Question about Sta Rite Sta - Rite Dyna - Glas Pool Pump - 2 Hp
I had to replace my pump motor and can't get my pump to quit leaking at the joint. I am trying RTV Sealer as we speak.
  • 64 Answers
Did you change the seals? Whenever pump motors are replaced, the ceramic shaft (mechanical) seal should be replaced. Its also a good idea to replace the seal plate and diffuser seals.
Posted on May 29, 2010
I need to replace my water pump in my Toyota Avalon. I need to know what parts I need and if I need to replace the timing chain as well
Hi Zachary,here's a link on replacing your water pump,your engine is a 3.5,the engine number is 2GR-FE,it also says you will need 2 special tools,if you buy the water pump from Autozone,they will loan you the tools,you will have to leave them a deposit,you get your money back when you return them,also you don't need to put a new timing belt on,as it says. Repair Guides Water Pump Removal Installation AutoZone com Here'a link to a new water pump. Repair Guides Water Pump Removal Installation AutoZone com Here's a link to some gasket sealer. AGS Thermostat and water pump RTV silicone gasket sealer TG 1A...
Sep 26, 2016 | 2006 Toyota Avalon
I read the answer for the 1955cadillac oil pan gasket. This gasket is made up of 4 pieces. I'm really concerned about the edges sealing so there is no leaks, any tips for this type of gasket?
Pressed steel cover gaskets of all sorts produce sealing problems in abundance, especially when cork gaskets are used. Multi-piece gaskets are used where the designer has saved weight and cost by such innovations as shortening the crankcase and deepening the oil pan and at the same time increased the chances of oil leaks.
The ends of multi-piece gaskets can be sealed with a dab of a high quality rtv silicone sealer or an adhesive sealer such as one of the special Bostik range which has been recommended by so many vehicle manufacturers.
Beware of using an excessive amount of sealer because as much squeezes inwards as outwards and the possibility of future problems are increased.
Cork gaskets should be fitted dry to avoid the problem of a sealer lubricating the surface and the gasket creeping out under clamping force instead of being compressed. Lightweight steel covers and pans always distort around the bolt holes regardless of how gently the bolts are tightened and sometimes even a dry cork gasket will be pushed from the joint and ruined.
The necessary blobs of sealer can be the death of the gasket so it is best to tighten in stages - the first stage is to merely pull the bolts down evenly so the gasket is nipped but not compressed. After about an hour the rtv will have developed a skin but will not have cured so the bolts need another half-turn and then leave the job until the cure has completed before applying the torque wrench or vast experience and finishing the job.
When the steel of a cover is particularly lightweight I find great benefit in gluing the gasket to the steel with a latex/solvent contact adhesive such as Evo-stik.
Feb 15, 2015 | Intro-Tech Automotive 1955 Cadillac...
How to replace Thermostat on 2006 Town & Country Van ?
drain coolant system half way until coolant below thermostat.to locate thermostat follow upper radiator hose to engine.just remove both thermostat housing two bolts then clean all traces of old gasket material. be sure to have new thermostat gasket and gasket sealer on hand.make sure both thermostat housing and engine block clean dont have any traces of old gasket material if so you will have coolant leak.but besure to put gasket sealer both sides thermostat gasket just need thin layer RTV silicone.you can buy can of gasket remove to help remove old gasket material. try not to damage thermostat housing surface or engine surface with scraper deep scratches cuts in either surfaces will cause coolant leak be careful.
Dec 28, 2012 | Chrysler Cars & Trucks
Replace water pump torrent
drain coolant until below water pump level. loosen water pump pulley bolts.then remove drive belt by rotating belt tensioner.remove drive belt from the right of idler pulley.carefully release the drive belt tensioner spring tension.then remove water pump pulley bolts and pulley.remove water pump bolts and water pump pay attention to the position old water pump when removing water pump so you can line up new water pump holes to the engine. be sure clean engine water pump mounting surface use gasket remover dont scratch engine surface when cleaning removing old gasket material. take new water pump gasket get it mounting holes line up with new water pump mounting holes.when done getting engine water pump surface clean.water pump gasket paper you need to put thin layer of sealer on both sides of water pump gasket use RTV SILICONE.LET SET UP 10 MINUTES. PUT GASKET ON WATER PUMP BUT FIRST MAKE SURE LINE UP GASKET HOLES WITH WATER PUMP HOLES BEFORE PUTTING ON THE GASKET SEALER.when gasket sealer set up 10 minutes then install new water pump with gasket to the engine torque to 89 inch lbs.or 10 NM that is about 7 ft lbs torque.you should be able turn water pump by hand if you cant turn water pump by hand got too tight damage water pump shaft bearing.when all done wait for THREE HOURS. before adding coolant i let RTV CURE SOME. torque water pump pulley bolts 18 ft lbs.
Dec 28, 2012 | 2006 Pontiac Torrent
I am leaking trans fluid. What are the areas on this 3.1 auto where fluid could be lost? I assume that the pan gasket is one? Also, what is the transaxle cooler line? Could I be losing the fluid from...
The easiest way to check is put a piece of cardboard under your vehicle when it is parked in one spot.Then look for where the drip is coming from.Fluild leaks can be tricky because when you drive,the wind blows the fluid back towards the rear of the car.The fluid lines run to your radiator for cooling when you are driving your car.They can leak at either the radiator or at the transmission if so,take them loose and wrap them with teflon tape then tighten back down.. Also your pan gasket can leak which is a simple fix with some rtv sealer and a new gasket.Or you can have either a tailshaft seal leak or a front pump seal leak.The tailshaft seal is in the rear of the ****** where it meets the drivetrain.The front seal is up by the engine and the ****** would have to come out to replace that.Depending on the leak,you might try so transmission sealer additive just to see if it stops.
Aug 17, 2011 | 1996 Chevrolet Lumina Mini
This question is about my 1990 Toyota Cressida. I'm in the process of replacing the valve cover gaskets because of an oil leak. My question is....how or is it possible to remove the center piece between...
I CAN tell you that just cleaning out the plug wells is a good idea so no crud gets in the cylinders when plug is pulled. The center piece you speak of is not understood. As for the gasket sealer, yes, it's a good idea to use Black RTV on the head surface after cleaning and to stick the gasket to the valve cover.
Jun 06, 2017 | 1989 Toyota Cressida
Sparkplugs under oil on 2006 suzuki
old school-- new school- sealant is sealant no 2 has advanced to a rtv silicone sealant the copper was probably the permatex -copper hi temp spray but u can still find and use no 2 there is no special just make sure everything is clean and dry and when using sealant let set up a bit and put in place
Jul 27, 2010 | 2006 Suzuki Forenza
Changed thermostate in 1994 chevrolet truck k1500 cant get it to stop leaking
did you replace the gasket also?maybe the outlet is cracked. try a new gasket and silicone sealer.
Dec 13, 2009 | 1994 Chevrolet K1500
We replaced the water pump on a 1993 buick skylark and the radiater outlet pipe that goes into the water pump housing we are having trouble getting it to seal up and not leak does anyone know if ther is...
Yes I think there is an O ring . But in any case try this, coat the outside of the pipe with RTV/Silicone gasket sealer, put it back in and let it set up for an hour or soo, this will seal the pipe.
Dec 02, 2008 | 1993 Buick Skylark
Sta Rite Sta - Rite Dyna - Glas Pool Pump - 2 Hp Logo
269 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
john h
steve morris
steve morris
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
