Question about Craftsman 21 Hp 42" Deck, Ys 4500 Lawn Tractor
Belt replacement WHAT HERE AND YOU CAN GUESS WHY>
  • 61 Answers
You can go to on the internet to
searspartsdirect.com
have the model number of your mower handy, you will need it and you can d/l the belt diagram. ts4500 is not the model number. model number is 3 digits then a period, then more numbers. good luck
Posted on May 29, 2010
I Have error code E000007 - 001 on Canon C9060 pro
Fixing belt full displacement error (Displacement
direction is unknown.)
Full displacement of the fixing belt was detected, but the
displacement direction (front, rear) was unknown.
1. Forgot to clear the counter at the fixing belt
replacement -> clear the counter
2. Check physical relationship between the fixing belt
position sensor 1, 2 (PS71, 72) and the sensor flag
A. In case that both sensors are blocked from light
A-1. Faulty fixing belt unit -> replace the fixing belt
unit
A-2. Faulty fixing belt displacement control drive ->
replace the displacement control drive assembly
B. In case that both sensors are not blocked from light
B-1. The connector on the fixing belt position
sensor 1, 2 (PS71, 72) is physically removed,
or the cable is disconnected -> connect the
connector, or replace the harness
B-2. Faulty fixing belt position sensor 1, 2 ->
replace the sensor
B-3. Faulty fixing belt unit -> replace the fixing belt
unit
B-4. Faulty fixing feed driver PCB -> replace teh
B-5. Connection error of drawer connector (J8023)
-> clean or replace drawer connector
B-6. Short-circuit or open-circuit of harness
between fixing feed driver and DC controller
PCB -> replace harness
Jan 02, 2018 | Canon Office Equipment & Supplies
Wondering if possible bad drive pulley
Belt coming off or slipping?
Pulleys are made of steel, belts are made of a reinforced rubber compound. In a fight guess who wins? :>)
Check the belt, spray it with Drive Belt Conditioner. Make sure the tension is correct.
Apr 01, 2016 | Garden
How do you replace thermost n waterpump on 93 toyota camery
and? At least 3 engines.
what engine, we can not guess engine ever, nor country.
remove thermostat housing after coolant drained, all cars.
but waterpumps can be easy to hard.
some engines real hard, timing belt off, or worse.
ill pick one at random for you, dice rolled.
bam. lets go
usa car
usa alldata.com (so can you, so can Anyone with 15 bucks)
i click year, and camry.
i then click engine cooling.
it says:>>>>
2VZ-FE & 3VZ-FE Engines
  1. Drain the engine coolant.
  2. Disconnect the lower radiator hose at the water inlet.
  3. Disconnect the timing belt from the water pump pulley.
  4. Remove the bolt holding the inlet pipe to the alternator belt adjusting bar and then remove the inlet pipe and O-ring.
  5. Remove the water inlet and thermostat.
  6. Remove the seven bolts and then pry off the water pump.
I then click tbelt pages
2S-FE, 3S-FE & 5S-FE Engines
  1. Remove the timing belt covers as previously detailed.
  2. Raise the engine just enough to remove the weight from the engine mount on the right side.
  3. Remove the thru-bolt, two nuts, and right hand mounting insulator.
  4. Remove the retaining bolts and remove the right hand mounting bracket (from the side the alternator was removed from).
  5. Remove the timing belt and timing belt guide. If the timing belt is to be reused, draw a directional arrow on the timing belt in the direction of engine rotation (clockwise) and place matchmarks on the timing belt and crankshaft gear.
  6. Remove the bolt retaining the No. 1 idler pulley and tension spring.
  7. Remove the No. 2 idler pulley.
  8. Remove the crankshaft timing gear , if it can NOT be removed by hand, use two flat bladed tools to pry it off. Make sure to position shop rags to prevent damages to the components.
  9. Remove the nut retaining the oil pump pulley.
V30 Camry?
first know what engines there, before you buy parts. or read books.
or its all just a waste of time, for all.
here is the engine LINEUP, that i cant guess. ever (at least 6)
1.8 L I4 gasoline (4S-FE)
2.0 L I4 gasoline (3S-FE)
2.0 L I4 gasoline (3S-GE)
2.0 L V6 gasoline (1VZ-FE)
2.5 L V6 gasoline (4VZ-FE)
2.0 L I4 diesel turbo (2C-T)
Jan 31, 2015 | Toyota Cars & Trucks
Where is crank sensor on mitsubishi colt
Nick, this is mostly an educated guess, Mitsubishi made so many engines, dependent and model and geography. But, MOST are located on the front of the engine(where the belt is) under or near the water pump. Access is from beneath the car. The other location, although unlikely, would be on the bell housing next to the engine. Helpful Hint>>>Sometimes and in some models, low battery voltage or a weak starter can trigger a Crankshaft Position Sensor code. before replacing any parts, recharge or replaced battery.
Nov 29, 2014 | Mitsubishi Cars & Trucks
How to set the timing 98 Isuzu Amigo 2.2
i feel the pain of owning any ISUZU.
(suzuki, Daewoo,yugo, etc)
1994 the Amigo was dropped from sales in the USA>
so you are non USA> (a key factor) and on engine.
2.2-liter petrol (X22XE)
or the Europe sold
2.2-liter diesel (X22DTH)
perlexing how 2.2. means nothing.?
so out comes my wild dice and roll>>>>>>>> drum roll......
Bam
ILL GUESS GAS.
guess 2 is cam. timing. not diesel pump time or spark.
is this engine Interference type, (always check that first)
  • 2.2L Diesel Interference
  • 2.2L Gasoline Interference
them means never crank the motor, until 100% sure cam is timed right or you will bend over the valves ( that is why I say 1st) see>?
or worse , !
Gas &cam , change timing belt, (not stated, and is key)
ok, alldata.com we go
spark 2.2L USA> (no diesel here, )
These engines are equipped with a Distributorless Ignition System (DIS). No adjustment is possible.
The chapter on timing belt :.
there are 22 steps
ill presume you have all 22 and just need the marks photos.
and that you have a cam locking tool. ???? seen in step 12.
and step 15? the super secret, 4mm tension step for tooth? offset???
yes/no?
ok here is the drawing 1 or 2.
did i guess right>???
Jun 23, 2014 | Cars & Trucks
Free belt diagrams
free?
which engine, WE CANT GUESS THAT < EVER !
ever google, ?
ever look at PONTIAC ACTUAL>>
http://www.pontiac.com/owners/owner_resources/manuals.html
3.8L or 5.3L
yours fell off?
the sticker near radiator for belt direction missing.
the operators guide fails to show it so is FSM only coverage.
i guess GM belts last for ever. or owners never change them.
id bet if you GOOGLE your engine, it would show vast hits.
I bet.
Jun 14, 2014 | 2006 Pontiac Grand Prix
Pontiac sunfire GT 2.4 timing chain diagram
Ignition control module ? did you replace that ? Plus the PCM - engine computer triggers the ignition control module for spark control . 2004 Saturn Ion 2 2 Misfire Case Study P0300
don't worry about the P0300 , diagnose ignition module before replacing the timing belt ,an finding out that's not the problem . Test don't guess .
Oct 27, 2017 | Pontiac Sunfire Cars & Trucks
Golf GT TDI 140 2007 replaced cam belt in 2009/45k miles , now 92k miles and 4 years on ,can i get another year out of it ?
You probably can get another year out of it, but the consequences of it failing mean you probably need a new engine. I'd be safe and get it replaced. Better spend little money now rather than A LOT if you guess wrong. Hope this helps.
Jan 23, 2013 | Volkswagen Golf Cars & Trucks
Power steering not working tried adding power steering fluid didn't work.
The Pontiac power steering pump run off a shaft driven and not belt driven. This means that when the steering system is stressed instead of the belt slipping it puts a lot of stress on that shaft and could cause that to break. If nothing seems to effect the power steering I would have to guess that this is what happened and the power steering pump will have to be replaced.
Sep 21, 2010 | 2000 Pontiac Grand Am GT
Craftsman 21 Hp 42" Deck, Ys 4500 Lawn Tractor Logo
242 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
