Question about Sharp 56DR650 56" Rear Projection HDTV
THE TV SHOWS SOME BLACK LINES ON THE MONITOR - Sharp 56DR650 56" Rear Projection HDTV
  • 11,896 Answers
That would be either a bad IC (integrated circuit) chip or loose or bad solder joints on the circuit. You can google ic circuits to see what they look like. If you feel the need to test it, they do sell analog tester fairly reasonably priced to test them, but that is usually what causes the lines, especially if the are horizontal lines.
Posted on May 29, 2010
Tvgoes on ok and shows which channel - then goes black What is the cause please - and can I fix it
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Feb 22, 2015 | Home Styles 56" Wide Nova Teak Finish Hd...
My 42 inch tv when it turns on half is black then color lines show up and down then I'll just tap it slow on top and picture comes on like something is loose inside some times it doesn't work
- Flickering screen
- Dim screen
- Slow start
Feb 04, 2015 | Televison & Video
Dynex TV came on black and the buttons aren't working?
- Flickering screen
- Dim screen
- Slow start
Apr 21, 2014 | Dynex Televison & Video
Monitor flashes different colors
Monitor has been successfully broken with fall.
Aug 31, 2017 | Samsung P2370HD 23 in. TV
Red line on samsung led tv
Any line (black is worst) can be caused by a number of reasons
Main board which directs the image onto screen can cause this.
A bad board that drives panel can do this (usually a larger and black line).
A loose plug or connection usually with one or more of the ribbon style cables.
A issue which is fatal is the problem is inside the display panel and cannot even be got at to examine it--cost of replacing panel is more than a new set.
May 25, 2012 | Televison & Video
HP pavillion dv9000 has black horizontal lines across screen and looks like a snowy background
Sounds like the screen is going bad. Isolate the problem by plugging an external monitor to the laptop. Borrow a monitor from a neighbor, friend, relative or co-worker to plug to the laptop. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If the Borrowed monitor does not show the black lines and snowy background, that proves your video card is ok and the problem is your lcd screen. If the borrowed monitor shows the same black lines ans snowy background it means your video card inside the computer has the issue.
The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
May 18, 2012 | HP Compaq Business Notebook nx7000
I HAVE A LCD TV MONITOR, MODEL P2770HD, AND I CAN NOT FIND HOW TO REMOVE STAND FROM TV. SOMEBODY PLEASE TELL ME OR SHOW ME. RON
bobhifi_23.jpgIn the area marked by the yellow line you will find four black screws.Keep the monitor on the floor & remove the screws. now keep both your toes on the base stand and pull up the monitor. If you do not want to stamp on the base ask somebody else to hold it down while you pull up the monitor. Make sure you do not apply any pressure on the front screen. Hold the edges of the monitor
Mar 28, 2011 | Samsung P2770H 27 in LCD TV
My 20 inch lg tv crt monitor will not show a
is video show on vcr player? if yes you need to replace jungle ic which is switching line from tv tuner to line in video.
Feb 10, 2010 | LG 42LC2D 42 in. LCD HDTV
Horisontal lines
make sure the cords are connected properly from both the computers end and the monitor
Feb 03, 2008 | BenQ FP931 (Silver, Black) (Black, Silver)...
Sharp 56DR650 56" Rear Projection HDTV Logo
19 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
