Great website!! Fn key combinations on my wireless Acer keyboard model KG-0917, tablet PC disabled external numeric keypad numbers, tho numeric key pad NumLock light remains on and its operator keys work (+-/). Running Windows 7 (Windows NT). Suggestions? How do I enable numbers to work again on my numeric keypad? Thank you in advance! I accidently pressed the keyboard Fn+NumLk key in (panic) trying to locate key combination for Interrupt key, since my keyboard has no BREAK key. Fn+F12, Fn+F9, and Esc all failed, so MS Word crashed in testing a macro (probably because I left my computer on overnight again/has happened before). I found how to enable typing normal characters, instead of numbers, from the keyboard. Only solution I know so far is to shut down, unplug keypad, and after restart, plug in the numeric key pad again.
SOURCE: Acer wireless keyboard kg-0917 right side of
On that keyboard, the numpad is integrated into the alphabetical keys on the right side of the keyboard. You have to fit Fn + NumLk in order to turn the NumLock off and make it work normally again.
SOURCE: Keyboard beeps when any key is pressed
I found out what was wrong in my case. Someone had tampered with the accessibility options
So for anyone with keyboard problem check :
In Windows XP : control panel-> accessibility options -> keyboard : StickyKeys and Filterkeys checkboxes should be unchecked.
In Windows Vista : Ease of access -> Ease of access center -> keyboard : StickyKeys and Filterkeys checkboxes should be unchecked.
SOURCE: Fn combination keys for external monitor
Key Combination Functionality
Fn+F3 Reduce speaker volume
Fn+F4 Increase speaker volume
Fn+F5 Switches display: LCD, CRT, and LCD/CRT simultaneous
Fn+F6 Increase LCD brightness
Fn+F7 Decrease LCD brightness
Fn+F10 Toggles battery warning off and on
Fn+F11 Switches the LCD panel off and on
Fn+F12 Places the computer into Hibernate mode
SOURCE: where's F9 to F12?
Go to this link. http://support.gateway.com/s/desktop/2009/gateway/dx/dx4300/DX4820faq4.shtml
It involves pressing the FN key next to the spacebar and then pressing one of the arrow keys next to the F8 key at the top.
