Question about Weber Genesis E-310 Gas Grill
Wont start just bought it it clicks but does not heat
  • 54 Answers
Ensure that your hose, regulator, and control assembly are all clear of debris and that the orifice is not plugged.
Posted on May 30, 2010
What happened to the heat in my 2007 Pontiac Grand Prix? It just stopped working.
Sounds like the heater control valve is stuck in the closed position.
Oct 19, 2014 | 2007 Pontiac Grand Prix
Bought a new battery it wont even turn over to start
If you get a clicking sound, that means the solenoid is working. Check all connections for corrosion and clean if necessary. Did you check the engine to frame ground wire? If all connections are good and solenoid clicks then the starter is more than likely bad. Did you do a load test on the new battery. It is possible to get a battery that is bad due to excess lead dropping into the battery case when being made.
May 03, 2014 | Garden
Piaggio diesis 100 automatic wont start at all
clicks means a starter solenoid has gone bad... wont start is a whole other issue... possibly a CDI issue
Dec 28, 2013 | Piaggio Motorcycles
Brand new dryer wont heat
depending on which model roper dryer it can be a thermal fuse,high-limit thermostat,cycling switch,burned off wire in control panel,check each side of the heating element to ground and find 125 v.a.c. then on the side of the element that has low or no voltage on it to ground start at the element and back track the components leading to the dead leg on the element till you find 125 vac to ground and replace or repair component or wire,then you should get 240 to 250vac across heating element terminals
Feb 17, 2012 | Roper Dryers
Wont heat
do you hear 3 clicks when you start it up,these clicks are the gas valves opening to supply the unit with gas for operation,if no clicks are heard it can be the thermal fuse is open,if only 1 or 2 clicks check continuity of the main and secondary gas valve coils as they can open up or get weak from heat during operation,usually just replace both coils on the gas valve as they are inexpensive one has 3 connections and the other has only 2 connections,but first bypass the thermal fuse with a jumper wire (for testing only) then replace the gas valve coils next,unplug both coil connections then remove 2 screws holding the valves to the valve and replace and reverse dis-assembly procedure
Feb 07, 2012 | Kenmore Dryers
Chevorlet silverado 1995 4x4 1500 problem: when starting it just clicks and then sometimes it will start. bought new battery,still wont start, bought new starter and everything worked fine for just over a...
sounds like a wiring problem. Have it diagnosed on a computer at a local dealership or someone you know that wont charge to see whats wrong! Then go from there. Are u getting a check engine light?
May 13, 2010 | 1995-1997 Chevy 1500 Truck Ignition...
1999 buick lesabre wont start
my 1999 buick lasaber wont take a charge
Dec 24, 2008 | 1999 Buick Park Avenue
Model 11060052991 kenmore elite dryer
For heat issue I had replaced the heat relay switch a year ago and that worked. For the start button holding issue I replaced the motor relay switch and the dryer is fine again.
Nov 25, 2007 | Kenmore 63942 Dryer
Weber Genesis E-310 Gas Grill Logo
90 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
