Question about Sony HDR-SR11 Flash Media Camcorder
The touch screen has stoped responding to touch what is the most likely reason, it did this a couple days ago and i calibrated it and that helped for awhile but now nothing works
I have the same problem. Without the LCD working, I cannot retrieve the data from HDD to my computer. I believe that it is a serious design flaw. Fixing the camcoder will cost $300, not really worthy. Does any idea how to retrieve data even Touch screen does not function?
Posted on Jul 22, 2010
  • 1 more comment
  • IshmaelB Jun 29, 2011
    I fixed this by attaching the usb cable and then pressing the disk burn button on the camcorder. It automatically goes into USB mode. Touch screens are like electric windows, great when they work but you wouldn;t want to rely on one in a disaster. Hope this helps somebody D.B, Glossop
  • Paul Hughes
    Paul Hughes Nov 27, 2012
    Lifesaver, thanks! I might have eventually started pushing all the buttons and discovered it. I pulled my SR11 out of the bag recently where the last time I used it it worked fine, wasn't dropped or anything. Screen is very dark and hard to see (viewfinder screen still works) and screen touch no longer works.
  • nsuri2004
    nsuri2004 Feb 27, 2013
    USE THE DOCKING STATION AND HIT THE USB BUTTON ,,, IT WORKS AND WILL CONNECT YOUR CAMERA TO PC THEN DOWNLOAD FILES... FORGET DISPLAY FOR NOW
Touch screen not responding
Which model of Ricoh are we talking about here? If touch screen is not responding before replacement, re-calibrate touch screen or replace it. I can help you with the calibration code if you require. If the touch screen is not responding after replacement, check whether the replacement lcd display panel was installed reverse as the connectors will not have contact.
Mar 12, 2014 | Ricoh Office Equipment & Supplies
My nokia touch screen is not working. Everything else on the phone seems to be fine, just that when I touch the screen there is no response. Please can you help?
Hello there,
There are two major reasons that could be causing the touch screen not to be responding. The first is if the phone fell and the sensor board got bad, and the best solution is to replace the sensor board. To replace the sensor board is quite sensitive so i will strongly advice you seek advice from a specialist that can assist you with that. But if you intend to fix it DIY way, then you can ask and i will direct you through the steps.
On the other, it might be the screen is weak and needs calibration. To calibrate the screen. I will advice you go through the user manual for the steps to calibrate the screen of your phone. If you cannot get any response from the screen, i will advice you replace the sensor board. Because calibration requires you to touch the screen and since it is not responding to touch, it will be pointless trying to calibrate.
Thank you for using fixya.
Caseytech
Sep 21, 2011 | Cell Phones
My iphone screen cant touch ?
Hello there,
Caseytech
Sep 21, 2011 | Apple iPhone Smartphone
Touch screen not working with my KP500
Hello there,
On the other, it might be the screen is weak and needs calibration. To calibrate the screen depends on the type of phone it is. I will advice you go through the user manual for the steps to calibrate the screen of your phone. If you cannot get any response from the screen, i will advice you replace the sensor board. Because calibration requires you to touch the screen and since it is not responding to touch, it will be pointless trying to calibrate.
Caseytech
Sep 12, 2011 | LG KP500 Cell Phone
Samsung a897 touch screen not responding at all
Hello there,
Caseytech
Jun 27, 2011 | Samsung Star GT-S5233 Cell Phone
We have a Leapster 2 which the screen no longer registers when touched by the pen. Can this be fixed or replaced? i bought it only 2 months ago hope you can help Emma
I posted a solution to this problem a couple months ago. We have the Cars edition of the Leapster2. I'm guessing it was the same problem that we were having. When the pen touched the screen there was no response and the unit had barely been used. Try this!! I found it on www.ehow.com.
Callibration
  • If you touch your stylus pen to the screen of your Leapster2 and it does not respond, your unit needs to be calibrated. To do this, make sure no game cartridge is in the unit. Turn the unit on while you are holding down the "Hint" or "?" button. Keep holding the button down until the Leapster2 menu appears. You will need to turn off the unit and repeat these steps if you do not see the menu. When the menu comes onto the screen, press the "A" button and use the stylus pen to touch each of the crosshairs as they appear. When you are done, your unit should be properly calibrated.
    Read more: Best Way - Leapster 2 Troubleshooting ' eHow.com http://www.ehow.com/way_5868621_leapster-troubleshooting.html#ixzz0wVJdZzs5
  • Feb 02, 2011 | Leapster Learning System
    My iphone screen is cracked and my touch slide button wont work but i can still can except call but i cant slide it to unlock it is there anyway to fix it
    my phone is a IPhone 3gs and i cracked the screen a couple of months ago and a couple of days ago my screen started to act really slow and it wouldnt work on some parts and now today my screen wont work nor respond at all. PLEASE HELP ME I REALLY NEED MY PHONE ...!!!!!
    Jun 16, 2010 | Apple iPhone Smartphone
    My nokia 5800 XM screen not working properly, I'm touching something its sawing different thing. whats probelm? Nokia 5800 XM screen not working properly, I'm commanding some think, its respond wrong....
    You can try calibrating your screen using the procedure at this link
    http://www.walkernews.net/2010/01/30/how-to-calibrate-nokia-5800-touch-screen/
    It will be difficult to start since your screen is not reacting as you expect it to, but it sounds like the calibration is out of whack.
    Feb 16, 2010 | Nokia 5800 XpressMusic Smartphone
    Particular areas on my Blackberry Storm 9350 touchscreen do not respond to touch (cannot highlight or press). Also, every couple of days, the entire touchscreen will not respond and i have to 'cold boot'...
    Hi, The screen of a BlackBerry Storm smartphone appears to be easily scratched or has air bubbles.So the BlackBerry Storm smartphone does not respond consistently to finger touches or slides.
    This issue could be because one of the following reasons:
    1) The clear plastic screen overlay that is placed on the BlackBerry Storm smartphone during the manufacturing process to protect the screen during shipping has not been removed.
    2) A purchased plastic screen protector has been placed onto the BlackBerry Storm smartphone.
    Still if you are facing the issue then please visit the blackberry service center or contact your service provider if it is under warrenty. I hope this information will be helpful to you
    Nov 24, 2009 | RIM BlackBerry Storm 9530 Smartphone
    Sony HDR-SR11  Flash Media Camcorder Logo
    604 people viewed this question
    Top Sony Video Cameras Experts
    Larry Stiles
    Larry Stiles
    Jerry Greenberg
    Jerry Greenberg
    Are you a Sony Video Camera Expert? Answer questions, earn points and help others
