Question about Tag Heuer Aquaracer Quartz Chronograph CAF1112.BA0803
Resetting GMT hand
I am trying to reset the red hand on my watch to the "12" position. The manual seems to refer to this as the GMT hand that indicates a second time zone. I know how to reset the 1/10 second hand and the second hand but I can not seem to find anyway of resetting the red hand on my chronograph. I do not see anything in the manual that explains how to do this. Any assistance you can offer would be much appreciated.
  • pharmca Jun 15, 2008
    How do you use the 12 hour timer, 60 min timer and the 60 sec timer? They just sit there. The only timer that moves is the 1/10 timer.
I have CL1180 and had the same problem, pulling the winder out to position 2 (fully out) and using the buttons resets the second and 10th second hands and putting the winder in position1 and using the buttons does the same for the minute and hour hands. However finding position1 was tricky, only seems to work on the way out from fully home and not on the way back from pos 2.
Hope that helps.
Posted on May 20, 2008
2 Suggested Answers
SOURCE: Tag Heuer Aquaracer reset red hand
The red hand is not for GMT on the chronograph model (the one with push-buttons above and below the crown) but for chronograph (stopwatch) seconds. It can be adjusted with the crown pulled out into either the first or second setting position- I forget which, you'll have to try each one out- and then pushing one of the buttons to advance it to zero (again, I forget which button, you'll need to try them both out). The small seconds sub-dial at the 6'oclock position is for constant seconds, not chronograph seconds, and cannot be set, but only stopped at whatever position you want and then restarted again, by pulling the crown all the way out to the second position, and then pushing it back in again at the right moment.
Posted on Aug 26, 2008
How do I reset the millisecond hand used in the stop watch function on my nixon Ride SS watch?
Try this:
Resetting Chronograph Hands:
Note: Some Nixon watches come equipped with a "screw-down" crown; the crown must be unscrewed by turning it counterclockwise before it can be pulled out)
1. Pull the crown all the way out to position 2.
2. Push the crown in slightly to position 1.
3. Push top pusher button to advance the second hand to line up with the 12:00 position
4. Push the crown back in. (Make sure it is screwed in if it is a screw crown)
Jan 02, 2014 | Watches
Invicta 0223 i see the hour hand , min. hand and sec. hand... what is the other hand for?
It is for GMT.
What is GMT? GMT is an absolute time reference & doesn't change with the seasons
Jul 30, 2011 | Invicta Pro Diver Sport Collection GMT...
I have a chronograph watch with a white and a red
The trick is to pull out the stem 2 times and use the plugers to adjust each of the dials. Some watches have 3 dials and you have to pull out the crown 1 time or click and use the plungers or buttons to adjust the other dials.
Nov 18, 2009 | Watches
Changing the hand time only w/o changing the digital time
For Casio Waveceptor:
--- A
( ) Button Reference
--- B
Set in correct order:
1) Hand Home Position
2) Digital Time Set
1) Hand Home Position:
Press and hold A and B for 5 seconds, Press A to move Second Hand to 12: position: (if not there). Press B to enter Hour/Min set mode. Press A to move both hands to 12: position. Hold A to move hands fast, Press A again to stop hands. All 3 hands are now at 12' oclock.
Press B to exit Hand Home Position mode and enter Timekeeping Mode.
2) Digital Time Set: (hands will self set when done)
Press and hold B for 5 seconds to enter setting mode.
Press A to advance current item or scroll through choices. Press B to set item and advance to next item.
<Order of Items to Set>
GMT Differential -> Daylight Savings auto/on/off -> Seconds -> Hour -> Minutes -> Year -> Month -> Day -> Day of week language -> Auto receive -> (back to Timekeeping Mode).
<Setting each Item>
GMT Differential: Press A untill your time zone is reached (E=eastern, C=central, M=mountain, P=pacific). Press B to set (advances to next item).
Daylight Savings: Press A untill desired DST mode is reached: ("At" auto, "On" after spring change, "Of" after fall change) Press B to set (advances to next item).
Repeat to set: Seconds (resets to :00), Hour, Minutes, Year, Month, Day, Day of Week Language, and Auto Receive (on/off).
For each item, Press A to advance, and B to set.
Pressing B to set last item exits Setting Mode and enters Timekeeping Mode. Hands advance to current time.
Good luck,
Techjoel
May 10, 2009 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Klik-Radio-Controlled-Watch---Self-Setting-Time
The secret of setting this watch is to set the hands to 12 o'clock to start with, then it will find the correct time. geoff@mainsmail.com
Oct 26, 2008 | Raymond Weil Parsifal W1 watch
Crane and Viceroy ladies RC watch
Hi, Klik and Crane & Viceroy are excellent and robust watches, but due to the radio control batteries need to be changed more often than ordinary watches. Instructions for resetting the time on a Klik or Crane & Viceroy watch. With the watch face upwards and the buttons on the right assume the buttons to be; top button - "A", middle button "B" For setting the watch to GMT all hands need to point to 12 oclock exactly. To achieve this press Button A until the hands start spinning. Stop the spinning when the time reaches a couple of minutes before 12 oclock by repressing A. Inch the time forward by repressing Button A until all hands are at 12 oclock.(EXACTLY). Press Button B within 10 seconds and the time will advance 1 hour and stop. The radio signal will be picked up automatically and time will set itself in a few minutes. Notes: If you have radio dead spots avoid these when resetting the watch and do it away from magnetic or large metal objects. i.e. trays etc. If you are refitting a new battery and have a battery that isn't quite dead, do the advancement of time with the old battery and fit the new one near to 12 oclock to get the best life out of the new battery. If for any reason you want the watch to be in radio mode but read a time other than GMT ( no adjustment is needed for BST ), then instead of stopping the watch at 12 oclock stop it at the time in relation to 12 oclock. i.e. if you wanted the watch to read 30 minutes fast then stop the watch at 12.30. if you want any other info my email is; Charles@adept.fsbusiness.co.uk
Jul 15, 2008 | Watches
Klik r c watch.
problem solved.
regards.
Matt.
Apr 17, 2008 | Watches
THANK YOU THANK YOU THANK YOU!!! I had a similar issue and this saved me!!!!
Apr 14, 2008 | Tag Heuer Aquaracer Quartz Chronograph...
Chronograph hand not resetting to 12 o'clock
for my victorinox, the crown out one position and the reset button (lower chronograph button) changes the minute hand and the top (start/stop button) does the 10th's of a second...crown all the way out and top (start/stop button) does 30 second intervals for the minute counter.
Feb 23, 2007 | Kenneth Cole KC1232 Wrist Watch
Tag Heuer Aquaracer Quartz Chronograph CAF1112.BA0803 Logo
860 people viewed this question
Top Tag Heuer Watches Experts
Jimmy Accardi
Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
