Question about Dishwashers
Recently out GE qp5 has started doing a worthless job cleaning dishes.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. First of all please check the Water temperature by using a thermometer inside the dishwasher to measure the water temp. It should be as close to 125 degree F to 140 degree F as possible. Now try using the temperature boost feature if your dishwasher is equipped with this cycle feature and check if this will help your wash ability issues.
Now check the Powder soap by making sure that you store your soap in a dry environment and it is not stale and clumping together. Possibly try a different detergent like a liquid or gel. Also, make sure the dishes are loaded properly, or dishwasher is not overloaded.
To check the proper filling dishwasher will fill with water up to and around the heating element. If water is more below the heating element, you may have low water pressure or a problem with the fill valve. Try & listen if it sounds like it is spraying the water around with enough pressure.
For low water pressure, try to clean the screen at the entrance of the fill valve, sometimes the fill valve can fail and not allow the proper water into the dishwasher and may need to be replaced. And, check the spray arm and pump cover for splits or leaks. Also make sure that the water is draining and is not accumulated in the dishwasher, if it is in dishwasher then check for clogged drain hoses and drain pump.
Low water fills are a very common trouble maker with today's dishwasher. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on May 29, 2010
  • 3 more comments
  • ttoale May 29, 2010
    heat is good. Looks like it is the supply of detergent. The unit has a fillable container that dispenses detergent as you run the machine. I tried adding normal detergent and it ran much better. So my problem is the auto feed mechanism must be clogged. How would you clean that out?
  • Rylee Smith
    Rylee Smith May 29, 2010
    Please
    check that the upper spray arm is rotating. If so, then please check that there
    is no residue or foreign object stuck in the small hole pointing sideways at
    each end of the spray arm. Use a needle to remove the residue or stuck foreign
    object. Please also check that there is no debris stuck in the water
    supply line leading to the upper arm from the pump on the bottom. Unscrew all the
    arms and clean them and then replace them back into their place. Please do accept the solution if the issue is resolved or
    Thanks
    Rylee
    hmmmm,
    One of us not hearing the other.
    Looks like it is the supply of detergent from the dispenser. The unit has a fillable container that dispenses detergent as you run the machine. I tried adding normal detergent and it ran much better. So my problem is the auto feed mechanism must be clogged not the spray arm. How would you clean that out?
  • Rylee Smith
    Sorry about the previous reply, please check this link on how to clean the auto feed mechanism. Please do accept the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
  • ttoale May 30, 2010
    can you copy and paste it here? It is very difficult to read and I am not sure what section you are referring to in the doc and my printer is on the fritz so I can't print it off..
My dishwasher is leaving a white film powder on all my dishes. It appears the powder is in the dishwasher. How do I clean it out? How do I clean my Ge range profile rangetop?
The scum, film and white residueproblems have started since the reductionof phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
DishwasherResidue and Film on Dishes
heatman101
Mar 29, 2011 | GE Ovens
Soap (?) residue on dishes; also not getting them clean--food on
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Dishwasher Residue and Film on Dishes
heatman101
Jul 26, 2010 | GE Nautilus 24" Built-in Dishwasher
Dishes do not get clean- residue remains
heatman101
Dec 22, 2009 | GE GLD5900NWW / GLD5900NBB / GLD5900NCC...
GE PDW9700 - The dishes do not get cleaned
Same as above problem: I have had this dishwasher for less than 4 years and the dishes as of about 2 years ago stopped getting cleaned. I use the recommended dish liquid and rinse and lightly clean the dishes before I put them in.
What a piece of junk!! gs
Feb 26, 2009 | GE Profile PDW8400J Built-in Dishwasher
Not cleaning dishes
Our Bosch does a pretty good job of washing dishes. But we rinse most of the time. Not a hard rinse, but a rinse.
Are both spray bars rotating? You can test by seeing that the bars rotate easily by hand, and also by starting a cycle and opening the door real quick when you hear the spray hit the door.
Make sure the spray bar nozzles are all clear.
Has it ever done a good job of cleaning dishes?
DI you leave a heavy build-up of food on the dishes, and allow it to dry before washing?
Jan 26, 2009 | Bosch SHU5315UC Dishwasher
Almost new GE quiet speed 2 dishwasher not working properly
look at the spray arms see if they are stopped up look at the little holes in it hot water cleans dishes always make sure you get the water as hot as you can stand it before starting the washer as new washer dont use as much water as older ones so you can fill it with cold water before hot gets to the sink
Mar 31, 2008 | Dishwashers
Not cleaning properly. Not Draining properly?
Don't Buy GE :)
pump may me clogged does it drain, can you hear water spray. is water filling into unit on start up? I had to take pump of bottom of mine had piece of tooth pick jammed in impeller + GE just stinks anyway. I will never buy again
Jul 04, 2007 | GE 24 in. GLD5860LSS Stainless Still...
Dishwashers Logo
23 people viewed this question
Top Dishwashers Experts
