Question about Kenmore 64602 Electric Dryer
How to change the belt in the kenmore dryer model number 110.62822101. Dryer is not spinning so I would assume its the belt correct?
  • ashley_gound May 29, 2010
    but still i would like to know how to change the belt?! Please let me know.
    President:
  • 1,554 Answers
It is indeed a belt issue if the dryer blows hot air, which means the motor is running, but the drum does not turn. Otherwise, the thermal fuse (part number 3392519) mounted on the blower has failed. This thermal fuse is wired in series with the motor circuit and its failure results in the motor not running and the dryer not working at all.
Remove the dryer real panel to access the blower housing and check the continuity of the thermal fuse. Grab a volt-ohmmeter and set it to the R X 1 scale then disconnect one wire from the thermal fuse terminals then check the continuity of the thermal fuse. Replace the thermal fuse should it read open.
Posted on May 29, 2010
  • 2 more comments
  • Jahn27
    Jahn27 May 29, 2010
    Remove the dryer rear panel to access the blower housing and check the
  • Jahn27
    Jahn27 May 29, 2010
    Check the idler pulley (part number 691366) for twists and bends should the belt has come off. Replace it if that is the case.
    Pull the lint trap out then remove the two screws on the lint trap slot opening. Push the top panel forward to release the clips attaching it to the front panel. Lift the front of the top panel then tilt it to the rear of the dryer to access the screws attaching the front panel to the dryer cabinet. Disconnect the door switch wiring harness then pull the top of the front panel forward and then lift it up to release it from the bottom hooks and remove it from the cabinet.
    Wrap the belt around the drum with the ribs facing the drum then route it under the idler puller while pulling the idler pulley to the right then wrap the belt around the motor pulley like the one shown in the figure.
    Reinstall the front and the top panels by following the removal steps in reverse.
  • Jahn27
    Jahn27 May 29, 2010
    it under the idler pulley while pulling the idler pulley to the right
    figure. Release the pulley then reassemble the dryer.
    reverse.
  • Jahn27
    Jahn27 May 29, 2010
    Let us know should you need further advice and please reconsider the rating. This is a free service and an appropriate rating should do.
Kenmore 970C8709210 dryer won't tumble. When you press the start button it just sort of moans and shuts off. Any suggestions would be appreciated.
per your model no. you are in Canada. in USA if dryer hummmming
when you press start button and will shuts off in less then 20 seconds and drum turns by hand then we change motor. one more thing if dryer works on 220/240 v ac and if power cord is not install correctly or wall plug is not wired correctly, mean motor getting 220 v ac not 120 v ac then it will do the same thing. hope this will help you.
May 02, 2017 | Kenmore Dryers
How do u put a kenmore dryer belt on do u have a diagram?
all kenmore dryers much the same procedure to change the belt
the casing has to be opened
some dissa sembly required
link as an example of how its done on any dryer unit
copy and paste link into your search engine
https://www.youtube.com/watch?v=x6zFGUpfC18
or
https://www.searspartsdirect.com/repair-guide/dryer/how-to-replace-a-dryer-drive-belt.html
May 29, 2016 | Kenmore Dryers
Dryer will not spin. Its a propane dryer and the heat is fine...just wont spin. I assume there is a belt somewhere?
Belt is on the inside. It wraps around the motor pulley and the drum. Opening the dryer is required. Make sure unit is unpluged 1st. Very easy repair. Belt can be ordered online and shipped to you. Model and serial number will be required. Probably about a $15 - $30 repair. Should take about 30 -45 minutes on the long side. Instruction to open your dryer should be here: http://www.partselect.com/dryer+open-cabinet+repair.htm
Feb 05, 2011 | KitchenAid Dryers
I have a Kenmore Residential Dryer Model # 97273100 (11097273100?). The dryer starts but does not spin. I assume it is the belt, but how do I access it?
I smell gas and can't find where the door panel is on my Kenmore You : Model:97273100 serial: MB3313988
Jan 16, 2011 | Dryers
Kenmore series 80 dryer . Drum does not spin, even when empty.
Good day,
If runs and heats, then the most probable cause is a broken belt.
Not hard to change. Below is a tutorial on how.
The Kenmore line is manufactured by Whirlpool.
http://www.wikihow.com/Replace-a-Dryer-Belt-on-Whirlpool-Models
Thank you for using FixYa
Dec 19, 2009 | Kenmore Dryers
Need diagram for belt and idler on dryer
That model number is not correct. Look here for where it's located. http://www.appliancepartspros.com/modelnumber_locator.aspx
Aug 08, 2009 | Kenmore Dryers
Dryer will not start, just humms
sounds like the drum belt maybe broken or worn out.
May 25, 2009 | Kenmore 98702 Stacked Washer/Dryer
I need Directions how to replace the belt.
broken belt......simple fix.......remove lint filter from top 2 screws remove.........insert screwdriver between top & front push down to pop top......1 screw on each side holding front on at top remove them....front will then pick up off the 2 remaining clips at the front bottom.....spin door around to the side belt should be laying in the bottom of the dryer or around the tub but broken.......hope this helps......
May 04, 2009 | Dryers
Can't get replacement parts back on Kenmore 60 series dryer.
The belt has groves, right? Make sure the groves go over the motor pulley from the right. The idler pulley is spring loaded. Place the belt around the idling pulley with the smooth side of the belt on the pulley. This should work.
Dec 24, 2008 | Kenmore 62602 Electric Dryer
Kenmore 64602 Electric Dryer Logo
388 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
