Question about Dishwashers
Frigidaire Dishwasher PLD2855RFCO, will start working and then stops a few minutes later still showing washing light as well as clean & sanitized light, but now cleaning occurs, no soap dispensed, etc.
  • 12,061 Answers
Http://www.retrevo.com/support/Frigidaire-PLD2855RFC-Dishwashers-manual/id/1060bh943/t/2/
http://frigidaireservicetips.com/pdfs/486_5.pdf
Dishwasher Repair Guide: How To Fix a Dishwasher - ACME HOW TO.com
Please use these manuals top, is your user manual, below is your service and repair manual, below that is a DIY troubleshooting website. using these you should be able to isolate and remedy your issue. Please work through the troubleshooting procedures and you will soon be able to isolate and hopefully remedy your issue.
Posted on May 29, 2010
Cycle Runs Funny
Hi Bill, this is AP
Based on the symptoms you are describing on how your Frigidaire dishwasher, model PLD2850, is performing I would think that your dishwashers control board could be causing this to happen. Your dishwasher should wash without stopping for longer periods of time. Regrettably, this is not a simple DIY job. I would highly recommend reaching out to an expert technician to ensure the appropriate replacement part is ordered and is installed correctly to prevent future issues. I hope this information helps to some degree - thanks for your question, and please do not hesitate to reconnect.
If needed you may use the link below to locate a local authorized technician.
http://www.frigidaire.com/Owner-Center/Locate-Service--Parts/
Thanks,
Mar 19, 2014 | Frigidaire 24 in. PLD2850 Built-in...
Clean sanitized washing lights flashing
Hello Brian, thank you for your post!
I understand Clean, Sanitized and Washing feature lights are flashing. Let's try resetting your dishwasher. This can be done by either unplugging or flipping the household circuit breaker to the off position. It is important to wait approximately ten minutes and then turn your dishwasher on. Confirm that the door is securely closed and select a cycle. If resetting the power does not correct the issue, it could potentially mean a number of things: a potential wiring failure, door latch assembly, or control board. At this point, I would personally contact a professional to accurately diagnose your dishwasher to determine the root cause to reduce the risk of unnecessary parts.
Best of luck, Chris!
Dec 23, 2013 | Frigidaire 24 in. PLD2850 Built-in...
My Frigidaire dishwasher - most buttons don't work and clean and sanitized lights are flashing after cycle completes.
Hello Rich - From what you have described if only some cycles are working, then there seems to be a communication problem coming from the main control panel, I would suggest contacting a professional technician to diagnose the unit.
Sep 23, 2012 | Frigidaire Dishwashers
Brand new Matytag MDB7749AWB Dishwasher does not work correctly. As soon as the power was turned on, all three cycle indicator lights ('Wash', 'Dry', and 'Clean') came on and always...
Try putting the unit into a test mode. This my clear your issues otherwise call for service.
One of two ways to do this.
In standby (no lights) Press the combination of buttons:
hi temp wash > sanitize > hi temp wash > sanitize > hi temp wash
All lights will come on and the washer will run a test cycle anywhere from 5 to 10 minutes.
If that button comb doesn't work use:
heated dry > sanitize > heated dry > sanitize > heated dry
May 27, 2011 | Maytag Dishwasher
Frigidaire dishwasher had blinking lights then nothing
there is no fuse in the unit but u can unplug and plug into power 2 c if resets.
Aug 18, 2009 | Dishwashers
Kenmore Ultra Wash Dishwasher LIghts are blinking....
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Feb 11, 2008 | Kenmore 24 in. 17262 Built-in Dishwasher
Flashig lights, ticking sound, unfinished cycle
It sounds like it may be a heater problem or motor start problem. If you will post the complete model number from the decal, I may be able to look up something on it.
You should be able to get warranty service even without the proof of purchase as long as the manufacturing date proves it is within the warranty period. The date code is in the serial number.
If you will post it also I can look it up and tell you when it was built.
Thanks/Mike
Nov 09, 2007 | Frigidaire 24 in. FDB1250RE Built-in...
Dishwashers Logo
78 people viewed this question
Top Dishwashers Experts
