Question about RCA RT2280 System
Remote will not turn the unit on. - RCA RT2280 System
  • jagbear543 May 29, 2010
    I don't know yet.
    President:
  • 1,070 Answers
Hello Friend, Try to Switch on Directly without Remote[To confirm unit is still properly Working]. Go to this Link.Check page 11 and 14.for Remote Instruction.read carefully the guide to get Complete Instruction of your Device. Still have Problem.....
  • Check your Battery of your Remote
  • Check your Remote Sensor Light as damaged
  • Check Remote Circuit
OR If any Button/other Buttons are Properly Working .Open your Remote Cover carefully.And smoothly clean its typing pad with clean Cloth.Then take a Carbon Pencil and simply scratch typing pad's buttons especially Not working Buttons.Close Remote Cover.You are Done. Note:Only do if you are Confident to do yourself without making any damage...Thanks for Contacting FixYa...
Posted on May 29, 2010
  • 1 more comment
    Thanks, The unit will not turn on from the unit itself. It doesn't seem to be the remote.
    The unit will not turn on from the base . the light on the remote does come on.
  • shafi
    shafi May 29, 2010
    Try-Unplug the power cord and leave it unplugged for 30 minutes or more. Then Properly plug in and power it up, again...also follow guide's Instruction well...
    Still have Problem it needs to manual repair/ It involves testing to make sure which transistors or module are gone and then replacing the critical parts[You may need assistance of qualified technician].
    Hope you got a Conclusion....Keep Using...
I need code(s) for my DVD Video, Model #: NB093 remote control to program my Philips DVD Player/VCR, Model #: DVP3345V/17. Can you please help me? I would greatly appreciate it. Here is a picture of it.
http://remotecodelist.com/remotes/magnavox/magnavox.htm lists the code for your device as possibly being 1000, 1001, 1002, 1003, 1004, or 1005. Of course, you also have the option of using the remote controller's "Code Search" button. 25300580-iv4burzhkawezvl2jbah1xae-2-0.jpg With Codes:
Turn on the DVD/VCR unit directly. Continue to depress the remote controller's "Code Search" button for about ten seconds, release, & the light on the remote controller should stay on. Enter the four-digit code (1000, 1001, 1002, 1003, 1004, or 1005) for the DVD/VCR unit. The remote controller's light should go off. Press the remote controller's power button, & when the DVD/VCR unit turns off, then you will know that the remote controller has been correctly programmed.
Without Codes:
With the DVD/VCR unit on, continue to depress the remote controller's "Code Search" button for about ten seconds, release, & the light on the remote controller should stay on. Continue to tap the remote controller's UP or DOWN channel button ONLY UNTIL the DVD/VCR unit responds. Then, press the power button on the remote controller once the channel has changed. If the DVD/VCR unit shuts off, then press the power button again to turn it back on. If the DVD/VCR unit turns on, then the remote controller has been correctly programmed. Otherwise, repeat this whole process until the remote controller is correctly programmed.
Nov 29, 2014 | Televison & Video
How to hard reset unit without remote
  • Reset the unit to factory default settings as follows:
  1. Press [POWER] on the unit to turn off the unit.
  2. Press and hold [FAST FORWARD] and press [POWER] and [OPEN/CLOSE] on the unit at the same time for more than 5 seconds until "PLEASE WAIT" is displayed on the unit.
  3. The power is turned on and then turned off automatically.
http://service.us.panasonic.com/OPERMANPDF/SCBT200.PDF
Feb 18, 2014 | Panasonic Audio Players & Recorders
New Fujitsu remote AR-DJ8 will turn unit on but will not turn unit off
Try new batteries before you buy or repair anything.
Feb 10, 2014 | Heating & Cooling
The buttons on my air conditioner quit working. It will still turn on and off. It is now set to fan. Will a universal remote work with it? I don't want to spend $75 on a remote(replacement remote) that...
I'm not sure there is a universal remote available for AC units. There may be, I just have not seen one. However, you can still operate the unit without the remote, if you do the following. I'm assuming you have changed the batteries in the remote and they were installed properly (i.e. Facing the right direction) and it still doesn't work or you lost the remote.
Turn the unit OFF and unplug it for 15 minutes. Once the time has elapsed, plug the unit back in and turn the ON/OFF switch to ON. The unit should have reverted back to the original factory setup settings. Which should now allow you to operate the unit without the remote, because the controls on the unit should now be activated.
I hope this helped you and thanks for choosing FixYa.
Aug 07, 2011 | Frigidaire FAM156R1A Wall/Window Air...
The unit is a Kelvinator Air Con unit - Model #KSR25F-01. The unit will turn on manually but not from the remote. The remote has new batteries, but will not start the unit. The only button that the unit...
take the remote and put it in front of your cell phone.turn on the camera of your phone and push the buttons of the remote.if you see a light in your phone the remote is ok and then the eye of the pc board(is a small plate)has problem.
Dec 06, 2010 | Heating & Cooling
Cant get sound in dvd mode only in radio mode
PS: Check if you car has remote wire or anterna wire.
Details below.
A relatively common problem is installing an amplifier with a factory head unit or other head unit without a remote turn on wire (or a burned out circuit). So the amplifier doesn't stay on 24 hours a day you need a way to turn it on and off remotely. Hence the term "remote turn on wire". Almost every aftermarket head unit has a remote turn on wire. Some manufacturers call it a power antenna wire. But regardless of the label all it does is output a positive 12 volts when the head unit is turned on. It should be noted that some head units have both a remote turn on wire and a power antenna wire. It's important to use the right wire for your amplifier and other electronic equipment. In the case of both remote and antenna wires the power antenna wire will only output 12 volts when the radio is on. If you were to connect your amplifier's remote terminal to the power antenna wire then you would only get output from the amplifier with the radio. When you switch to CD the amplifier would not work because the head unit turns off the power antenna wire when the radio is section is not active.
There are several ways to get your amplifier to turn on and off remotely even if your head unit does not have a remote turn on wire. The cheap and easy way is to run the amplifier's remote terminal off of a switched accessory wire. This is the wire that your head unit uses. It is only powered when the key is in the accessory or run position of the ignition switch. When you shut the car off the wire loses power and the head unit and amplifier will both turn off. Your amp will be on when your car is on and off when you car is off. If you don't want the amplifier to always be on when the car is on you could wire a simple switch inline with this new remote wire. Normally you would leave it on so that it turns on when the head unit is on. But if you wanted to turn the amplifier off you could flip the switch to off which would stop the flow of 12 volts to the amplifier's remote turn on terminal.
Baadaye Mo
Oct 26, 2010 | Clarion VZ709 Car DVD Player
I have a Samsung HT-z510 home audio and the wireless receiver for the back speakers stays in standby mode. I have set the mode to cinema but it still stays in standby. What can I check next?
Here is how I reset. Key terms to identify: Main unit, remote unit, transmission card, reset button on remote unit. 1. Unplug both units and remove transmission card from rear of Main unit. 2. Wait five minutes. Insert transmission card in rear of Main. 3. Turn on both units. If units do not communicate, there will be a solid red indicator on remote unit...In this case continue with 4. Use remote and turn off main. 5. Point remote at main and enter the following four digits, holding each down for about a second:  0   1   3   5 6. The main unit should turn on. 7. With remote unit on, press and hold down the reset button for 5 seconds.
Nov 29, 2008 | Audio Players & Recorders
Turns on 1 out of 4 times?
The problem might not be with the amp. You will need to check the "remote" output from your head unit at the amp end using a voltmeter. It should be ~12.5 volts dc when the head unit is turned on. If there is no voltage when the head unit is turned on, then the problem is not the amp. The head unit may be bad or there may be an intermitant short somewhere in the remote wire.
You can test the amp by removing the remote wire and connecting the remote input directly to the +12v terminal. Use a short scrap of wire. This will (should) manually turn on the amp. Don't forget to return the remote wire to the remote input or the amp will never turn off.
A friend of mine had his remote wire shorted to ground once after he replaced his head unit. Turns out when he slid the new one into the dash opening he pinched the remote wire against the chassis. Frustrating but an easy fix.
Sep 03, 2008 | Kicker 06ZX750.1 Car Audio Amplifier
Ceiling fan and lights with remote control
I got a new reciver installed in ceiling fixture,works fine:Boytin
Mar 15, 2008 | Hunter 52" Ceiling Fan With Light And...
On/off button flashes green, unit will not turn on manually or with remote
PRESS THE TV BUTTON OF YOUR REMOTE CONTROL FOR FIVE SECONDS AND YOUR TV WILL TURN ON.
Sep 25, 2006 | RCA T19064 19 in. Combo
RCA RT2280 System Logo
59 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
