV-24FV12 24" TV
Blinking power button
Blinking power light is usually due to bad capacitors on the power supply. See the tip for RCA atc336 under my profile that can apply to your set as well.
Mar 23, 2008 | RCA D44LPW134 44" HDTV
Televison & Video Logo
134 people viewed this question
Top Televison & Video Experts
