Question about Bosch 24 in. SHU43 Built-in Dishwasher
I turn on my switch, power comes on. I press scrub the lights come on but when I close the door lights go off and the machine doresn't run?
    Brigadier General:
  • 3,513 Answers
Thanks for writing to Fixya.com.
This is a condition called "flood safe mode" which means that water has gotten into the base pan underneath of the dishwasher causing a float switch to activate and tell the board that there is water in the unit.
You will have to pull the entire dishwasher out and remove the left side panel. Turn the power off at the circuit breaker to the machine and use towels or rags to soak up the water in the base pan. You will see a little round Styrofoam float that looks like a hockey puck. Once the water is out then the float will sit down on the ground again and the error will be gone. Because you say it would work sometimes that's probably because some of the water would evaporate and it would start working, but because the issue kept coming back I would assume something is leaking. It isn't fun to find leaks on these units you just have to take the right and left side panels off and watch for leaks. But unfortunately that's the only thing you can do.
Thanks for contacting Fixya and please accept the solution if it has helped you.
Posted on Jun 02, 2010
Error code e01
do the following steps: God bless you
To start test program, press and hold both POWER SCRUB PLUS and RINSE & HOLD program buttons, then turn unit on by pressing ON/OFF button. When program buttons are released, lights above them will flash. To end test program, press ON/OFF button.To check program indicator lights (POWER SCRUB PLUS, REGULAR WASH and RINSE & HOLD), press and hold each program button. When REGULAR WASH program button is pressed, CLEAN light also comes on.
To start testing, press both POWER SCRUB PLUS and RINSE & HOLD buttons a second time. When testing has ended and a fault was detected, the following indicator lights will be lit:
POWER SCRUB PLUS = Heater fault
REGULAR WASH = Water filling fault (over or under filling)
RINSE & HOLD = NTC (temperature sensor) fault ? note circulation motor stops shortly after it started during an NTC fault
To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil, measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high limit or flow switch are faulty.
If water level switch (f1) has failed (opened), REGULAR WASH light will come on and unit will continually fill and drain where testing won't be completed. If flow switch (e5) has failed (opened), water won't heat (to 150?F) and water won?t stop circulating. If NTC probe (f2/f4) has failed (opened), RINSE & HOLD light will come on immediately and testing will end shortly after water has started circulating.
If more than one fault occurs, more than one light will be lit.
Jul 21, 2012 | Dishwashers
I have just bought a hotpoint aqaurius washing machine model no. WMF740. THe power to it is o.k. but when I press the power button the machine does not light up. Can you help
MOST WASHING MACHINES HAVE A SWITCH ON THE DOOR , WHEN THE DOOR IS CLOSED THE SWITCH ACTIVATES OR TURNS ON THE WASHER. THIS IS A SAFETY TYPE SWITCH TO PREVENT IT FROM RUNNING WITH THE DOOR OPEN. CHECK THIS SWITCH TO SEE IF IT IS LOSE OR NEEDS ADJUSTING. IF THIS DOES NOT FIX THE PROBLEM, THERE THEN MAY BE A SENSOR OR OTHER SWITCH THAT NEEDS REPLACING. THIS WILL REQUIRE AN APPLIANCE REPAIR MAN TO REPLACE THE SWITCH OR SENSOR. - - SORRY
Feb 20, 2011 | Hotpoint Washing Machines
Cleaning Light flashes 7 times then repeats 7 flashes again. Cant find model #.... About 6 years old.. Thank you
342f192.jpg techbuster
  • Rank: Guru dishwashers_small.png
  • Rating: 92%, 2877 Votes
  1. Crack open door
  2. Within 3 seconds push Hi-Temp Scrub, Heat Dry, Hi-Temp Scrub, Heat Dry
  3. Close and latch door
  4. Press Cance
Try the above steps and also check the video in link given below to know detailed explantion on what the light means
http://www.youtube.com/watch?v=Hv7xOaucH7I
Jan 19, 2011 | KitchenAid 24 in. KUDI01IL - Multiple...
We can't get it to cycle.... the green light next to 'clean' is flashing on the panel - can't get it to stop flashing and run??
Found it; High temp scrub--Energy saver dry---High temp scrub---Energy saver dry--press start, close door ,wait for it to reset,open door press cancel and you are ready to go.
Jul 23, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
I have a Juki MO-655. I just threaded the machine, plugged it in and when I turn it on the light comes on but the motor doesn't start when I press the foot control. I have all the doors on the machine...
I also have the Juki M)-655. Look at the power button; it should have 3 positions. First position turns the power switch Off, second position turns the power switch on and it will sew, third position turns on both the power switch and the sewing light. Several times I have thought I turned on the power switch to sew only to realize it was not in the second position. Hope this helps.
Jun 14, 2010 | Juki MO-655 Mechanical Sewing Machine
My dishwasher clean light keeps flashing ... turned the braker off, open and closed the door several times, as well as the soap holder, moved the latch where the door closes ... not sure what else to do...
The reset sequence used was reported to be the following:
1) Crack the door open.
2) Within 3 seconds press the following sequence - Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry
3) Close and latch the door
4) Press the cancel button (the circle with the triangle in it)
Dec 27, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Year old Bosch SHU33A0UC won't start. Lights on
Light's on mean you have power.
Initiate the self test program by doing the following -
ON/OFF button.
RINSE & HOLD = NTC (temperature sensor) fault – note circulation motor stops shortly after it started
during an NTC fault
where testing won't be completed. If flow switch (e5) has failed (opened), water won't heat (to 150ºF) and water won’t stop
Let me know what you figure out. I can repair these boards most of the time.
Dec 18, 2009 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Own a Kenmore 665 dishwasher. The clean light is flashing (7 times) and the machine won't run. Have pulled the control panel and checked the door latch switches and they appear fine. No obvious burned...
It sensed a problem in the heater circuit. try this sequence to reset the code. If it comes back again you will have to determine a cause.
Sep 13, 2009 | Kenmore Dishwashers
Kitchenaid dw clean light still blinking/ machine won't run...
I tried the following sequence, as recommended on a similar blog and it worked!
Open door
Quickly press :
Hi Temp Scrub
Energy Saver Dri or Heat Dri
Hi Temp Scrub
Energy Saver Dri or Heat Dry
Close door
All lights should come on
then clear and revert to cycle.
Feb 28, 2007 | KitchenAid 24 in. KUDI01FLSS Stainless...
Bosch 24 in. SHU43 Built-in Dishwasher Logo
123 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
