320gb harddrive only reconized as a 126gb
I have a wd3200beve 320gb harddrive but my computer only reads it as a 126gb i have tried this drive in a 2004 and a 2009 computers running xp pro and windows7 but both computers read it as 126gb
    Guru:
  • 158 Answers
    Problem Solver:
  • 12 Answers
Try partitioning the drive to make the bootable partition to be 120GB and the rest as the second partition. It will appear as two hard drives but you will be able to use the entire drive.
Posted on Dec 11, 2012
When I plug my harddrive into the computer everything freezes up instantly! help
Try it on another computer, if it happens on the other computer then the hard drive is bad.
Jun 02, 2016 | SimpleTech SimpleDrive Pininfarina 320GB...
How can i claim for harddrive warrenty
You would have had to have the hard drive specifically insured against damage you should check your computers insurance policy it should be insured against damage read the fine print.
hope this helps
Dec 31, 2012 | Samsung 320gb 7200rpm sata desktop hard...
Installing a new larger hard drive, and it will not accept it?
Wait a minute! Hold the phone!
HOW, are you trying to install this 320GB harddrive?
You cannot just grab a fresh, new harddrive, and put it in. There's no Operating System on it. It's on the 160GB harddrive.
(Windows XP?)
Not trying to 'sound' condescending, but I do not see anything to support that you know what you are doing.
If you are using a Western Digital 160GB IDE harddrive, you have a motherboard, and BIOS, that is past the size limitation for an IDE harddrive.
The size limitation was 137GB for motherboards, (BIOS program, actually), that had this limitation.
Size limitation isn't your problem.
Plus, LEAVE BIOS ALONE, as far as upgrading.
Why?
A) Power goes out while you are upgrading, and when asked, you do not save a copy of the original BIOS program, you can take your motherboard out, and use it for a Frisbee.
B) IF, there was a BIOS upgrade, AND it is NOT compatible, AND when asked you do not save a copy of the original BIOS program, you can take your motherboard out, and use it for a Frisbee.
Also, if it IS an IDE harddrive, and the old 160GB is an IDE harddrive, you cannot put both harddrives on that flat ribbon cable, AND use the 320GB as a Primary harddrive.
Want to use the 320GB as a Primary harddrive, (Master), and the 160GB as a Secondary harddrive? (Slave) There is a proper procedure.
No, I'm wrong? You have a fresh, new GENUINE copy of Windows, and are going to install it on this 320GB?
[Microsoft makes one Master disk. From it all GENUINE copies are made, and sold to the consumer ]
I hope it is Windows XP, (Home or Pro)
Why?
Because drivers are not be available for Windows Vista (Yecch!), or Windows 7.
What are drivers?
Small pieces of software that allow the Operating System to communicate with a device.
Windows XP and Windows 7, are just two examples of an O/S.
Harddrive, motherboard chipset, optical drive, (CD/DVD drive), audio (Sound), etc., are Devices.
http://support.gateway.com/us/en/emac/product/default.aspx?tab=1&modelId=1460
Winfast is no longer in operation. No help from them.
(The motherboard manufacturer that made the motherboard for eMachines/Gateway. Confusing? Yes, I know.
eMachines sold out to Gateway. Guess what? Gateway SOLD OUT to Acer. Isn't this fun(?)
The motherboard is a Gateway MCP61SM2MA. Part number Gateway 4006232R.
http://support.gateway.com/s/MOTHERBD/Shared/4006232R/4006232Rnv.shtml
1) Has one Parallel ATA connector on the motherboard.
[PATA. Term is also known as IDE. Just to be more confusing, it is also known as EIDE. Enhanced IDE brought out by Western Digital, back in the day. The reason PATA is used, is to help distinguish it from SATA.
Serial ATA. This will help you understand,
http://en.wikipedia.org/wiki/Parallel_ATA ]
On the main Gateway support page I linked above, click on ->
Product Views.
In the list click on the blue -> Parallel ATA IDE connector.
2) The motherboard also has two SATA connectors,
http://en.wikipedia.org/wiki/Serial_ATA
On the Hardware Details list, click on the blue -> U - SATA connectors
Do not know if it is a PATA harddrive, (320GB), or a SATA harddrive?
Look at the label. Example on WD 160GB might be WD1600BEVT.
What is it on the 320GB?
Blank, new 320GB WD harddrive? BIOS isn't going to recognize it.
Why?
It hasn't been formatted.
WD does have a software tool to do this. Do I recommend this for a beginner? NO.
Better to install the 320GB in an economical external enclosure, and plug the USB cable from the enclosure into any available USB port on your computer.
Now you have a 160GB harddrive with WinXP on it, and 320GB's of extra storage.
Example (IMHO) of an economical external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1733195&CatId=2779
If you have no clue of what I have posted above, it is going to look like so much gibberish. Not my intent.
Not after 'Points'. Could give 2 cents.
{With this website you can rate ANY solution you see, and ALL solutions you see}
My intent is to teach. I have been at this for 8 years. (3 here, 5 elsewhere)
I want you to understand. Post back in a Comment, with the answers I need, from the questions I stated above.
We together WILL find a solution.
Regards,
joecoolvette
Jun 20, 2012 | E-Machines Computers & Internet
Hi there , i have an acer travelmate 6592 laptop , the original 80 gig hard drive crashed , and i dont have the recovery disc , the hidden partition wont re install either , i have bought a new 320 gig...
You cannot get the full 320Gb capacity because the BIOS can only support a maximum of 127Gb.
You only hope is a BIOS firmware upgrade that can support 320Gb. Check out the Acer WEB site to see if a BIOS upgrade will solve your problem.
OTHERWISE
Install a 127Gb hard drive in your Acer and put the 320Gb hard drive in an USB hard drive adapter case and use it as an external USB hard drive because it is not affected by the BIOS limitation.
Jun 13, 2011 | Computers & Internet
I have just tried, for the first time, using my new 320GB Canvio. The white pilot light comes on, and I feel the disk spinning for a short time, but there is no operating software presented, and no file...
External harddrives do not come with an O/S. They are for external storage, beyond the master harddrive you have installed.
The master harddrive has the O/S.
The Platters are spinning because BIOS had a look to see what is on the Toshiba 320GB external harddrive.
[You press the Power On button. The first chipset to receive power is the BIOS chipset.
(Basic Input/Output System)
BIOS looks to see what devices are connected to the computer, does a Ram Memory count, turns the Processor on, then hands the computer over to the operating system.
BIOS finds THE harddrive with the O/S on it ]
http://en.wikipedia.org/wiki/BIOS
http://computer.howstuffworks.com/hard-disk.htm
When the Windows O/S (Operating System) is installed on a computer is assigns hash values to certain major hardware components in the computer.
A) Processor
B) Harddrive
C) Motherboard. (Motherboard chipsets and BIOS software on the BIOS chipset)
D) Graphics chip. (Whether it is Integrated Graphics, {OnBoard}, or a graphics card)
Change any two of these hardware components and Windows throws up a 'red flag'.
Microsoft's User License states, "One genuine copy of Windows per One computer"
If a hash value has changed, such as there are different hardware components, Windows 'feels' it is being stolen.
Why do you feel there should be an O/S already installed on the external harddrive?
Awaiting your reply please state in a Comment.
Regards,
joecoolvette
Jun 07, 2011 | Toshiba (1TBEXT-HDD) (1TBEXTHDD) 1000 GB...
My Apollo 25 PHDD-320GB harddrive does not appear on my PC. I get the bluelight stating power but the device does not read on any PC. Please Help
Nov 08, 2010 | Computers & Internet
External hard drive is not being recognized by any computer
First make sure usb cable connected to harddrive is working fine.
try it in different usb ports.
Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers.
then check.
Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11­CE-BFC1-08002BE10318}
And remove upper filter and lower filter.Then restart computer then check.
If your harddrive still not recognized then you need to repair your harddrive.Try your harddrive in different computer if it is not recognized on another computer then your harddrive has internal issue.
Let me know if you need further assistance.
Thanks for using FixYa.
Apr 27, 2010 | Western Digital Passport 320GB External...
I have an acer travelmate 4010 laptop with windows xp professional. i recently purchased a wastern digital 320GB hard drive (wd3200beve). when i installed it, windows only sees 137GB. when i take the drive...
Yes. Go to the control panel, adminstrative tools,computer management, disk management. From there you will see the hard drive and be able to expand it to the full 320gb.
Nov 26, 2009 | Acer TravelMate 4010 Notebook
HP Computers using XP will not show drive to which Western Digital 320GB external harddrive is connected
Your usb device could be finished or your USB ports may not be strong enough/ enough power to run the device.
Jan 13, 2008 | Western Digital 320GB MyBook External USB...
Computers & Internet Logo
372 people viewed this question
David Payne
David Payne
