Question about Goodman CLQ36AR49 Air Conditioner
No cold air blowing.
Both the blower and the compressor are working, however there is no cooling going on.
And it's getting hot in here!!!
  • Goodman Master
  • 8,220 Answers
Must be a leak somewhere. Better get a pro out there. Civilians ain't qualified to fix leaks.
Posted on May 29, 2010
Fan blower blows cold and hot air
most likely a stuck heater tap,but may involve vacum or elec controlled trap doors in HVAC system
Mar 15, 2015 | 1999 Dodge Dakota
MOTOR IS RUNNING BUT NOT GETTING COLD
you say motor do you mean the compressor, if so is it making any heat if so it says it is trying to work. common problem if so is a frost build up in frezer on back panel keeping cold air to circulate to refrig. from freezer. also check to see if freezer blower fan blowing air. back to compressor, it has large return line should be cold and a smaller high side line usually 1/4 inch and this should be hot if compressor is doing it's job.check cooling motor by compreesor also to much heat will shut it off.
Nov 08, 2010 | Refrigerators
Does not blow cold air
check your compressor first to see if it comes on, then the freon inlets and outlets. one side should be hot or warm and the other should be cool or cold. If not 1. check the fan or blower for the cooling fins to see if it is blowing. 2. call your manufacturer to see if a capacitor or switch could cause the apparent problem (either the cooling fan not blowing or the compressor not coming on) . this info is for a house a/c but should not be muich different
Jun 09, 2010 | LG GL6000ER Air Conditioner
How can I determine if my compressor is out on my
If you still get cold air out of the rear vents but the front only blows hot air you may have a bad temp door actuator in the dash, it may be stuck on hot and not able to move to cold air. However if you are low on freon with a truck that has front and rear ac then there will be a temp diff between the two. If it is hot air out the front like the heat is on then you have that actuator problem but if it is cool air about the same as the outside air temp then you may be low on freon.
May 23, 2010 | 2004 GMC Yukon
My 2002 Expedition air conditioner will sometimes blow hot air and others cold air
I would check the following possibilities:
1. Is compressor clutch working? - You need to do this when the ac is blowing hot air only - locate compressor drive pulley on engine - rubber belt wraps around it. Start engine and set to max ac. When the ac is blowing hot air, look at the center of the compressor drive pulley using a good flash light - watch it for a while, it should be spinning with the pulley - this means the compressor is engaged. If not, the compressor is not engaged. If your ac is blowing hot air, then the compressor should be engaged and running (trying to cool). If it is not engaged, then your compressor clutch is probably going out. Could be low voltage to clutch, but more likely the clutch is worn out and only working some of the time. Note: if working normally, the compressor clutch will engage and disengage in cycles- but the air should always be cold. If clutch is bad, compressor would need to be replaced (sold as one unit). This is tricky to diagnose and could take some time - you need to do it when ac is blowing hot air but set to max cooling.
2. Low on refrigerant or refrigerant has moisture in it? If your ac blows cold initially after being off for a while, then heats up, and continues to regularly cycle back and forth between hot and cool air, then the system may be low on refrigerant or the refrigerant may have moisture in it that is freezing and restricting refrigerant flow. An a/c shop can check refrigerant level and even replace refrigerant if moisture is suspected.
Could be other issues, but I would start with these.
Good luck
May 07, 2010 | 1999 Ford Expedition
I live in a very hot climate, Yuma AZ. In the
It may be getting low on freon sometimes they leak out
Sep 10, 2009 | 2005 Dodge Durango
Air conditioner not blowing cold air. We put coolant with gauge reading 25 lbs pressure. We think the compressor is coming on. The pipe coming out of the compressor is cool but, the air coming into the car...
Is the air actually blowing into the car?But it's just hot?It sounds like your blower motor is not turning to blow air.you have a fuse,check the switch that controls the blower,and the blower motor it self.
Jul 27, 2009 | Saturn L-Series Cars & Trucks
Uotside unit blowing cool air but hot on the inside
It sounds like you have a unit called a heat pump. When a heat pump unit is in cooling mode the outside unit blows hot air and the inside unit blows cold air. If the outside unit is blowing cold then the indoor unit is most likely blowing room temperature or warm air. It sounds like the thermostat could be controlling incorrectly or you could have a failed reversing valve which is the device that switches the unit from heating to cooling mode.
May 31, 2009 | Ruud UBHC Air Conditioner
2000 FORD ESCORT AIR CONDITIONER BLOWS BUT COOLS ON AND OFF
under the passenger side below the glove box check the relay switch.. sometimes they corrode which will keep it from working.
Jan 07, 2009 | 1998 Ford Escort
Air conditioner wont cool
the compressor has a capacitor that helps to start the compressor if the compressor does not reach the speed required to jump from the start coil to te continum work in about 10 sec the termic protector disconect the compressor for about 5 minutes but the blower or fan does work just blowing the air and that is not cold
Dec 31, 2007 | Heating & Cooling
Goodman CLQ36AR49 Air Conditioner Logo
93 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
