Question about Panasonic NN-S252WF Microwave Oven
My model is nn-s253wf, micowave stopped working, no power, checked circuit breaker, is ok ?, unplugged, then plugged back in, still no power ?
    Brigadier General:
  • 4,090 Answers
Inside the external case and usually to the right left ( from Front) in some models There is a 30 amp fuse ( This may vatry on oven output amperage) Replace that and you should be back in cook mode.
Removing the case you should remember to disconnect from the power plug.
Please rate my help++++Thanks for using FIXYA
Posted on May 29, 2010
When power went off and then came back on, screen on micro wave continually shows demo and I cannot set time
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes and try again.
If it still won't work, then you may have a bad membrane keypad / DP circuit.
If your model is NN-P295SF, the service is here.
Parts can be ordered from Encompass here.
Aug 19, 2011 | Panasonic NN-P295SF Microwave Oven
The machine just stopped. I hooked it up on a breaker and crossed over the fuse. It worked and I could set the time. However, when I put a cupof water in it and tried to run it, it threw the breaker. Is it...
In this case, it's the wiring in the wall and not the microwave. It sounds like you have over-loaded the electrical circuit. Each electrical circuit is designed to provide only a certain amount of power at any given time. The intent of the breaker or fuse (they serve the same purpose in different ways) is to keep you from using more power than the circuit was designed to carry. Otherwise you start could fires in the wall. Microwave ovens require a large amount of power run. If you plug the microwave into a circuit that already has a number of large power-draw appliances on it (like a fridge, dishwasher, toaster, oven, coffee maker, etc.), that's probably more than the circuit was designed for. Try plugging the microwave into another circuit (one that still worked when the breaker was thrown) as see if it works. If it does, the issue is with your circuit load. If it does the same thing to your other circuit, it may have a short in its wiring that causes it to draw more power than it is intended to. In which case, it's not something that can be diagnosed over the internet.
Sep 18, 2009 | Panasonic NN-S960WA Microwave Oven
Panasonic nn-s255 wont turn on
See if this describes what's happening:
  • Put in time, push start and unit runs for 2 seconds, relay clicks, unit goes off. Cook time on display goes off and clock time comes back. Bad upper interlock switch and charred connector
If so, see http://www.microwavedisplay.com/safety.txt , http://www.microwavedisplay.com/disassembly.txt and http://www.microwavedisplay.com/doorsw.txt
Otherwise, if the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
It may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
NOTE: The FixYa system is not currently notifying me when folks reply to my posts, so please contact me directly for more help.
William E. Miller
prototech@usa.net
Sep 08, 2009 | Panasonic NN-P295SF Microwave Oven
[Identical to earlier posting by stefeckstein]
Check for a circuit breaker on the back. If nothing, pull the plug and remove the case. Look for a blown fuse. If so, look for a shorted high voltage diode in the magnetron power supply or a shorted stirrer bearing located above or beside the cavity area where the microwaves enter. The stirrer is a metal fan-like device with a plastic bearing that often arcs internally. That shorts the microwaves out and blows a fuse. Replace the stirrer.
Aug 24, 2009 | Panasonic NN-SN657SMicrowave Oven
Has no power
If your microwave oven doesn't seem to work at all, check these: Fuses Usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven. When it blows, you need to have a qualified appliance repair technician replace it. Door switch If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work.
thanks
Mar 18, 2009 | Panasonic NN-SN657SMicrowave Oven
Stop working
IS IT POWER UP.
please rmoove the cover and check the fuse also.
is it work?????
nuwan
Jan 11, 2009 | Panasonic NN-S540BF Microwave Oven
No power to Panasonic NN-S252 microwave oven
follow the incoming mains lead into the microwave their is a small pcb with a fuse their check this first
Nov 14, 2008 | Panasonic NN-S254BF Microwave Oven
No cook mode
check control circuit, and check highvoltage section, and all the door lock switches, and sensors, chaeck over all circuit..
Oct 07, 2007 | Panasonic NN-S540BF Microwave Oven
Panasonic NN-S252WF Microwave Oven Logo
263 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
