Question about D-Link AirPlus DI-614+ Wireless Router
Hi, My connection keeps dropping going through
Hi, My connection keeps dropping going through the router but when direct connected it is fine. I have tried another cable with the same results and have also reset the router .....any ideas?
  • 3,866 Answers
This would be the router itself not agreeing with the computers ethernet card. I would have a look at firmware first and see if that does not put a stop to your issue, you mentioned you tried a diffrent cable and direct connection was fine then the router is the issue. I would try to firmwar eit first if that does not work I would try a diffrent router at this point.
thanks and please do be considerate and leave positive feedback and ratings.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on May 29, 2010
Router keeps dropping signal. I have to constantly unplug it and restart it. Reset button doesn't work. Yes, mi Internet connection is OK, I've checked it with my phones and by connecting the computer...
Hi ,
I got your issue, Since your router keeps dropping the connection , the best fix is to update the firmware on the router. Here is the link,
http://en-us-support.belkin.com/app/answers/detail/a_id/306/session/L3NpZC9DRXppQW1maw%3D%3D/kw/f5d8236/r_id/166/sno/1
You have 4 different firmware version, select the appropriate version for Eg: If your version number of the router is ver:3000 then download v 3xxx and update the firmware on the router , that it will fix your issue.
With Regards,
Prema.
Nov 18, 2010 | Belkin F5D8236-4 Router
Since getting a new Dell laptop and Linksys E1000 (also have HP desktop), my internet connection keeps dropping (no problems ever before)- sometimes I can stay online for 2-3 hours or it can go in 15...
we need to first figure out whether it the modem or the router which is dropping the connection.
Please connect one of your computer directly to the modem, by pass the router and access the internet. If the connection drops then its the modem which is dropping the connection and you need to contact your isp to check it.
If the internet works fine directly with the modem then its your router which is dropping the connection. To fix the router we can upgrade it firmware.
To upgrade the firmware please visit the link below;
http://homesupport.cisco.com/en-us/wireless/linksys/E1000
Note; If you are not comfortable upgrade the firmware then don’t do it. If not done properly then it can damage your router.
Rashish
Aug 16, 2010 | Linksys Wireless-G WRT54G Router
Wired connection randomly drops
Since the wireless works fine on your router, then it is possible that there is a problem either on your ethernet cable or on the port of the belkin router.
Try a different ethernet cable. (Ethernet cable is the one that is connected from your computer to the router.) If you don't have a spare cable, you can directly connect the computer to the modem, just to isolate the issue and determine if it is the cable or the computer itself.
If you have determined that the cable is working fine, then try a different port on the router.
I hope this helps!
Jul 24, 2010 | Belkin F5D7234-4 Router
The internet connection is fine (DSL AT&T).
1. You may have a an IP address conflict.
2. check the device connected to the router
all computer need to be connected at the same time.
3. Bring all the computers up one at a time and this should resolve the address conflict.
May 16, 2010 | Linksys WRT54GX4 WIRELESS 802.11G...
N1 Vision keeps losing internet connection from modem.
Hi Friend,
Please check it by updating the Firmware for your router from the below website
www.belkin.com/support
Regards,
Aysaam
Apr 13, 2010 | Belkin N1 Vision Router
Dkt-410 wireless router keeps dropping connection
Make sure that your computer works properly when connected directly to the modem without the router.
If that is working properly and not dropping the connection then the Internet service is working.
If it is dropping, then you will need to check the modem or call ISP.
If your computer works properly when connected directly to the modem then you will need to check the settings of the router. I think you will need to upgrade the Firmware of the router.
For this you will need to connect a computer to the router and open the set up page of the router. After upgrading the firmware, you will need to reset and reconfigure the router.
Click here
for more information about the routers and networks
Jan 31, 2010 | D-Link (DI-711) Router
Netgear range max keeps dropping signal
Is it cable or DSL? Cable should be fine but DSL gets slower everytime a second or third connection is added.
Jan 04, 2009 | NetGear RangeMax WPN824 Wireless Router...
Internet keeps dropping out using this router
One simple solution, can you try using the router on another ISP connection (at your friends' place possibly?) This will rule out the possiblility of your ISP fault saving you $65 straightaway...
Dec 17, 2008 | NetGear RangeMax WPN824 Wireless Router...
Internet connection
try to update the router's firmware to the latest one, if conection is still dropping try lowering the MTU size(by default its set to auto) to 1492, 1480, 1472, 1450 check which MTU size will make you connection stable.
Aug 05, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Router seems to drop connection frequently
What a static ip is, is the ip address that the router automatically assigns to other equipment. (computers, xbox, ect.) Find D-links customer support line for help.
Apr 11, 2008 | D-Link DIR-625 (790069292637) Wireless...
D-Link AirPlus DI-614+ Wireless Router Logo
161 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
