We are getting code 37 . we have a top load machine Intuitive model - what does that mean?
  • luisa_sgro May 29, 2010
    is your machine draining all the water from the bowl? where are you draining the water into? this code 37 means that the machine has not drained in the allotted time allowed for the drain cycle.please reply for further help.
  • 159 Answers
37 is slow or no pump out.check that water is flowing out at a good stream.if not then pump is either jambed with debris or blocked.the water needs to be bucketed out as much as possible then tilt machine back against the wall as far as you can so any eccess water is to the back of the tub.With machine unplugged from wall lay down on the floor & unplug wires from pump.release plastic locking tab & twist out pump anti clockwise,remove ant debris.
Posted on May 29, 2010
Hello I have an 8 yo 'Intuitive' with an error message No. 37. Any suggestions as to whats wrong? thanks Pat
Hi just read your posting.Error code 37 means PUMP BLOCK ERROR.Does your machine drain the water out?Please reply with additional information and I am sure I can help you out.Looking forward to your reply.
May 16, 2011 | Fisher and Paykel Washing Machines
We have a fisher and paykel intuitive eco, which says code 37,
Hi just read your posting.Now ERROR CODE 37 means PUMP BLOCK ERROR.Is your machine draining any of the water out of it?Please reply with additional information on the question and I am sure I can help you rectify this fault.Looking forward to your reply.
Aug 17, 2010 | Fisher and Paykel Washing Machines
Error code 51? F & F intuitive washer
Hi just read your posting.Error code 51 means you have a Recirculation Fault.This means while the machine is filling or washing it loses water.Error code 37 means you have Pump Block error which means the machine is not draining.Please look under the machine to the front right and you should see a pump with a red or black fan attached.Can you confirm this please? I think there is a problem with your diverter valve and the information on your type of pump will help me rectify this problem for you.Please reply with additional information on the type of pump in your machine.Looking forward to your reply.
Jul 01, 2010 | Fisher and Paykel Washing Machines
Top loading intuitive washer says fault code 37
This machine calls this error number for most faults.
So first let us know what stage it stops at.
The most common fault is blockage in the pump.
Remove the power plug, disconnect the 2 water hoses and tilt the machine onto its front.
It is simple to remove and replace. Disconnect the 2 sockets from the pump The pump is held in position by a latch on the left hand side. Depress the latch and twist the pump anti clockwise. Clean out , add a smear of vaseline to the rubber ring.
Reassemble in reverse
Mar 02, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Fault Code 37 Intuitive Washer -
you have a clogged diverter valve, its blue and looks like a Y, it will need to be replaced, if you want call 1-888-936-7872 they can order the part and walk you thru replacing it
Jul 04, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
What is code 37 intuitive eco
replaced the water pump. It was failing intermitantly
May 05, 2009 | Fisher and Paykel Washing Machines
Screen has code 37 on it
Hi, welcome!
Code 37 is a "pump blocked error" code. Typically this code is triggered when the machine does not sense a change in the water level when called for. Check for debris caught in the pump, either in the impeller for moving water or in some cases, the external cooling fan impeller (exposed underneath the machine) gets snagged with a piece of fabric softener sheet (such as "bounce") and this will stall the pump and trigger a code 37.
I hope you find this info useful and thanks for using Fixya.
Jan 26, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher & Paykel intuitive code 37
My machine is actually an IW811. But what happened was I checked motor see if it was spinning & confirm it was. But realised instead of pumping water out, it was going back into bowl, went straight to diverter valve, found control solenoid was burnt, was very hot to touch, even though hasn't been operating, only with main power point on. Suspect motor control board faulty as well. Replaced both parts & was fine after that. New contrl board has been upgraded & came with listings of all codes, explaining every code in detail. Specs to test switch, motor & solenoid resistances. But thanks to you guys for pointing me in the right direction, with what code 37 means in the begining.
Nov 23, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
Top Washing Machines Experts
