Question about Hitachi P50H401 50 in. Plasma HDTV
Problem with Hitachi P50H401 Plasma TV - Will not turn on. Blue light flashes 4 times ???? Plasma TV less than 2 years old will not turn on. The blue light continuously flashes 4 times
I have the same model, P50H401 and it developed the same problem two days ago. This set is 2 1/2 years old in service, being purchased in December 2007. The original manufacture date was October 2007.
The set was turned on and operating at the time and then promptly shut down by itself. The front blue LED power indicator began flashing four times in a loop or cycle.
The flashing LED sequence in this instance points to a problem with one of the following boards: PSU, X-Sus, Y-Sus or SDRs (there are two SDR boards, SDR-U and SDR-D, both are connected off of the Y-Sus board on the left hand side of the frame when rear facing). The set shuts down to prevent further damage to other boards or components.
I could power cycle the set but it would shut down after after a few seconds. Power LED would stay solid, I could hear the PS relays switching, and audio would output through the speakers. Then as the screen was just about to illuminate, the entire set would just shutdown. The blue LED would again go into the 4X flashing sequence.
I could not visually detect any signs of severe component damage on the main PS board. The two large electrolytic capacitors which have been mentioned as problematic in other threads seems fine. The where slightly raised on the top surface, but not blistered or completely blown open.
The only indication of component damage that I could detect visually was on one of the small surface mounted ICs on the SDR-U board.
Through reading other posts on this site, I learned that I was able to remove the suspect SDR-U board and then re-power the set. Doing this proved that the PS, X and Y Sus, and the SDR-D boards where o.k. The PS held, and the lower half of the screen illuminated. (I would only do this for as brief a period as required to determine if the the other boards would function and the screen would illuminate. Do not pro-long operation in this state so as to not cause further damage.)
It was somewhat difficult to locate the correct SDR-U board. My local service rep did not have one in stock, and the Canadian parts distributor was also out of stock. They estimated 10 - 14 business days to order one up from the U.S.A. (Hitachi closed their consumer electronics division in Canada back in 2009.)
By chance, I checked with another service rep in an adjacent town. He had a board for the P55. We did a visual comparison on the two boards and determined that it would be compatable.
The easy part was removing the defective SDR-U board and installing the replacement. The hard part was re-alinging the three ribbon tabs into the respective connectors on the SDR board. Be careful with these ribbons. The other end of each is fused to the plasma panel screen, so if you damage them, your screen is rendered useless.
I initially had the same problems as others have posted with having black or gray lines on the screen when the SDR-U was replaced. After gently adjusting the position of the ribbons as they are seated in the connectors, the lines disappeared. This was a slow and frustrating procedure, but it worked, Be patient.
Posted on Jul 03, 2010
  • bcr88 Nov 06, 2010
    I also have the same model, P50H401, and it developed the same problem. After reading your post I found that it was in fact the SDR-U Board that was damaged. After attempting to find a replacement part I learned that it was discontinued.
    I called Hitachi customer service and they referred me to ModusLink PTS in Bloomington, IN which is a company that repairs broken boards. I received the repaired part yesterday and put it back into the T.V. I did have to re-align the ribbon tabs just as you stated but after that the T.V. worked perfectly.
    Thank you for taking the time to post this as it was very helpful and has saved me a lot of money.
Hi friend can be the power source unit, check the manual according to the 4 lights mark these four cards: X-SUS, Y-SUS, SDR, PSU
Posted on May 30, 2010
Hitachi Ultravision tv model number: P50S602 When I turn it on the blue power button comes on and the sound comes on for about 2 seconds then the sound turns off and the blue light flashes three times...
Lights flashing is code talk .So call a TV repair guy and ask him good one will tell u what the light code means over phone cause he'll wanna sell u parts or get your business for service .
Jul 12, 2012 | Hitachi P50H401 50 in. Plasma HDTV
Blue light blinks three times then pause...blinks 3 times then pause etc etc.. no audion or picture, just black screen with the blue power light flashing like mentioned
My Hitachi 50" plasma has exactly same problem. I have called local TV service centre, and I was told min. charge is $500 plus $110 for pickup. It is out of the warranty now (almost 3 years old), I really don't know what to do.
Jan 15, 2011 | Hitachi P50H401 50 in. Plasma HDTV
very common issue for these sets! p50h401 and p50s601 are almost the same.
for more info on this set please check out http://www.hometheatershack.com/forums/hitachi/38229-hitachi-p50h401-led-flashes-3-times.html
if will tell you how to trouble shoot this tv. these tv's are known for two caps in the power supply to go bad and they need replaced then you have to test the sdr buffer boards if they are bad you need replacement boards or you can send them off to be repaired.( Repairing the buffer boards is a lot less then replacing them ) the link for the repair guy is on the page. this guy also sells the repair on ebay but if you contact him directly i beleave the price is lower. just tell him you were send over by home theater shack.
Sep 19, 2010 | Hitachi Ultravision P50S601 50 in. Plasma...
My hitachi P50H401 will not turn on. No sound no
check your sdr boards. you can test them with a multi meter. they are known for going bad. what happens is the two caps by the output go bad on the power supply and they make the sdr boards burn out. you can replace the two caps and save lots of money. then please check out this web page http://www.hometheatershack.com/forums/hitachi/38229-hitachi-p50h401-led-flashes-3-times.html
This web page has info about repairing these. The 4 flashing lights maybe the x sus or the y sus but it's still a good idea to check the sdr boards since its a common failer. I had one tv with a bad sdr board flash 3 time and another set it was flashing 4 times.
Nov 16, 2009 | Hitachi P50H401 50 in. Plasma HDTV
Broken plasma display panel
hi,i have same hitachi p50h401,just over a year old,mint condition never use stand but boards inside have some problems(blue light is flashing but tv not turning on).will sell it or buy yours.thx oliver.e-mail to oshvetz@yahoo.com
Aug 09, 2009 | Hitachi P50H401 50 in. Plasma HDTV
Hitachi Plasma TV model P50H401
I think you have problems with the digital main PWB.
If the power PWB failed, turn off and change the pilot ligth to red.
Aug 31, 2008 | Hitachi P50H401 50 in. Plasma HDTV
Hitachi 50" plasma no picture
how do i fix p50h401 blue light no picture and sound
Feb 07, 2008 | Hitachi P50H401 50 in. Plasma HDTV
Hitachi HD 1080 has blue power light on but no picture
Press the reset button...it's on the bottom to the right (underneath the TV). Same thing happened to me.
Hitachi P50H401 50 in. Plasma HDTV Logo
5,098 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
