My 30" PowerSpec LCD TV won't turn on. I've tried the factory reset and unplugging it, but nothing worked. All I see is a little yellow light on the lower right-hand corner of the frame. Is there anything I can do besides buy a new TV?
I had the same problem it's the power it switches on is off and off is on I had to plug and unplug it from the back and shock the television until it remained off than you can turn the tv on and you'll get a picture.
Posted on Aug 16, 2010
I have no remote and I think the TV is on child lock, it is a technika tv LCD 40" the stand-by light comes on but you can not get the tv to start. Is there a way to "factory reset" this tv without using a...
not sure it this will work on ur tv but try to unplug the tv, and push the power button on the TV and hold for 30 or more seconds,, on some TV's this little trick resets back to Default.
Jan 26, 2015 | Televison & Video
I have a Sony Bravia LCD tv an it won't turn on at all the standby light is not even there I've tried turning on an off and leaving unplugged for an hour still nothing.? Help,
You either have a problem with your power supply board or main board. I would start with having the power supply fuse checked as well as the power supply board!
Jan 26, 2013 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
My JVC flat screen won't turn on, tried unplugging and resetting. Stand-by light is still on. And it's attached to a surge protector than to the wall. I've only had this for 1 year.
More than likely its bad capacitors on the Power supply very common problem with most models. You can get repair kits or replacement power boards from www.tvrepairworld.com
Dec 09, 2012 | JVC LT-42X579 42 in. LCD TV
Vc3207 v7 tv/combo dvd player, turn on tv, worked, changed channels, worked, when back to orginal channel, stayed on for a couple of minutes then the screen went black, the little red light came on. tried...
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
Sep 02, 2017 | Televison & Video
Steady yellow light
To reboot unplug the unit for 30 minutes. then plug back in. This may fix the problem, and try this link for troubleshooting PDF.http://homeappliance.manualsonline.com/manuals/mfg/bionaire/127176.html...
Apr 20, 2017 | Holmes Products BH3955-U Bionaire Utility...
19 inch slyvania tv/dvd combo turn on play button stays on and the the tv goes to red green yellow and blue screen and won't do anything else
I have been having just about the same problem with mine, i can watch the tv for about 20 min and then the dvd player comes on by itself then it goes to red, green, yellow, and black and white, i've tried resetting the dvd player to default but it hasn't helped mine.When i try to turn it off it automaticly comes back on so i have to unplug it.If i find a way to make mine work right i will send you a message to let you know so you can try it on yours. I've had mine just over a year and i don't have a warrenty anymore.
Aug 08, 2011 | Sylvania LD195SSX 19 in. LCD TV
We had a really bad storm yesterday with a lot of lightning. our power flickerd on and off a couple times but all of our electronics are plugged into surge protectors. everything in our house is working...
Few mins will not resetting tv and recovering power supply board from it protection modes that quick.Tries tv unplug,replug it back like about an hour later for tv resetting it back to the factory setting.The tv should get out it protections modes and might work again.If tv still have the same problems,than enough high currents got in the tv and kill ur tv power supply board.That the board where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish power supply board for the replacement.
Jun 30, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
No picture no sound, flashing power and OPC lights
At 8:30 AM CST call 800-237-4277 to be walked through an INIT. That is a factory reset that might correct this issue.
May 07, 2010 | Sharp LC-C5255U 52 in. LCD TV
I have a 30" Powerspec LCD TV and am having trouble adjusting the color. Built by Tatung? Help
Hello
I am am having a lot of trouble finding good setting for your TV or a similar model made by the same company. I got a few things to ask. Do you have any pixar dvd's or blu-ray's? some DVD's have a easy calibration guide right in the disk that works well enough to get a decent picture. There are even several games out there with them.
I did get a little info that may help. You can do a full factory reset by doing the following:
1. Turn the PowerSpec LCD TV/Monitor OFF with the Power button on the top of the unit.
2. Press and hold the Channel + button, then press and release the Power button.
3. Your PowerSpec LCD TV/Monitor will now be returned to the factory default settings.
This can help if you get the setting out of wack. Send me a message if you have any of the calibration items. There is also several disks you can pay for such as:
Digital Video Essentials
(blu-ray,dvd or even hddvd) is a good one and I have heard nothing but good things about it.
Monster calibration wizard is another.
There are several more but the only I can recommend Digital Video Essentials
Send me a message and let me know if you have any of these items.
Hope I helped
Mar 19, 2010 | Televison & Video
Televison & Video Logo
154 people viewed this question
Top Televison & Video Experts
Electro Med Services...
