Question about Jacuzzi Cyget In Ground Pool Pumps
We do not know where the air filter valves are
We have a Jacuzzi Pool Pump. It will not prime. We do not have a manual on the pool pump to know where to locate air filter valvers, etc
  • 8,404 Answers
Air filter?
Remove the strainer basket cover ... fill with water ... check the gasket ... replace if questionable ... close the cover and SNUG the top down. Start the pump ... it should run just fine.
If you are sucking air, tighten the strainer basket cover a little.
Still sucking air? You will have to find the air leak. You might plug the leak with plumbers putty.
Posted on May 29, 2010
My intex 637r pump is not pulling the water through to the filter and letting it discharge back into pool could it be that the pump and hoses are sitting to high on the ground and not far enough under the...
Air release valve for air trapped inside filter chamber
Intex 1000 GPH Easy Set Pool Filter Pump Instructional Guide 637R
The link has a set-up video for the 637R pump. Make sure water flows out of the air valve on the top of the filter cover. This will purge air out of the filter and prime the pump. Hope this helps you....
May 13, 2014 | Intex Krystal Clear Model 635 Pool Filter...
My pump is not primeing
most pumps that won't prime are not recieving a good seal on suction line (inlet) ck alll the fittings for good o-rings and ck filter lid as well , hairline cracks too can develop in hard plastic over time and rough treatment this can lead to loss of prime , one other reason and it's the most expensive reason is pump seal at drive end has went bad and sucking air if your handy with a wrench then you can source a new seal from jacuzzi if not replace entire pump (thats the expensive way)
May 10, 2014 | Jacuzzi Magnum Force Series Pool Pump 1...
No suction for pool vac
If you are not getting any suction to the vacuum, but the pump is working fine the rest of the time, start by checking all of your connections that conncets the cleaner to the filter and pump. Make sure there are no cracks, lose hoses, etc. Then, check for the following common problems with your pump that might cause low pressure in pool pumps:
1) Pump not primed
2) Leakage of air into suction system
3) Impeller clogged
4) Valve in suction or discharge line partly closed; Suction or discharge
line partly plugged or too small.
5) Plugged basket in skimmer or hair in lint strainer
6) Dirty filter.
Sep 09, 2010 | Jacuzzi MAGNUM POOL PUMP 1-1/2 HP MAGNUM...
Not self priming itself. when it turns off the water pushes back out of the skimmer and pushes the basket up. it loses water and the pump cant re-prime itself.
PRIME PUMP, OPEN AIR VALVE ON FILTER. OR TAKE THE LID OFF YOUR FILTER AND SEE IF IT STARTS TO PUMP... YOU DO HAVE IT PLUMBED RIGHT? THE PIPE COMING OUT OF THE PUMP GOES TO THE FILTER !! I'M YOUR LOCAL POOL PUMP REPAIR GUY IN LONGWOOD FLORIDA. WHERE THE POOL IS ALWAYS OPEN
Aug 28, 2010 | Waterway Inground Pool Pump Champion No....
I replaced CVA-24 VALVE....now when I turn on pool filter no water being pulled through..no water being pulled through to pump
Your pump has probably lost its prime. This is either because it got too much air or not enough water. Try priming. This should make your pump start working again. Any time pool pumps have to be services, they need to be re-primed. In case you are not sure how, remove the pot lid and fill the pot with water. Re-add and clamp the pot lid. Open the air release valve on the filter and stand clear. Turn on switch or time clock. When water comes out of the air release valve, close the valve. If it is a two speed pump, make sure it is on high speed.
Aug 20, 2010 | Pentair 3hp Whisperflo Pool Pump In -...
My jaccuzi message pump pressure is low
It could be any one of the following problems. Try these troubleshooting steps for Jaccuzi pool pumps.
1)Pump not primed. Prime pump.
3)Impeller clogged
5)Plugged basket in skimmer or hair in lint strainer.
6)Dirty filter.
Aug 05, 2010 | Jacuzzi Cyget In Ground Pool Pumps
Air in my jacuzzi pool pump
It sounds like air is entering the system through the clear dome (filter access) on the pump. Check the o-ring directly underneath the clear plastic dome. CAUTION: Be sure to isolate the pool from the pump via in-line shutoffs prior to loosening the dome lid. Sometime cleaning the o-ring and coating it with petroleum jelly helps the unit seal better.
Aug 02, 2009 | Jacuzzi Cyget In Ground Pool Pumps
Jacuzzi Magnum Force Pump not working
The number one problem is air leaks.......check all connections to see that they are tight, and rubber seals. The intake side would give you trouble with air leaks. If you dont find any leaks then I would pull the pump cover and check the impellor. Pool stores have parts and lots of knowledge.
Jun 09, 2009 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
My pump is running however it's pressure is less than 10 psi and the heater on the pool will not run.
With the Jacuzzi Magnum pool pumps, low pressure is going to likely be cause by one of the issues below. Try these troubleshooting tips.
1.Pump not primed
2.Leakage of air into suction system
3.Impeller clogged
4.Valve in suction or discharge line partly closed or suction or discharge line partly plugged or too small. 5.Plugged basket in skimmer or hair in lint strainer.
6.Dirty filter.
Jun 06, 2009 | Jacuzzi MAGNUM POOL PUMP 1-1/2 HP MAGNUM...
My pool pump won't prime
If the pump is above the pool water level the it is unlikly that the tank will fill completely with valves open (which is ok).Most pumps are self priming and will pick up a prime with water level below suction inlet on strainer. Try starting on main drain again and slowly open skimmer line. Did you remove water from skimmer line and winterize(if in cold weather climate)during closing?.I know this sounds stupid, but make sure water level in pool is well into skimmer. If air situation remains after scspriggs' and these thoughts then prepare for a pressure test on skimmer line to determine location of leakage.
Apr 21, 2009 | Hayward 3/4hp Super Pump Inground Pool...
Open Questions:
Jacuzzi Cyget In Ground Pool Pumps Logo
298 people viewed this question
Top Jacuzzi Pool & Spa Experts
Jay Finke
Jay Finke
Mike
john h
Are you a Jacuzzi Pool and Spa Expert? Answer questions, earn points and help others
