Question about Sewing Machines
My zig zag is not working properly
Hi my machine stopped doing zig zag after one day while sewing the machine did a sudden stop and broke the needle and made a noise and small spring sprung out from the light area and i dont know where it goes after that i can only sew straight stitch and the zig zag and the button maker stoped working the right way, i need a repair book on this machine so i can adjust the zig zag and know where this spring goes.i took it to sears but they wont even look at it unless i give them a unrefundable $30.00 dollars, quite unfair if you ask me, i ask about repairs or at the very least a tune up, but still 30.00 bucks or nothing, well so here i am, hope you can help. thanks, i dont mind paying the 30.00 dollars but they werent sure they could adjust it. so i might as well adjust it myself. again thanks
by the way my e-mail is victoriano58@yahoo.com if is easier for an asnwer, am also willing to pay for the book. is a kenmore sewing machine model 385 16120200
  • meli_mp2 Sep 04, 2008
    how to fix the zig zag its stitching straight when i put it on zig zag
No i have not received an answer to the problem from no one
neither anyone having a repair book on this machine, anyway the reason i cannot purchase a plan is because i dont have a crdit card.
Posted on Apr 08, 2008
After my needle broke I replaced it with the proper needle and i t will not zig zag
Is not picking up the bobbin thread? Very possible the machine has been knocked out of time. Search for sewing machine timing or take it for service.
Mar 07, 2017 | Sewing Machines
I just worked with my Shark sewing machine and it was fine suddenly it stopped zig zag and start working simple stitches! Can you let me know why it happened? There was no noise or sound of breaking.
There is a spring that got loose from the needle arm that keeps pressure on the arm. It needs to be reattached. Anyway, make sure all of the normal adjustments are set properly. Just one adjustment wrong will cause the machine to only run in a straight stitch. Possibly a button hole or something else. Remove the top of the machine and look down where the needle arm is. The needle arm bracket has got to pull the arm towards the arm using the pressure of an attached spring. This spring is hanging inside the machine from a permanent side bracket. If it isn't there then it has dropped to the bottom of the machine. Anyway, the needle arm must have the sideward pull in order for the machine to produce a zigzag stitch.
Aug 05, 2016 | Sewing Machines
How do i adjust my machine so i can use the zipper foot?
If you could tell us what kind of machine you're using maybe we could help you more effectively. Thanks
Apr 04, 2015 | Sewing Machines
Can I go from straight stitches to zigzag stiches and back in the same seam?
Hi Susie,
I can't tell whether you mean straight stitching and then turning your work 180 degrees to stitch atop the straight stitches in zig-zag, or continuing around the corner of your straight stitched side using zig-zag. But you can do either. You can mix up straight and zig-zag stitching at will.
Just ease up to a stop, ensuring the needle is positioned down inside the work when you stop.
Lift the foot.
Adjust to your desired stitch setting.
Lower the foot.
Turn the wheel toward you manually to ensure the stitches will be placed where you want them, and
Slowly engage the power again (via foot or thigh lever).
Hope this helps.
May 14, 2014 | Singer 3116 Simple
Singer Touch and Sew Model 648 will not zigzag
There is an arm in the head that does the zig zag movement and attaches to the needle bar with a pin. If that isn't connected zig zag won't work at all.
Jan 19, 2013 | Sewing Machines
Can't sew. Needle hits zig-zag plate. Needle is not bent.
Replace the needle anyway, it's probably blunted now. Also narrow the zig zag width. But your machine needs adjustment. Take it in for a good clean and repair.
Dec 30, 2012 | Sewing Machines
The fabric doesn't move forward.
What is the length set at?
Are the feed dogs visible at the needle plate?
What does the design look like in the pattern box?
Have you tried it on the straight stitch to see if is effected also?
Bonnie
Sep 21, 2008 | Kenmore 15516 Mechanical Sewing Machine
Suddenly zig zag stitch not working?
Because it is almost a straight stitch but the needle continues to move in a zig zag fashion is reason to believe it is in a long stitch. By changing the number of stitches per inch there will be a very noticeable looking zig zag stitch.
Mar 25, 2017 | Brother XL-2610
Sewing Machines Logo
287 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
