Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
OE error rest machine and error comes up again
OE error reset  machine and error comes up again water doesnt drain
removed cloths and start again  and i get OE
What should I do?
Posted on May 31, 2010
LG washer WM2501HWA quit mid cycle and had an OE error message. The drain filter was checked and was clear. I drained out all the water through the drain hose. For a time, the drum would not spin. When...
i believe if the water outlet is still good,,,,,u will have to loose out the pump from its cup , mayce something hooked its propeller inside the i cup or replace the water pump
Jan 25, 2015 | LG Washing Machines
-I have a Daewoo washing machine DW F1251S with OE error code. What doesthis mean?
Possible this is relative of a poor drain time which means a clogged draining pump and system. So it si best to remove and clean the drain pump/filter and reset.
check if the machine drain hose is connected to a outlet which is not clogged when the water is flushed out . Also the washing machine must be slightly tilted to drain to the pump to reduce the drain timing.
Finally check if the machine was overloaded to produce a strain on the motor so as to give an error. If so shut down remove plug remove load , check if the agitator is jammed and reset.
Nov 21, 2011 | Washing Machines
OE error
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 09, 2010 | LG WM2233H Front Load Stacked Washer /...
What does the flashing OE mean? My washer is flashing OE and the water will not drain after the cycle.
OE means the drain hose is clogged. UE means unbalanced or overloaded. This is decribed in the owner's manual page 31-32. Pull the hose from the back of machine and rinse it out. Then, check the lint filter on the bottom, front left side. Put drain hose back and close lint filter. Unplug the machine, press and hold the start button for 10 seconds to reset machine computer (not the on button...leave machine turned off and unplugged while resetting computer) plug back in, put on no spin and start the machine. It should drain.
Jan 20, 2010 | LG WM2487H Front Load Washer
My washing machine showing an OE error before end of cycle
OE error is noyhing but an Outlet Error.. OE simply means “the pump is blocked”. Clean and straighten the drain hose / clean the drain filter. Check the hoses (drain hose) and the pump filter but if it didn't cure the problem then turn the thing upside down and strip the pump out of it check if anything is caught in the impellor.. if so remove it and everything will be fine..
Jan 18, 2010 | LG WM-2277HW Front Load Washer
LG WM2277 "OE" ERROR. PLEASE HELP
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!!
Jan 12, 2010 | LG WM-2277HW Front Load Washer
Error code OE; dishwasher stops with error message 2 min into cycle, drainage seems OK, water doesn't appear to pump into machine - any advice?
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
Good Luck!!!
Apr 19, 2009 | LG 24 in. LD-12BW5 Free-standing...
Water doesn't drain
water discharge drain $50 part, easy installation. google the lg model to locate part.
Nov 19, 2008 | LG WM-3677HW Front Load Washer / Dryer
Washing Machines Logo
907 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
