Question about Amcor PLM-14000E Portable Air Conditioner
Keep Tripping the Reset button on the Plug In Cord- Any ideas how to fix this issue? What is the issue? Basically It won't turn on at this point. I have owned if for a couple years. I cannot find the manual and don't know where to start as to a solution. I have cleaned the filter, drained the water, etc... What can it be?
I am having the same problem. Amcor is out of buisness,I called all the numbers on the manuel that is why I am trying this service
Posted on Jun 05, 2010
Ac won't blow any air
Good Morning David - Here are some simple troubleshooting tips to help resolve this issue:
If the outside temperature or inside temperature is below 60 degrees, the unit may not run.
Confirm that the unit has power to it.
Check the power cord connection to the wall outlet is secure.
Make sure that the house circuit breaker has not tripped.
Make sure the unit is turned off, Press the TEST button, you will notice a click as the BUTTON pops out. Then press the RESET button. Again, you will notice a click as the button engages, now turn unit on. If the LCDI plug does not reset the cord may be damaged.
The "Cool" circuit has an automatic 3-minute compressor time delayed start if the unit is turned off and on quickly. This prevents overheating of the compressor and possible circuit breaker tripping and the fan will continue to run during this time.
If the unit has been turned off and on rapidly or if the thermostat was changed to a lower number and then immediately turned back to a higher number the compressor may not start. You must turn the unit off and wait a minimum of 3 minutes for the unit to equalize before restarting.
I would recommend reaching out to an experienced appliance tech just to ensure no troubleshooting step has been missed. Parts are often costly and if the problem is precisely diagnosed, it can save you a lot of time and funds. I hope these troubleshooting tips help you in some small way.
Jul 09, 2013 | Frigidaire Heating & Cooling
Reset button on water heater keeps tripping
Need a new thermostat to keep the unit from tripping
Feb 13, 2013 | Bradford White CF-50-6 50 Gallon - 119,000...
Hp officejet 6500 all lights are flashing and mechine says turn off and on . Please can someone Help??
: Check the power cord
1.
Turn on the product.
2.
Remove the power cord from the back of the product.
3.
Check the power cord for any physical damage. If the power cord is damaged, replace the power cord.
If these steps resolved the issue , you do not need to continue troubleshooting.
If the issue persists , continue to the next solution.
Turn the product off and then on again
1.
Press the Power button ( ) to turn the product off.
2.
Wait 60 seconds, and then press the Power button ( ) to turn the product back on.
3.
If the product does not turn off when the Power button ( ) is pressed, wait three minutes, and then proceed to the next solution.
Plug the product into a wall outlet
Follow these steps to make sure the product is plugged in correctly.
1.
Unplug the power cord from the back of the product.
2.
Unplug the power cord from any surge protectors or power strips.
3.
Select a wall outlet to plug the product into. Test the wall outlet by plugging another electric appliance, such as a lamp, into the wall outlet and turning it on. Unplug the test appliance.
4.
Plug the power cord into the back of the product.
5.
Plug the power cord into the wall outlet.
6.
Press the Power button ( ) to turn the product on.
Solution six: Reset the product
Follow these steps to reset the printer.
1.
2.
Unplug the power cord from the wall outlet.
3.
Wait 10 seconds, and then plug the power cord back into the wall outlet.
4.
NOTE: Many power cords have an LED light on the power module or on the end of the cord that plugs into the product. Make sure the LED light is lit and steady.
5.
6. Perform a partial reset of the product
  1. Disconnect the power cord from the product.
  2. Wait for 20 seconds.
  3. Press and hold # and 3 while reconnecting the power cord.
  4. When the product turns on, release both buttons.
  5. Try printing again.
IF still won't resolve it by following steps mentioned above then your printer needs replacement. Malfunctioning hardware.
Mar 28, 2011 | HP Officejet 6500 Wireless All-in-One...
No connection the display reads "DAC FAIL CANT TALK"
In order to solve this issue, please do the following:
Unplug the power cord of the BOOM Push and maintain the button 1 on the Squeezebox player Keep maintaining 1 and plug back the power cord Release 1 when you can see RESET DAC
Fixed !
Have a great day !
J -
Aug 27, 2010 | Logitech Squeezebox Boom Radio
AC will not work after being cleaned
You are going to have to let it dry very well. That's about all you can do at this point, as something electrical has gotten wet, and its tripping the unit to keep from burning out a part. Its just a matter of wait. wait, and so on. It will start again.
Shastalaker7
Apr 17, 2010 | Samsung AW1203B Air Conditioner
On my mp 460 ,after a refill, doesn't recognize the cartriges.Any help for reset?thanks.
Hi there you can try this it may help.
How to correct, fix: Reseat ink cartridge for Printer MP460) Issue:
ERROR LED: E, 1, 4
How to correct, fix: Press ON/OFF switch to reset the multifunction device Reset the device when it is not functioning properly. If the device is not functioning properly or to clear memory, reset it. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.) Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer. Wait approximately ten seconds and then press the <ON/OFF> button again. Wait until the device has completed its cycling process before submitting another job request.
Turn the machine off, and remove the power cord from the electrical outlet.
Wait approximately ten minutes then plug in the power cord and turn the machine on. If the problem is not resolved, the machine may require service.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Feb 16, 2010 | Canon PIXMA MP460 All-In-One InkJet...
Moved my 7410 All-in-One - now it won't power on all the way
Perform power reset :
  1. Disconnect the power cord from the back of the product.
  2. Disconnect the power cord from the electrical outlet, and then wait 60 seconds.
  3. Connect the power cord to the electrical outlet.
  4. Connect the power cord to the back of the product.
  5. Press the Power button to turn on the product.If the issue still persists perform the partial reset steps:
    1. Perform a partial reset on the printer. To do this first remove the power supply from the back of the printer. With the power off press and hold the # and 3 keys.
    2. Plug the power back into the printer, keep holding the # and 3 keys till you see “ Partial Reset ” displayed on the printer screenIf the issue still persists, perform the semi full reset of the printer.
      1. Perform a partial reset on the printer. To do this first remove the power supply from the back of the printer. With the power off press and hold the # and 6 keys.
      2. Plug the power back into the printer, keep holding the # and 6 keys till you see “ Semi Full or Semi NVM ” displayed on the printer screen.
Sep 27, 2009 | HP OfficeJet 7410 All-In-One InkJet...
A6414w7b b wall unit gfi plug keep tripping problem: fedders wall unit brand new keep tripping the gfi on its power cord
GFI plugs go bad very often if you had a storm in you area. You need to replace the plug. Go to aplliance parts house and they will sell you the new cord. Feed back please.
Jun 13, 2009 | Fedders A6D24E7D Wall/Window Air...
Cannot engage RESET Button on plug to power the 220v AC unit
The reset button is a voltage leak detector it is possible the unit has a short in it or the cord has a short
Apr 28, 2009 | Heating & Cooling
Amcor PLM-14000E Portable Air Conditioner Logo
261 people viewed this question
Top Amcor Heating & Cooling Experts
AJMAL KHAN
Michael Youngman
Michael Youngman
Are you an Amcor Heating and Cooling Expert? Answer questions, earn points and help others
