Question about Sony Handycam DCR-HC14E Mini DV Digital Camcorder
When turning on to vcr or camera, camera beeps repeatly
Yellow arrow flashed on screen numbers c 31;23 flash aswell wont fast forward ,play or reverse
  • Sony Master
  • 3,866 Answers
Sounds like the camera ATE THE TAPE will not eject,fastforward, or rewind.. This will need to be repaired , worse case a belt slipped or something got misalligned inside, I would recommend a camera shop so you can save the tape otherwise digging into this yourself could stirr up more issues in the long run. Please do be considerate of facts here that we cannot see your unit and this error is because the tape got ATE or something got jammed.
Thanks please do leave some feedback and ratings for your free answer today.
Posted on May 29, 2010
Put in tape and vcr fast forwards
something maybe broken on the inside for it to say play but fast forward. the botton could be stuck as well. maybe open the vcr and clean it all up in side. that might help
May 11, 2012 | Panasonic Pv-9661 Omnivision 4-head Hi-fi...
Hi, I am seeking the region free code for a Samsung DVD-D530? Thanks!
I tried the above steps, but each time when restarting the DVD player, it said 'reset' and asked for the language to be selected again. Pressing the "Fast Forward Fast Rewind Fast Forward Up Down" sequence caused the player to lock up and require powering off at the wall.
I found on another web site that there are different initial sequences. Once I use the one for Region 2, it worked fine.
I found the instructions below on another web site, but it worked for me...
  • Make sure there is no disc in the player.
  • Turn on the player (you can use remote control or front panel, it doesn't matter)
  • Wait for "No Disc" message to appear on the TV screen.
  • Press the Repeat button on remote (plain, not A-B).
  • Press the correct sequence of buttons of remote according to the original region code of your player (it's on the sticker on the back panel of the player). FF = fast forward, FR = fast rewind.
    • Region 2 players: FF, FR, FF, UP, DOWN
    • Region 3 players: FF, PLAY, FR, UP, LEFT
    • Region 4 players: FR, PLAY, DOWN, DOWN, RIGHT
    • Region 5 players: FF, UP, DOWN, STOP, RIGHT
    • Region 6 players: LEFT, RIGHT, RIGHT, PLAY, LEFT
  • If you pressed the correct sequence, a small white number 0 will appear somewhere on the top right of the screen. The white number 0 of the same font and size as the "No Disc" message, so don't confuse with the red "not allowed" sign that would appear when you press a function that's not available.
  • Turn the player off and on again, then you can pop in a DVD of any region and watch immediately.
Apr 30, 2011 | Samsung Televison & Video
Flashes turn off and on in the LCD. beep sound
Hello!
Please consider the troubleshooting given below:
(a) Remove the Battery from the Camera then press and hold the power button for 30 seconds.
(b) Reinsert the Battery pack and turn ON the Camera. Please make sure that the Battery pack is fully charged.
(c) Next, try resetting the Camera to the original factory settings if the menu options are accessible on the Camera.
Perform the steps given below to reset the Camera to the original factory settings:
(i) Press the Menu button on the Camera to access the menu options.
(ii) Press the right arrow on the control button to select (Setup) setting, then press the right arrow again.
(iii) Press up/down/left/right arrow to select the Setup 1option.
(iv) Next, select the Initialize Option and select OK.
Performing the above mentioned steps will reset the Camera to the original factory settings.
If the issue persists even after performing the above mentioned steps then service will be required.
Aug 23, 2009 | Sony Cyber-shot DSC-W70 Digital Camera
How do you unlock the Samsung DVD - P191 from all regions?
The following solution was posted on Whirpool.
Turn on the unit with no disc in the unit. The No Disc message should be visible
Press the following keys in this sequence
Repeat (not the A-B Repeat, just the plain Repeat)
Fast rewind button (just below the Disc Menu button)
Play button
Down button
Down button
Right Button
The number 9 should now appear towards the left of the screen.
Open then close the disc draw
Turn off the unit and then on again. You should now be able to play DVDs from any region
Apr 18, 2009 | Televison & Video
Sony GV-D1000 Powers on, will play memory stik, but not tape
C:31:23 error code means problem is in Supply Reel section.
If you are tech person you might got the point.
Unit has mechanical problem in supply reel area and reel pulse is not being generated as supply reel table may be stuck due to back tension.
Let me know if you need further help.
Feb 11, 2009 | Sony GV-D1000 Mini DV VCR
VCR sv 670 wont play or fast forward tapes.
Open the bottom Cover, and check the belts.
Nov 29, 2008 | Samsung SV3000W VHS VCR
Sony digiital handycam dcr-trv250
You are probably looking at around $100 repair to get the mech sub chassis, with the reel sensors replaced. Please, if you approve of my information, please be sure to rate it. Thanks!
Oct 29, 2008 | Sony Handycam DCR-TRV250E Digital...
Vcr won't play
having the same problem I would love to know myself!!!! PLEASE HELP
Mar 20, 2008 | RCA VR349 VHS VCR
Cannot record
it is a reel sensor problem...try to adjust the contact of the sensor at the main board sometimes it is a poor connection or poor solder...
Aug 26, 2007 | Sony Handycam DCR-PC105 Mini DV Digital...
Sony Handycam DCR-HC14E Mini DV Digital Camcorder Logo
284 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
