Question about Frigidaire Microwave Ovens
Turn table stop turning at times - Frigidaire Microwave Ovens
  • Frigidaire Master
  • 9,098 Answers
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
In some brands, you have to cut the motor cover off with snips, then use a screw when reassembling it.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Posted on May 30, 2010
Microwave Inverter NN-ST651BB 1200W Works fine but the turn table still turn when I open the door.
Does the turn table ever stop? If not you need to either replace the oven or have it repaired, it is likely cheaper to just replace it.
Dec 06, 2016 | Microwave Ovens
Turn table will not turn
I'd check to see if the turntable motor has continuity. If it does, check to see if 120 volts is being supplied to it. If both are o.k., then the motor has probably bound-up in some way internally. There's also the possibility that it has mechanically become detached from the hub that turns the glass tray.
May 06, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
I have an panasonic inverter microwave the bulb went then the turn table stopped turning I have changed the bulb now the turn table turns all the time but the light still does not work any ideas?
It seems that the fault is relative of the program controller board or the processor subsection outputs. If there is display and you are able to adjust then the processor is working but if not this is confirmed. Also if the turntable runs all the time there is a continuous short in the output and the magnetron must also be checked to see if this is opwered or else it is not safe to work on-- please be extremely careful as a cross link within board can power the magnetron which can produce microwaves.
If so the contoller board is the suspect.
Sep 29, 2011 | Microwave Ovens
The turn table stopped turning and the unit stopped heating.
the turn table stopped and the unit stopped heating.What should I do?
May 30, 2011 | Goldstar MV-1501 Microwave Oven
Hi, I have a Sharp R-254 microwave and the turn table turns for approx 30 seconds. After 30 seconds it stops and makes a clunking noise, if you open the door and manually turn the glass plate 1/4 of a...
Either the coupler that is located in the center of the oven cavity that the turntable sits on is defective or the turn table motor is defective. . Either repair is rather simple (coupler being the easiest) with parts available online.
Nov 11, 2017 | Sharp R-254 Microwave Oven
Frigidaire microwave doesn't work
Don't have a fix for your problem, but my Frigidaire microhood just did the exact same thing--about the same age, started cooking some food and it worked for a few minutes and then just stopped--time kept going, light stayed on, but turn table stopped and fan noise cut out. I tried it a few more times and it seemed to fade in and out and then stopped trying.
Nov 30, 2009 | Microwave Ovens
Ultrex microwave turntable won't turn
turn table motor may be going bad.. it is almost impossible to diagnose untill it stops working completely.. when it stops working completely you can test for 120v down at the motor if you get 120v you need to replace the motor.
Jan 20, 2009 | Microwave Ovens
Turn Table wont turn
if you can check the turn table motor for resistance. 90 percent would be a broken motor which you could replace. just look for the motor at the bottom of the microwave and race the wire back to the pc board.
i hope i was able to help..
pls rate me
tnx,
drcool
Jul 19, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
I have a combi which I have had for some years model carousel1 and the turn table has become slow and at times stops I have purchased another sharp--delivered yesterday modelR-959M-but if the old model...
if you open it you will see a large belt that connects the table ,
it might be stretched or greasy. remove it and turn the table by hand . is it sticky or turns easy . gunk can be in the bearing surface.
Apr 25, 2008 | Microwave Ovens
Microwave Ovens Logo
44 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
