Question about Frigidaire Dishwashers
DW5700P1 dishwasher must have stopped running last
I have a Frigidare DW5700P1 dishwasher which stopped running last night and left the tub filled with water. I have tried to run it in all cycles but the motor will not run to evculate the water. I believe the door switch is working as the opersting light comes on. Is it the motor or the relay the problem and how casn I confirm it before I order the parts?
Any ideas on what to check next and how to do it?
Thanks
  • Frigidaire Master
  • 3,247 Answers
A lot depends on at what point the dishwasher stopped working.
Have you tried to turn the mains power off and on again and then try one of the short cycles.
I would suggest if water is not draining, then empty with a small pan and check filter for blockages. Also good idea to check there is no blockage on the drain side.
A good site to check is
http://www.partselect.com/dishwasher+water-wont-drain+repair.htm
Please post a comment to let me know what you find.
Posted on May 29, 2010
  • 9 more comments
  • bdcurran May 29, 2010
    I have tried turn the power off and on at the circuit breaker as well as trying it in all of the wash cycles. i checked the motor leads with an ohmmeter and everything is fine with no readings on ther leads or to a grou.
    I changed the motor relasy thinking it was at fault but it did not correct the situation, I drained the tub,set it in max cycle and it filled the tu. The relay buzzed for a few seconds and stops. The timer seems to be working as it went through the entire cycle with the relay buzzing at every time the motor should have been running. For some reason it add more water at every point in the cycle.
    I spun the agitator foreward and backward with a battery power drill and it seems to turn fine. What should I check next? Could the door switch have anything to do with the motor not running. .
    Thanks,
    Barry
  • Sam May 30, 2010
    I do not have access to the user or repair manual for this model.
    But generally the dishwashers have separate motor for wash and drain.
    In your case I believe you are having problems with the wash. Does the drain cycle work?
    I am not doubting the door switch otherwise it would not fill. But you could test it with blade of srewdriver if the microswitch is accessible.
    Is the water heating up?
    Does your dishwasher have a float switch at the base? If so, is it moving up and down freely.
    Please post a comment to confirm what you observe.
  • bdcurran May 30, 2010
    The drain cycle does not work on any of the wash cycles. The water is supplied from the hot water line and is not heated. The motor on this model is reversible which I believe creates the drain cycle.
    When I checked the motor which has five leads running into I put one of the leads from the ohmsmeter into the white lead and placed the other lead in the other four terminals. Then I placed one of the leads against the case of the motor and tested all of the leads and all readings were 0.
    The door switch is not accessible on this model without disassembling the door. Do you have any other ideas on what is wrong with the unit? I have a large party coming up next weekend and need to get it fixed or buy a new unit.
    Thanks,
    Barry
    The float works fine and the tub fills up like it always has.
  • Sam May 30, 2010
    If you can hear the relay clicking - are you able to check if the motor is getting the power.
    Where is the motor power coming from - direct mains or is there a conversion somewhere.
    If power is ok then perhaps the main suspect looks like the motor. How old is the unit?
    Unfortunately I cannot find any documentation on the web about this model.
    Hopefully you will get some success before your party - otherwise might have to be paper plates.
    I am unable to check if the motor is getting power without cutting into the circuit which I would rather not do. The unit is 17 years old and has worked fine up until this point with the exception of replacing the door seal. Do you have any other suggestions on what maybe the problem?
  • Sam May 31, 2010
    At this stage the best bet is to go to the motor and expose its leads and check the power supply coming to the motor.
    If you are getting the voltage, then the motor is not responding. Could be a broken bearing. If you are not getting any voltage at the motor terminal then you will need to trace back to the relay terminal to see if the Power supply is dead.
    Not sure if I have any other ideas to help you. Unfortunately I am not able to track any documentation on this model.
  • Sam May 31, 2010
    Further to my earlier posting - I have located a possible replacement for the motor of your dishwasher.
    http://www.repairclinic.com/SSPartDetail...
    It does appear to be expensive. It would be nice if you could check the voltage coming at the motor terminal when the relay/ timer is on. Can you take it out to check any possible damage before you order a new one.
  • bdcurran May 31, 2010
    There are four leads going into the motor which ones should I check? There is a white one, a red one, a black one and blue one. Which one of them is a ground? If you cannot properly diagnose and do not have access to the manual or a schematic it maybe we should call it a day as I am running out of time.
    Thanks
  • Sam May 31, 2010
    You are welcome to keep trying with other experts anytime. I did explain to you right in the beginning I did not have access to any documentation on your dishwasher.
    I thought you were familiar with the components the way you described the tests you had already done. If you are checking voltages it does not matter which one is ground. All you need to know is
    1) what is the voltage rating of the motor - should be 120v AC in USA. (check plate on motor)
    2) are you getting that voltage on any pair of wires. (make sure your multimeter is set for AC volts).
    If the volts are coming from the relay/ controller then your motor is the problem. Otherwise you will have to trace back the connection to the relay to find why the volts is not reaching.
    Please note you have no obligation to keep dealing with me.
  • bdcurran Jun 01, 2010
    It looks like you are unable to come up with a definitive solution to to the problem I am having with the dishwasher and I have sent an email to FixYa.com to let them know the matter is unresolved and request a refund on the money that has been paid.
    I was hoping you could have found a resolution to the problem. Thanks for your time.
    Barry
My dishwasher(samsung DW7933LRABB) wont fill, it will drain if i put water in the tub. supply is on.
You either have a bad water valve, or a bad case-brake assembly (in which case you should have an error code or blinking light on your console).
Mar 06, 2015 | Samsung Appliance DW7933LRABB 24" Tall Tub...
KUDS01FLSS0 Dishwasher - tub slwoly filling with
Slow fill of water is due to the strainer clogging. Strainer is located on the body of the machine where the inlet water hose is connected.
Clean all the water flow tubes in the machine.Clean the solenoid valve opening also.
May 26, 2010 | KitchenAid 24 in. KUDS01FLSS Built-In...
My dishwasher does not drain after water filling. it used to work fine last week.
that was then this is now . drain problem w/ your model g e / ck drain line for restriction / ck power valve in back of tank / ( verry common ) and drain valve sol under tub left of pump motor . with motor running hold down sol / if drains prob the problem . this will also ck the drain line quickley .. mm
Dec 07, 2009 | General Electric GSD4060NSS Built-in...
Our Kemore dishwasher is leaking water onto floor, and the water valve continues to pour water when machine was turned off, but is not leaking water now. There is also standing water at bottom of tub from...
you just need to clean the pump area in the bottom of your unit :)
try to take spray arm out if you can and then open pump cover clean it good but watch for broken glass in it ...and thats it :)
Aug 12, 2009 | KitchenAid 24 in. KUDS25SH Built-in...
Kenmore Dishwasher 5871525 stops running after a few minutes
sounds like a stuck key pad since you said the normal wash button flashed.. the other thing is try holding the door shut while you run it.. to see of it is maybe not latching properly..
Apr 10, 2009 | Kenmore 15762 Dishwasher
Whirlpool dishwasher will not fill with water
turn the valves to the left if there the screw in type or parraell if the quick open type the first thing a dishwasher does when you start it is drain for a few minutes then stops then fills with hot water run the water as hot at the sink as you can before starting the washer there is a float in the tub that can shut the water valve off if its not seated on the safety switch after the drain at the start of cycles stops then you should hear the water valve open and start the fill let me know and we will go from there
Mar 27, 2008 | Frigidaire 24 in. FDB126RB Built-in...
KitchenAid Dishwasher fill up with water after use
Is the water clean water or dirty water? This may sound like an ignorant question, but it can make a difference. If the water is clean water, it sounds like you could have a bad fill valve. If the dishwasher is filling with water when it is not running, chances are the fill valve is leaking. The valve is closed when the float switch senses the tub filling to a certain level. The valve is also closed when not energized by the control board during drain, drying and off cycles. However, if the valve diaphragm is not seating properly when closed, it will continue to leak by. That's probably why you don't notice it while is running and it has a chance to fill during the night when not in use. Here's what to look for: With the dishwasher off, take a towel and dry the tub as much as possible. Now, locate the fill port where the water comes in (usually on the left hand side of the tub). Watch this fill port closely for several minutes to see if water is running in. It could be as minute as a trickle or drip. If any water is coming in at all, the fill valve should be replaced. Now, another problem that can occur is when you notice dirty water staying in the tub or overflowing. This is usually caused by a bad check valve in the drain pump that's allowing water to leak back from the sink into the tub. Or, you do not have a high loop in the drain line. Here's what to look for: Check to make sure the drain line has a high loop as it leaves the dishwasher and before it gets to the drain pipe at the sink. That is, make sure the drain hose is looped above the trap in the sink and not laying under the sink somewhere. You can also try filling the sink with water and open the dishwasher door. Drain the sink to see if anything is getting fed back into dishwasher. If you see water starting to fill in the tub, chances are you could have a bad check valve. Some dishwashers have a check valve in the drain pump, while other models have the check valve located in the drain hose itself. Some don't have one at all. That's why the positioning of the drain hose can be important. Good luck to you and I hope this may help. If you determine a cause, post back with comments if you need advice on how to replace anything.
Sep 22, 2007 | KitchenAid 24 in. KUDS25 Built-in...
Dishwashers Logo
307 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Garth Jackson
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
