Question about LG WM-2277HW Front Load Washer
What causes an lg direct drive not to spin
What causes an LG direct drive WM not to spin
    President:
  • 2,468 Answers
Your tub needs to be totally empty of water first,if it is then open the top cover and run the diagnostics on the unit,if this fails then the control board is defective
Posted on May 29, 2010
Spin cycle isnt spinning. it will spin slowly during rinse but not spin cycle
Are you receiving a "LE" error code on the display? If so, you'll possibly need a Hall sensor or Stator assembly replacement. If you have your units date of purchase, it will possibly fall under the 7 or 10 year warranty on the direct drive assembly which includes hall sensor/stator/ and the rotor.
You can refer to LG for service if you'd like.
Mar 07, 2011 | LG WM-2277HW Front Load Washer
My LG Wm 2432HW is making a lot of noise when it goes into the spin cycle. Is there an adjustment for the direct drive gears? The machine is level and it occurs with any load of laundry.
check your the inside tub for play if the tub moves up and down or side to side loosely your bearings are possibly going out. mine did that and it wasn't long before it ground a hole in the outer tub causing a massive leak.
Nov 05, 2009 | LG WM2432H Front Load Washing Machine
LG WM-1832 C
the spin tub
or the entire tub itself?
if its the spin tub inside, it would be caused by serious issues
the whole tub is just a replacement of the suspention. access is through the rear.
May 28, 2009 | LG WM-1832C Front Load Washer
Lg wm-14445fds direct drive 8kg washing machine manual
You can get the manual here:
http://uk.lge.com/products/sidemenu/list/homeappliances|washingmachine|steamdirectdrivewashingmachine_PRD|MANU_manu.jhtml
Just curious - what happened when you tried to get in touch with LG? Also, did you call, email, what?
Aug 07, 2008 | LG WM-2277HW Front Load Washer
LG WM 1832CW
if your getting LE code on your LG washer check if your hot and cold water is hooked up right
Jan 27, 2008 | LG WM-2277HW Front Load Washer
LG Direct Drive WM-16220FD loud vibration during spin cycle
the pump hose is knocking if you can unplug the machine and tilt the machine on its back you can see the hose get a cable tie big one you can cable tie it down that would stop it from moving that's why its knocking if the pump is not on that side then your suspension leg is on its way out meaning you will have to call your local second hand shop to have a look but be for you do have a loo your self save money
Jan 05, 2008 | Washing Machines
LG WM-1280 DD front loading washing machine
Be sure the unit is level, not just stable,with the four feet touching the floor. If the unit is not level the centrifugal force of the spin cycle will be distributed unevenly, causing more pressure to be exerted in one corner then the other. this causes the unit to slighty lift in the opposite corner, thus shaking or vibrating. Many people citing this problem have their washers in an upstairs laundry room. Some of these houses may lack the needed support to sustain these washers without the floor flexing. the quality of the building is a factor.
Sep 19, 2006 | LG WM1812C Front Load Washer
LG WM-2277HW Front Load Washer Logo
593 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
