My TV does not turn on I have a Mitszubushi 60 Inch
  • 549 Answers
The first thing to do is check the outlet that it is plugged into.
Do you have a gfci outlet that may have tripped?
Sometimes the whole circuit that the tv happens to be plugged into may have tripped at the electric panel.
Chek for a blown fuse or tripped circuit breaker.
If that is ok, check inside the tv for a blown fuse close to where the power cord is attached.
If still no power, then it will take a checking of the power supply/power circuit board, which may be something a service person should check into.
Posted on Apr 08, 2008
Vizio intermittent backlight
You have to check the power supply of the tv. Normally led TVs power suppy is integrated with the led driver. If the led driver is faulty then this type of problems can occur.
If you wish to get some more details then check the following link.
http://electro-medical.blogspot.com/
Jul 21, 2016 | Vizio E601I-A3 60-inch Class Razor LED...
How do I fix my Samsung 40 LED TV that has sound but no picture?
Samsung 60-Inch 1080p 120Hz Slim Smart LED HDTV ...
? 10:42
www.youtube.com/watch?v=hcVhHU322Gk
May 18, 2015 - Uploaded by Thomas M. Landry
samsung un60h6350 60-inch 1080p 120hz smart led tv,samsung... 120hz smart hdtv,slim led tv,65 inch smart tv deals,samsung 40 led 1080p 120hz ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight Test ...
Oct 15, 2015 | Samsung 40" 1080p 120Hz Slim LED Smart TV...
60 inch samsung led tv turns off and on while watching
it may caused by the dust.
open up the led tv and clean it using the blower.
Jul 29, 2015 | Samsung UN60ES8000 60 inch 240hz 3D Slim...
Sony wega 55 inch tv turns on fine but after one minute tv shuts itself off and comes back on 40 seconds later by itself and this cycle continues - none of the error code lights blink
This kind of problem occurs when lamp becomes weak that means near to end of working life hours but still not dead nor broken.
Replacement of lamp in tv will solve your problem, lamp replacement procedure is easy and would be written in user manual.
Thanks.
Oct 30, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
My 60 inch tv is not turning on do i need it
Was this tv made between 1995 and 1997? The problem is in the large signal board. It has the flyback on it. You will need to find a servicer.
Sep 16, 2009 | Philips Magnavox 9P6034C 60" Rear...
My sony wega 60 inch tv will not turn on. The
I bought a new blub for it and the light still goes green then red.Anybody know?? mg
Sep 02, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
I have a philips 60 inch tv with on picture and sound
There are two common problems with Projection TV sets. Problem #1) Convergence Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pngSOLUTION http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jun 28, 2009 | Philips 60P8342 60" Rear Projection...
Multi color stripes on 60 inch sony wega, no picture
it sounds like the projection unit went out. if it is still under waranty then i would take back and get it fixed for free. if anything i would contact sony and tell them what is wrong with the tv.
Dec 19, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Open Questions:
Magnavox MWR-20V6 DVD/VCR recorder fails to record one time but not the next This problem just recently started as the unit was functioning perfectly up to now. And I've kept the unit in excellent condition and free of any dust. What's happening is this. When the timer is set to record a program, the unit will turn on and begin to record. But after about 9-10 seconds of recording, it will fail and you'll see an error message saying you cannot record on this disk. FYI, this happens too when not using the timer and just pressing record. And in both cases, it's been hit or miss, so one time it successfully records no problem and the next time no. So you don't know when and if it's going to happen, which is really frustrating! What's even weirder is that once it failed, you can wait a few seconds and try recording again with possible success. So if it failed at first, it may work the next time, but who knows if it'll work after this. And even if it does work the next time, after that, it's again hit or miss. This recording problem happens even when dubbing. So it doesn't matter if you're copying from VHS to DVD, using the time, or just hitting DVD record, the same recording error happens. And as I said above, it may work the next time but who knows? And even if it worked then, anytime after that is also very hit or miss. Nobody else touches the unit and it's never been moved or banged. So again, I've kept it in very good shape and working order. No problems whatsoever on the VCR side. And I most often use DVD-R discs rather than RWs, but even with RWs, the same problem can happen. Lastly, finalizing has also become more hit or miss now when it used to be very consistent. So I don't even know when or if it'll be successful in finalizing a discs. Most times, it does work, but a couple of times, it hasn't. Lastly, a weird thing with discs that failed to finalize is this. A few of them were finally able to be successfully finalized after just sitting around for about a month of not being able to be finalized. So for whatever reason, a few of those discs that wouldn't repeatedly finalize suddenly worked. The rest of those that were not successful still cannot be finalized. And I've kept all these discs in plastic sleeves or in a disc case.
Jan 17, 2018 | Magnavox Televison & Video
Televison & Video Logo
53 people viewed this question
Top Televison & Video Experts
Electro Med Services...
