Question about Philips Magnavox 15MF400T 15 in. LCD Television
Need to know where to get ac power cord/adapter
  • 11,896 Answers
Try amazon.com or newegg.com or partstore.com
Posted on May 29, 2010
I need power cord and AC adapter for an Acer H236HL BID monitor
You may want to call Acer support for them to send you a new power cord and ac adapter. Acer technical support number is 1-800-816-2237
May 15, 2014 | Acer Office Equipment & Supplies
What class of cord is needed
The same classification of power cord used for a table lamp, can be used for the power cord of an AC adapter (Charger)
Gauge of wiring is 22 gauge.
Load of AC adapter is L-O-W
19 Volts (DC) at 4.74 Amperes,
http://www.mundocorp.com/shopexd.asp?id=17592
I'm going to post this same solution in the other problems you posted.
(Regarding AC adapter )
Post additional questions in a Comment.
(I know. I have been told FixYa is hard to navigate around in )
Regards,
joecoolvette
Apr 21, 2012 | MPC Computers TransPort T2300 Notebook
No power
1.Check the power outlet if it's working.
2.Try to also change the power cord with good one. If it works then the problem is the power cord.
3.Try to use a good know ac adapter to check if the only problem is the ac adapter. If it works then the problem is the ac adapter.
4.If could borrow a battery that has same specs and size of your battery , you may put that on your laptop and try if the laptop will power ON. If the laptop won't turn ON, meaning there is a system board problem, if it turns ON the only problem is the ac adapter.
Hope this helps.
Mar 16, 2011 | Toshiba Computers & Internet
My wii was working a few days ago then I tried to turn it on today and it will not come on. I tried plugging it in to different outlets but it still will not come on. No lights will come on either.
hello,
One of two common possible problems. Either 1) Your AC adapter needs to be reset or 2) Your AC Adapter is bad.
Most power issues with the Wii can be fixed by resetting the AC adapter. You can easily reset the AC adapter by following these steps:
Unplug the Wii AC adapter at both ends (from the back of the Wii system and from the wall outlet or power strip).
The AC adapter must remain unplugged at both ends for a full 2 minutes.
After you've waited 2 minutes, plug the AC adapter into the Wii system and directly into a wall outlet, not a surge protector or power strip. If the power light comes on and stays on, then it appears resetting the AC Adapter worked.
Try to find someone with a Wii.. not that hard everyone has one. See if they will let you use the power cord.
test the cord and if that doesn't you know its inside the Wii.
Then, their are fuses inside the console one of them my have blown.You need a special screw driver.
Hope this will help..
May 31, 2010 | Nintendo Wii Console
Where do I get lost cords for this monitor?
are you mention about the AC adapter or just power cords. For pwer cords is everywhere, but ac adapter you have to know the specification for the power input/output and size of plug since I can't tell the model on your description.
Mar 22, 2010 | Samsung SyncMaster 245BW Monitor
Laptop won't a hold charge when plugged in
Remove the Laptops Battery, Plug in AC Adapter... Is it able to Stay Powered On?? Slightly wiggle the Cord Near the plug end while plugged in... Does it still receive true power??? If So, Its Not Your AC Adapter Or Your DC Jack And You should Look into Replacing Your Laptops Battery...
If You Are Not Able To Power THe Laptop Using Just The AC Adapter When The Battery Is Removed, Then You First Need To Check/Test The AC Adapter using A Multimeter To See If You Have A Faulty Cord... If Cord Is Still Getting Correct Power Through To The Plug Tip .. Then You Will Need To Replace The DC Jack (the port where your AC Adapter Plug Plugs into on the laptop)
Nov 16, 2009 | Acer Aspire 3680 Laptop
Power Cord
Please let me know when I can get the power cord & AC adapter. I moved and lost them and cannot use my television. Thank you R. Werkheiser
Nov 03, 2008 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
Cord missing
http://www.18002526123.com/products.aspx?type=pa&view=104&p=34&sc=6
Apr 15, 2008 | kawasaki PVS1965 Portable DVD Player
Ac adapter for laptop
is that the cord, on which side of the adapter?
check out www.laptopparts.com
Feb 21, 2008 | Acer Aspire 3000 Notebook
Philips Magnavox 15MF400T 15 in. LCD Television Logo
116 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
