Question about Jenn-Air 27 in. Electric Single Wall Oven with Multi-Mode Convection
I don't know how to turn off the oven - I am at my sisters place alone and I don't know where the breakers are either!!! Help!
  • Jenn-Air Master
  • 3,053 Answers
Hello, dalia
I was trying to help you out here. Maybe this will help some? I was going back to some customers that asked questions in the recent past and farther back, It appeared that no one answered some of them, So, I thought I would take some of my personal time to see if I can help. Even though this site may not have your exact model or brand, This link will help you tons. Here is a link to about everything you want to know about your oven, from repair to trouble shooting it. Even pictures and video's. Just scroll around and you will see tons of information to almost any question you might have on your Oven. If you go to this link and click around, I am sure you will find out so much about your oven, you will know more than the company that made it. The good thing about this link is, then you can make the decision of DIY or hiring a pro. Here Is the link for you to click on>>
http://home.howstuffworks.com/dishwasher.htm
Please if this helped you at all, if you can find the time to rate my help and some kind words written would be appreciated for my free help , I would appreciate it. Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks,Mike
http://home.howstuffworks.com/how-to-repair-an-oven.htm
Thanks,Mike
http://beta.fixya.com/users/mc1bean
Posted on Oct 28, 2011
Wont get hot
Most likely burned out heating element. Does the broil work? If your handy turn off the circuit breaker making sure power is truly off by turning on oven to verify it won't turn on. Remove the screws from the bottom heating element remove the wires and take it to your local appliance supply house, they might test it for you and they can surely sell you a new one just by the the shape alone.
Oct 28, 2013 | GE Jrs06Skss 24" Single Electric Wall Oven...
Kenmore 790
I could be wrong, but from your limited description I am assuming that you cut the cord and wired direct to the box. You may not have 240 volts at the box and are trying to connect it to 120 volts. A dark green wire is the safety ground. The white is neutral and two colored wires are supply lines with 120 volts ( average) EACH. Better get someone in there that knows electricity and how to make proper connections to the proper voltage. Otherwise you are asking for major trouble.
Jun 26, 2013 | Ovens
I have an Turbochef NGC oven that keeps tripping the breaker. There are no faults but seems to only trip the breaker when the sausage setting is entered.
BEFORE WORKING ON OVEN MAKE SURE YOU TURN IT OFF AND DISCHARGE CAPACITOR.IF YOU DON'T KNOW THEN STOP HERE AND CALL TECHNICIAN.
If you know how to use multimeter than check the resistance of Convenctional heater and the IR element.
CC heater .....not sure how many ohms
IR should be 14 ohms
If both are in specification then replace breaker(thermostat in the oven).
Usually if breaker trips 4-5 times then its good to replace it.
reply me if you need more help
and don't forget to vote me.
Aug 10, 2011 | TurboChef TORNADO Electric Oven
We had lighting come in and now our GE electric oven doesn't work. The range top still works but the oven display does not. Any idea's?
Look for a reset or fuse on the unit. If lightening hit, the surge could have wiped it out, as you already know. But hopefully GE put a fuse or breaker in the unit. You just have to find it, if it exists.
According to GE, a diagram is located in behind the control panel. If you can safely remove it (CIRCUIT BREAKER OFF) you may find the protection devices that GE has in place. You may also
find the fuse or breaker hiding in there too! Good luck.
NEVER ACCESS AN APPLIANCE WITHOUT FIRST TURNING OFF THE CIRCUIT BREAKER
OR UNPLUGGING THE UNIT. BE SAFE.
Apr 01, 2011 | GE Profile JTP18 Electric Single Oven
My sister's oven element burned out. Never having replaced one before, I asked a friend how to get it out & he told me. I asked about turning power off & he said as long as the oven is off no need....
First, you should always turn the power off to replace the element. One side of the element always has 120 VAC applied and it turns the oven on by applying 120VAC to the other side giving 240 across the element. Most ovens have L1 branching out to both the bake, and broil elements, and it also branches out to the control board and all of the switches that run your top elements. If you don't have an element in the bottom, its likely that L1 is grounded out and is tripping the breaker as soon as it's turned on. So if you install the new element it should fix your problem, however if it doesn't you might have burned up the L1 wire somewhere and will just have to trace it back.
Jan 30, 2011 | Ovens
Oven displays "Supply Open Neutral" What does
I got this problem on my GE Trivection oven after a 2 minute blackout. "Supply Open Neutral" showed up and no other buttons worked. I shut off the breaker to the oven from outside and it still didn't work. I then turned the breaker off of the other appliances in the kitchen and turned the Trivection oven breaker on first and then it worked. I don't know if it was the order or whether I just turned it off for a longer period of time, but the oven started working normal again.
Nov 29, 2010 | GE Monogram® ZET3038 Dual Single Oven
I opened the door while cleaning was in setup and now F-9 flashes and I cannot turn on my oven.
Hello, welcome to Fixya.
The timer is just indicating the "monitor" switches where interrupted while the sensing of their position was taking place.
Have you tried turning off your breaker at the home service panel ( or unplugging it for several minutes ) ?
If not, turn off your breaker and turn it back on. This should initiate a restart of the component`s back to factory default including the lock monitor switches.
Once you switch the breaker, allow it to go through the start-up process ( don`t open the door or touch the clock ) where the processor (onboard watchdog) checks to make sure all functions are in working order and all switches are in the default position, ready to use.
If it works for you please take a second and rate the answer favorably, if not let me know and we`ll go from there.
good luck
macmarkus :)
May 08, 2010 | Frigidaire 30 in. Electric Gallery Series...
GE CONVECTION OVEN. WE GET DISPLAY MESSAGE F2
Diagnosis= failed thermister (temp probe inside the oven cavity) The part number is WB23X5340 and it lists for ~$72.00 at your local appliance parts place.
Bad news is that you have to pull the oven out of the wall to do this repair.
Good news is that it's not difficult to do.
TURN THE POWER OFF AT THE BREAKER BEFORE YOU PROCEED!
Otherwise you'd look like this...
Ready? OK!
All you need is;
1.) Phillips screwdriver
2.) 1/4" socket/nutdriver
3.) Ratchet if you don't have a nut driver
4.) 36 quart Igloo ice cooler (like what you'd take to the lake or the beach)
5.) Sturdy wire (smaller than a coat hanger, preferably)
6.) Flashlight
Did I mention TURN THE POWER OFF AT THE BREAKER BOX?
Now we're ready for surgery.
Open the oven door and look where the oven meets the wood. You'll see a couple of screws there... remove them. Now the oven is ready to pull.
Place your Igloo cooler under the oven. Slowly pull the oven from the cavity until you have it out and sitting on the cooler. (don't sweat it... the oven is light. maybe 75 pounds or so.)
Now that you have it out, open the oven door and remove the oven racks. Look inside (may need a flashlight) and locate the temp probe, there are 2 screws holding it in place. Remove those 2 screws and set them inside the oven cavity, you'll need them soon.
Now go to the back of the oven (slide it if necessary) and remove the back panel. (*Here's a tip... some of these GE units? All you have to do is remove one screw to access the temp probe, so look carefully... don't go nuts here. Sometimes the whole panel/panels DON'T have to come off)
You'll see the temp probe wires... they are 2 small white thermally insulated wires coming from the cavity to the wire harness in the back. Disconnect this harness and pull the old probe out from the front of the oven cavity.
OK... now to get the new probe installed... See that plastic thing on the end of the new probe? It's a pain to get through the cavity where you'll be plugging it into. It's best to have help. but it can be done alone (I've never had help, it's just harder)
Take the sturdy wire (from the tools list) and make a small hook at the end of it. Poke it through the hole that the old probe was stuck through. Now hook your new probe into the hook. Now go to the rear of the oven and gently (did I say gently?) pull it through to the back of the oven.
Now that you have it through, connect it to the harness. Now all you have to do is reinstall the rear panel/s and the oven. No biggy. Just take care not to scratch your wood trim... line it up before lifting and installing.
All in all about an hour's worth of work. I know it sounds like alot more but I could have done this in less time than it took me to type it.
Congrat's on your first major oven fix! Let us know how it turned out.
Mar 17, 2009 | GE Profile JTP18 Electric Single Oven
Oven short circuit
ok two prime places to look is the oven elements to see if they are burned in two second take the cover off the back of the range to see if the cord is burned after you turn the breaker off and let me know
Feb 11, 2008 | Ovens
Kenmore Stove (coils)
if the timer is on hit cancel or reset then hit clock and then use up and down arrows to set them also locate the serial plate and give me the mod num will be a buch of num like 106.48062890 around the bottom drawer on the body of the range or around the oven door if the eoc or clock isnt lit go turn the breaker off for 5sec and let me know
Dec 13, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Jenn-Air 27 in. Electric Single Wall Oven with Multi-Mode Convection Logo
32 people viewed this question
Top Jenn-Air Ovens Experts
 Fix Your Board
Fix Your Board
Dan Webster
Dan Webster
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
