Question about Samsung SC-D103 Mini DV Digital Camcorder
"Protection!" on screen when trying to record on tape
- tape is already on Rec mode
- can record on memory stick
- cannot record on tape because of the "protection!" word on the screen
needs help fast!
i need to use the camera in a few weeks
Samsung is awful. i only used my camera a handful of times and then same problem with the protection mode. since its out of warranty i have to pay for the repair. they told me that it has never ever been a reported issue, so being that said i have to pay for repair on a faulty part. (I literally used this camera 10 times most since i bought it 4 years ago) they are horrid! not to mention how long it took me to get anywhere. they hung up on me 3 times, and I also kept getting disconnected! I will never own another samsung again!
Posted on Dec 15, 2010
I would like simple steps to transfer VHS to DVD on my Toshiba DVR620KY. I want to copy with the unit alone. Would appreciate your help. Thanks.
Hi ,
Please follow the instructions below to record from VHS to DVD. You may not be able to record from some pre-recorded VHS cassettes due to copyight protection embedded into the recording. You should stick some tape over the copy-protection tab on cassettes prior to recording if the tab has been removed. On some cassettes, there may be a slide switch which needs to be moved to the record/rec position. All pre-recorded cassettes will have the copy-protection tab removed.
1. Switch on the TV and DVD/VCR and select the correct input on the TV for the player.
2. Set the player for the recording direction, i.e. VCR to DVD . . .
- Press the SETUP key on the Toshiba remote to open the on-screen menu
- Use the UP/DOWN arrow keys to highlight GENERAL SETTING then press ENTER
- Use the UP/DOWN arrow keys to highlight RECORDING then press ENTER
- Use the UP/DOWN arrow keys to highlight DUBBING MODE then press ENTER
- Use the UP/DOWN arrow keys to highlight VCR > DVD then press ENTER
- Press the SETUP key again to close the on-screen menu
3. Press VCR to select VCR mode.
4. Insert the cassette you wish to record and fast-forward or rewind it to the position where you want to start recording from. Allow at least 5 seconds extra if not starting the recording from the beginning of a cassette.
5. Press PLAY then press PAUSE immediately.
6. Press DVD to select DVD mode
7. Insert a blank DVD
8. Press the REC MODE button to select the recording mode (XP / SP / LP, etc)
9. Press the DUBBING key to start the recording.
You can watch the VCR while it's recording. When you reach the point where you want the recording to end, press the STOP key. You do not need to repeat step 2 every time you record. The player will stay in VCR > DVD recording mode unless you change it.
Hopefully, you will now be able to record from VCR to DVD. If you need further assistance, please let me know.
Regards,
BElectric
Mar 26, 2011 | Toshiba D-VR4 DVD Recorder/VCR
I have not used my handycam for a few months, and now it does not record. Push rec button and nothing happens .The camera will take pics rewind,fast foreward and play but push record and nothing.
The camera wont go in record mode if the tape protection tab is over hole on rear of cass tape, maybe you ought to buy new tape and try again, very little goes wrong on those cameras my friend, there is nothing on market as good these days I can tell you.
Jun 15, 2010 | Sony Handycam DCR-TRV460 Digital Camcorder
When i put a tape in it ejects it..then a tape with a slash appears on the screen
you are prohibited from recording on thips tape. This is because the red tab on the side of the tape that faces you when you are inserting the tape inside the camera has been put in 'SAVE' position . to be able to record o the tape you need to use your fingernail to slide the red tab to the 'REC' position.
Ive extracted the following article for you from wilkepedia to help you understand this issue:
Tape and recording protection
250px-8mm_cassette_erase_tab.jpg magnify-clip.pngThe write-protect switch (right) prevents accidental erasure. .
To prevent the recording on the tape from being erased, there is a small write-protect tab that can be moved to one of two positions, labeled "REC" and "SAVE". Comparing the sliding tab to a door, the tape is in the "REC" position is when the "door" is open and the "SAVE" position when it is closed. (Not all tape cases have markings for this information!) The tape can only be recorded on (or recorded over) when this tab is in the "REC" position. This is an improved version of the VHS write-protect tab, which prevents erasure after it has been (permanently) broken off.
Dec 02, 2009 | Sony Handycam CCD-TRV318 Camcorder
Problem when Trying to record
If you are trying to record to a tape and the display shows "Protection", you must slide the protection tab at the top of the tape to the "Rec" position.
Jul 23, 2008 | Samsung SC-D103 Mini DV Digital Camcorder
Need an urgent solution regarding "Protection" problem (I have a program to record in next 2 hours) pls pls help !!!
have suddenly getting a "Protection" message in Camera mode. - The viewfinder is OK and i can see the view but a "Protection!" message is blinking in the middle of the screen and the record button is not working if i press
Apr 13, 2008 | Samsung VP-D103i Mini DV Digital Camcorder
Canon GL2 still shot while recording on tape
there no way you can record a still photo while recording at mini dv tape cause the a tape and memory card switch rec mode
Aug 04, 2007 | Canon GL2 Mini DV Digital Camcorder
Protection! Flashes on screen
This camera has a history of the flexible harness located on the cassette housing tearing when it rubs against the frame as the housing moves in and out. The harness tears and opens the circuit that detects the tapes record lockout tab, the camera is preventing you from recording on the tape in error. This repair requires replacemnent of the cassette housing, not for the faint of heart. I wish you luck. Joe Weibel customelectronics.org
Feb 04, 2007 | Samsung SC-D103 Mini DV Digital Camcorder
DV Cassettes vs Memory Stick
Well, I went to The Sony site and what I found out was that currently this camera is only ceritfied for a 512mb stick. It does say what the qualiy is the memory stick is E-mail mode with a resultion of 160x112 pixels. The TAPE mode is DV quality or 740X480 pixels. Try recording both ways and see what looks better when you play it back on you TV or PC then decide.
Sep 14, 2005 | Sony DCR-PC350E Mini DV Digital Camcorder
How do I use the memory stick?
Recording Still images To The Memory Stick M.REC mode (Memory RECORD mode) 1. Set the mode switch to MEMORY CARD. 2. Set the power switch to CAMERA. 3. Press the PHOTO button. The still image is recorded to the Memory Card. To View photos on the Memory Card M.PLAY mode (Memory PLAYBACK mode) 1. Set the mode switch to MEMORY CARD. 2. Set the power switch to PLAYER. The last recorded image appears. If there are no recorded images on the Memory Card, NO STORED PHOTO! or NO STORED MPEG4! will display on the screen. 3. Using the (FWD) and (REV) buttons, search for the desired still image. * To view the next image : press the (FWD) button. * To view the previous image : press the (REV) button. * Pressing (FWD) when you are on the last image will take you to the first image and pressing (REV) when you are on the first image will take you to the last image. * Keep pressing (FWD) or (REV) to search for an image quickly.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Samsung SC-D103 Mini DV Digital Camcorder Logo
128 people viewed this question
Top Samsung Video Cameras Experts
Tony
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
