Question about Whirlpool AWM8000 Front Load Washer
The machine is "Stalling" in the cycle and stops washing. Needs to be clicked over one click to get it going again. Sometimes doesn't pump out either
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. From what you have described the issue can be due to the water not draining and/or the Timer has gone bad & needs to be replaced. Usually water not draining at all is due to the drain line that is clogged and/ or because of kinked drain hoses that’s attached to the Drain Pump. . If it's in the pump, you need to remove the hoses from the pump and clean them out. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on May 29, 2010
Kenmore 70 series wont stop filling with water to start the wash cycle
Lid off, right side circular pressure switch with black hose attached. Remove end of hose, blow down to make sure not blocked and blow into switch where hose attaches. Should click twice. If doesn't click, faulty pressure switch (replace)
May 19, 2012 | Washing Machines
WASHING MACHINE stopped in mid-cycle
if it stops at the drain and spin cycle check the lid switch,open the lid,set the washer to spin cycle and pull out the timer knob,stick a screw driver into the hole where the strike from the lid goes into and push down,if you don't hear a clicking sound when you push down on the switch in the hole then you have a bad lid switch but if your machine does run sometime it sounds like the switch will work if you push down on it,could be cracked where the screws go into it.
http://www.youtube.com/watch?v=V5aW9WkTFhE watch video on how to replace it.if you do hear a clicking sound when you open and close the lid or push down with the screw driver you could have a bad timer but check the lid switch first
Mar 17, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Starts water cycle then stops
Probably needs new carbon brushes in motor.
Dec 17, 2011 | Bosch Washing Machines
Will fill with water but wash cycle does not start rinse &spin worksm
Needs looking at, take the top of the unit off, switch on and manually turn to the wash/spin cycle and listen for a click, if theres no click then the circuit panel needs replacing, if there is a click have another look (switch off and isolate machine) and make sure the small springs that hold the pegs near the cogs are there, sometimes they just break off being so fragile.
Oct 02, 2010 | Frigidaire FWS833A Top Load Washer
Kenmore series 80, model 110-25842400, and serial number CR3353550 washing machine. I hadn't heard the machine work before the problem, and my wife said it was not working right (would fill with water and...
thabks for being through... i wish everyone was like you.. i get alot of Its not working? i hate that what does that mean... wish they were like you.. please check the harness on the motor while it is spinning.. i had that problem before... also it could be the speed selector switch.. sometimes it will get caught running 2 speeds at once and it will click like that...
checks these things and let me know if you need more assistance.... you sound like a tech.. wanna job? lol
Apr 12, 2010 | Kenmore 24032\24036 Top Load Washer
Hoover 750 l top loading .......wont spin proporly
check the lid switch its not working or its already cracked open
Dec 15, 2009 | Washing Machines
Indesit programmer has a mind of its own
I have LG Washing Machine WF-S6607 when I START after 5 Second it will be stop and alarm to come up on Rinse MODE. what I do?
Oct 17, 2009 | Washing Machines
Over Flowing
OK, you have two issues here. you will need a new Water level pressure switch and, the timer will need to be replaced as well.
Jun 22, 2009 | GE WJSR2070B Top Load Washer
Indesit W123 s UK water overflows from the detergent draw
My machine clicked round, although I did not have the water overflow. I managed to unlock the pump filter, on the front of the machine under the lower panel. This was fiddly. I removed a coin. The machine worked again, but two cycles later starting clicking round the timer. I called an engineer - it worked when he was here, he checked the element and pump and said it was OK. When he had gone, it clicked round the timer again! He came again, and once again it worked perfectly when he was here. Eventually I checked the pump filter again, and removed another two coins. At the moment - it is working!
Oct 11, 2006 | Indesit W 123 Front Load Washer
Whirlpool AWM8000 Front Load Washer Logo
21 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
