Question about Gateway FPD2275W LCD Monitor
Monitor I am not getting a picture or anything on my monitor. Does that mean I need a new monitor or something else?
  • nazii Apr 08, 2008
    tried several things. plugging and unplugging. different outlets. completely shutting the power off everything. disconnecting things that didn't need to stay connected. the screen makes a little sound then shuts down without ever showing a picture or give any audio.
  • 40 Answers
Check the connections from the monitor to the CPU...
also did you install or change the resolution of the monitor?
also check the wall outlet.
Posted on Apr 08, 2008
MY MONITOR WENT BLACK, ABOUT SIX YRS OLD. STILL WORKS JUST CANNOT SEE ANYTHING. CAN THIS BE FIXED?
Have you check all connection to see if they are right, check if no cable was unplug, if you have and yet no picture display, It could be that the picture board on your monitor has started malfunctioning, since the power led or button is on, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity or any service center to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Jul 06, 2010 | HP Pavilion F1503 15" LCD Flat Panel...
The monitor functions only for 15 seconds then you don't see anything
The picture board on your monitor is bad, since the power led or button is on and all connection are correct the monitor only display for 15 seconds before going blank, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care
Jul 04, 2010 | Dell E773C 17" CRT Monitor
My lt865b doesn't display anything and the display functions of the monitor do not respond at all i love the monitor and need help.After 3hrs use the display starting going all white then blacked out. I...
It is the picture picture board on your monitor that is malfunctioning, since the power led or button is on, but the display screen goes blank, it means the picture board of your monitor has developed fault.
Take care.
May 07, 2010 | Mag Innovision InnoVision LT865s 18" Flat...
The ON/OFF button blinks but no screen image
Since the power led button is on, I think the picture board on your monitor is faulty that is why it is not displaying anything.
Since your computer work perfectly with other monitor, it means the picture board is bad that is why it is not displaying any image.
The best thing for you to do now is to take the monitor to a local repairer or any service center within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself in other to complicate issues.
Take care.
May 01, 2010 | Acer AL1716 F Monitor
I rebooted my PC and now screen is darker and my colors are off
Check the contrast (darkness/lightness) on your Samsung LCD. There's a menu button on the monitor, press that and select contrast setting from the Menu.
Apr 29, 2010 | Samsung SyncMaster 932B LCD Monitor
Power button is flashing and the monitor is not coming on. check all connection are fine even plugged into second computer and no differences. thanks john
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hello,
Since the power led or button is on, this indicate that the picture board is not responding.
The picture board of your monitor is bad that is why your monitor is not displaying anything on the screen, it means the picture board of your monitor has developed fault, because the power button is on.
Take care.
Apr 29, 2010 | Dell E193FP 19" LCD Monitor
Screen appears on for three seconds then goes black
Try the monitor on another computer that you know works, If it works on another computer then that means you have no video output on the original computer and you'll need to reseat the memory on that computer.
If you get the same response on another computer, then that means the monitor is bad and you'll need to replace it.
Apr 19, 2010 | Samsung Syncmaster 2033SW Monitor
The monitor works just fine when I turn it on and displays the picture perfectly, however, after 15 to 20 minutes the picture comes off and the screen displays a series of diagonal lines. Why does this...
It sounds more like a monitor hardware problem than anything else being wrong, but the definitive answer would be to try it on another PC.
If it does the same you know it's the monitor; if not investigate your PC.
Mar 25, 2010 | Gateway FPD1760 17" LCD Monitor
My monitor powers on I see the orange light (which normally means there's no signal) and the green (which means there's something being sent) however, the monitor doesn't show anything. Can anyone help
if you do not even get display of the bios screen it could be as simple as needing to reseat the memory moduleswhich is a common cause of no vid. Also are you using onboard video or a seperate video card?
Feb 11, 2010 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
No picture and make popping sound hp w2207.
Popping sounds from electronic devices is never a good sign. It generally means that something was shorted out inside the item. You will need to bring it to a qualified technican for repair or buy a new monitor.
Apr 12, 2009 | HP w2207 Monitor
Gateway FPD2275W LCD Monitor Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
