Series 80 top loader ,wife decided to do wash ,now its not working , its making a grinding noise in back on bottom
  • 10,319 Answers
Your washer is a direct drive which means the transmission that drives the washer drum to agitate it directly mounted to it. Between the two items is a coupler. That coupler has shear pins which have sheared off causing the grinding noise. The coupler can be obtained a a very low price and SEARS may even stock it
Posted on May 29, 2010
Maytag washer mah9700 makes grinding noise and wont engage
take it its a top loader gear box suss if front loader check bearings
Mar 02, 2015 | Maytag Washing Machines
What is causing my Kenmore top washer to make a grinding noise before the rinse cycle?
Have you replaced the clutch or spin tube? There is a brake actuator that comes with the clutch kit and if this is broken it can make a very loud grinding or clacking sound.
Jun 25, 2014 | Kenmore Washing Machines
My Kenmore 80 series washer won't spin, and it just makes a loud gear grinding noise. What could this be, and how do I fix, in the simplest form please I'm chick... :)
rebecca it is probably the motor coupler. Move or slide ur machine over and if there is ruber filings under it then it is the coupler.
Apr 04, 2012 | Kenmore 24032\24036 Top Load Washer
Won't spin--just makes a grinding noise
Hi.
The grinding noise usually means that there are objects stuck in the drain pump filter.
with front loader the drain pump filter is often located behind an access door or a trim on the front side at the bottom. Open the door or remove the trim, then unscrew the cap. Be prepared to collect the water. Disconnect power before starting.
Top loaders have pump access from underneath or at the back.
Apr 26, 2011 | Washing Machines
My maytag legacy series top load washer sav405deww makes a horrible grinding noise. It also doesn't drain and seems to spin slowly when it decides to even spin. I've replaced the belt and the pulley wheel...
That grinding noise your hearing is most likely the center bearing in a maytag they are usally very easy to break and mainly because when they make maytags they dont put the right type of grease on the bearing itself which causes the machines not to last the 10 years that we all think they could. This repair is honestly not worth the amount of money that it would cost to repair I've seen technicians price this job out between 450 as a low and 600 as a high and considering you can buy a brand new top loader for 2-400 it really isnt worth the effort in trying to resurect the machine. Please also note maytags are notorious for the center bearings disintergrating because of poor factory assembly. Sorry about the bad news. when looking for a new washer if your going with a top loader stick to the whirlpool there easy to fix cheap for parts and last alot longer. Please remember to rank this opinion and if i can answer any further questions please message me back. Thanks again (p.s. on whirlpool make sure if you buy a new one you ask if the drive couple has metal around the shaft dont get the plastic one they let go in two years and then techs charge 180 bucks to repair a 6 dollar part)
Rick
Nov 30, 2010 | Maytag Legacy Series Top Load Washer
Kenmore series 80 top loader washing machine 11029852991. When turned on spin cycle, makes a loud grinding kind of noise. I believe unit may have been overloaded with three kingsized bedsheets &...
unless some thing inside the washer is broken i would say the drum bearings have started to wear out badly,,,my washer will easly take 3 king size bed sheets and covers,,,that not a lot realy,,,how old is your unit? and how many washes has it done,,,years old and 1000's of washes?
Jul 16, 2010 | Kenmore Washing Machines
Won't spin, makes clunking noise, drains fine
If it agitates fine , with normal noise , drains with lid closed , then the problem is probably the transmission .
Aug 02, 2009 | Kenmore 24032\24036 Top Load Washer
I have a series 80 top loader. It filled and
Screws holding the lid switch was broken. Had to replace lid switch.
Jun 11, 2009 | Kenmore 24902 Top Load Washer
Kenmore 80 series 110 washer making loud noise during final spin
Make sure all springs are still in their place tilt the machine back and look under it and you can see them. 2nd all legs must be level as well as the floor.
Dec 21, 2008 | Kenmore 24032\24036 Top Load Washer
80 Series top loader excessive vibration and noise on spin
check the screw feet, on the front corners, one may be not screwed down far enough to be 'tight' to the floor allowing a small movement that makes a lot of noise, halting under pressure suggests this is the case
May 26, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
47 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
