Question about Canon PIXMA MP240 All-In-One InkJet Printer
Only the yellow alarm button is lit and the printer wont respond.
No response from printer when any button is pressed. I tried unplugging everything and re-plugging, nothing
    Sergeant:
  • 284 Answers
Most probably is Logic Board problem. If under warranty period, pls send to get replacement.
Posted on May 29, 2010
Lexmark X2350 All-in-one does not respond to anything. When i plug it into an outlet the power button lights up and stays lit for 10 seconds then blinks once and stays lit for another 10 seconds and blinks...
Your problem lays in to one of the output capcitors in the circuit board. To have it repaired would cost more than purchasing a replacement printer these days.
I would just purchase a new one instead
Jan 28, 2011 | Lexmark X2350 All-In-One InkJet Printer
Alarm is orange, and is pulling a E3
Take the cartridges out and left the lid up, unplug it, plug it back in with finger on the power button and tap the stop/reset button twice. Put the cartridges in, press the color start, a test page should print. unplug it again, plug it back in .
or
Try an EEPROM reset:
Service Mode
This printer has a service mode for service-related settings and for performing test prints. The operator panel buttons are used to enter the desired service mode.
Service Mode Operations
1) With the printer powered off, hold down the resume button and press the power button.
2) While holding down the power button, release the resume button and press the resume button twice in succession. Now release the power button. The
indicator will blink in green and remain lit in green.
3) Select one of the following service mode functions by pressing the resume button the specified number of times.
Press Resume Indicator Functions
Zero times Green Power off the printer
1 time Orange Service test print
2 times Green EEPROM information print
3 times Orange EEPROM initialization
4 times Green Waste ink counter setting
5 times Orange Destination settings
6 times Green Print head deep cleaning
7 times Green CD-R test print
8 times Orange CD-R print position correction (horizontal)
9 times Green CD-R print position correction (vertical)
4) Execute the function you have selected (except for model setting) by pressing the power button. The printer will switch itself off after performing the function.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 23, 2010 | Canon PIXMA MP240 All-In-One InkJet...
AUDIOVOX CAR APS787N ADVANCED REMOTE START DOES NOT FUNCTION EVEN AFTER EVERYTHING IS CONNECTED PROPERLY.
If everthing is properly connected and the system does function,you may need to program the remotes. But first,let's check a couple of things. Turn the ignition on and press and release the push button LED three times and check for a response.The alarm should chirp one time. If the alarm chirps one time, press and release the lock button on the remote. If the alarm responds with a long chirp, press and release the push button LED one time,should hear two chirps; press and release the unlock button on the remote. The alarm should respond with a long chirp. Press and release the push button LED one time, you should hear three chirps, press and release the green button. You should hear a long chirp from the alarm. Press and release the push button LED one time, you should hear four chirps from the alarm; press and release the (1)button on the remote. continue the process for button(2).Now, if you do not hear the one chirp in the beginning, the system is not responding. Check your power and ground connections. If the system does chirp but, no response from the remote, check your antenna cable for proper connection at the module and the antenna. If the connections are fine, check the remote. Also,it is possible that there is major RF interference where you are located. If all of the above check out, try moving the vehicle to a different location and test.
Oct 13, 2010 | APS787N Advanced Remote StartKeyless Entry...
Getting a 5B00 error on a MX310. We just replaced the ink absorber
error 5b00
reset waste absorber counter. here is how to reset.
1) With the printer2.gif powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button 4 times.
If this does not work you need to call canon.
Good Luck
Nov 12, 2009 | Canon PIXMA MX310 All-In-One Printer
ERROR CODE 6500
Hi there
The 6500 error code is a logic board error code. The PCI Bus error is detected by the ASCI. Sounds like it needs new logic board. but i suggest you to first of all you can try to reset your printer -
1. Turn the printer off with the Power button (if available).
2. Disconnect the data cable from the printer.
3. Unplug the printer's power cord for approximately 10 minutes, and then plug it back in.
4. Turn the printer back on. If this works you're done, if not try the next step.
1. After confirming that the printer is powered on, open the paper output tray.
2. Open the top cover and wait until the print head moves to the center.
3. Open the inner cover and check that ink tanks are properly seated.
4. Properly seated
5. Press down on each ink tank until a click is heard.
6. Close the inner cover and top cover
if reset method not works for you then you go for the new logic board replacement .............
Good Luck!!
Thanks
Apr 07, 2009 | Canon MP830 All-In-One Printer
Power and alarm lamp lit error code e 3 flashes indicating a paper jam but no paper is jammed power flashing green 3 times then stays green and alarm lamp flashers orange three time then gos off over and...
Try a hard reset first - Unplug printer from AC power source for a minutes and from PC. After a minute, reconnect everything and power up and see if it works..
Oct 12, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Canon Pixma MP140 alarmlight on, nothing else lit, no response.
Press & hold STOP/RESET button for 10 sec. Then restart.I think it fix your problem.
Oct 03, 2008 | Canon MP140 PHOTO AIO All-In-One InkJet...
Printer will not respond
Canon S330 Turn off printer
Hold down Resume button and press Power button.
Keep holding down Power button and let Resume button go.
Press Resume button 2 times then let BOTH buttons go.
Green lights will flash and then stop blinking.
When green lights are solid, press the Resume button 4 times.
Press the Power button and the printer should turn off, if not, press the Power button once more.
Your printer should respond as normal
Jul 22, 2008 | Canon S 330 InkJet Printer
Canon PIXMA MP240 All-In-One InkJet Printer Logo
235 people viewed this question
old marine
old marine
