Slo blo fuse for Hafler DH100 preamp
Hi
I'm in Australia and need to source a replacement fuse.  F1 Fuse, 1/16A slo blo SF019
Nobody over here now's what I'm talking about
  • 1,512 Answers
Hi sheffster
Hehehe I am a Brizvegas , but I know what you are on about.. . Hard to find such a low value of fuse, if you mean a 1/16amp device You can get an 80ma from Farnell Electronics. in Australia by mail order.
What markings are on the fuse itself?
How long is it? 3/4 inch or 1 1/4 inch
It just seems a very low value, particularly for a sloblo. Good luck, hope you get the old girl fired up again :)
regards
Graeme
Posted on Apr 09, 2008
I need to find a fuse for my jbl sub 160 subwoofer.
Those are pretty common. I'd pull the old one just to make sure the new one looks like it and be SURE the new one is a "Type T" or Slo-Blo.
Google "30mm 3.15A 250v slo blo fuse" and you will find them at Mouser, DigiKey, even Amazon. Better still--if you have a local electronic parts store, go there.
Sep 28, 2015 | JBL Audio Players & Recorders
Whirlpool Microwave MH6700xW-0 Blows internal fuses regulary
Assuming your power line voltage is okay, it would not surprise me that after 27 years, your high voltage capacitor is drying out and increasing its capacitance. This will cause variance in the high voltage output, which can stress the magnetron and increase current consumption.
You can order Whirlpool parts my model number here.
http://tinyurl.com/gv383
For more free DIY and other help & advice, feel free to contact me via my site.
William E. Miller, AS-EET
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Mar 16, 2017 | Whirlpool Microwave Ovens
The small ceramic fuse inside the monitor has blown. Where can I geta replacement, and what is its value. It is difficukt to read whether it is 3.15amp or 15am?
wvc12, You will need to look with magnifing glass. could be ".315a or 3.15a" Check with Newark for proper rating( fast-blo or slo-blo) . LittleFuse makes both types. Will also need to know first 2 or 3 letters in front of amperage. Also check "DIGIKEY.com" You will also need to determine if fuse blew from "old age" and just got "tired" or did it blow because some other active (solid state) or passive device has failed!!! Good luck with this one. 12fixlouie
Oct 18, 2010 | LG Flatron L1800P 18.1" LCD Monitor
How do I know If the fuse that needs replaced is a "slow blow" or "fast acting" fuse?
Look at the stampin on the fuse, if it has TXXA 250V, then it is a slow blow fuse type (T = Time dealy), some may be stamped with SLO-BLO XXA 250V on it.
Post pictures if you are not sure.
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Sep 24, 2010 | Philips Televison & Video
The lights do not go on at all, it does not turn on
It may be the power supply fuse. The fuse is a "2amp Type T or slo-blo 250v" if you live in north america. If your electrical current is 230v like in europe the fuse you need is "1.25amp Type T or slo blo 250v". You will need to unplug the unit from the wall outlet, unplug all cables, and set the unit on a padded surface. Remove the 10 screws holding the amplifier to the sub box and remove the amp assembly from the box. At the bottom of the circuit board is a glass fuse, gently remove that fuse and inspect it for obvious signs, like dark burn spots. If you can, check it for continuity, or just replace it. Also before going through this check the outlet that the sub is plugged into for power.
May 16, 2010 | JBL PB10 Subwoofer
What makes a fuse blow after being on for about 15 seconds
Hi Bill,
Either a short or too small a fuse.
Many fuses are what they call, 'Slo-Blo'. they are designed to take high current for a few seconds before blowing. This prevents normal power surges from blowing the fuses.
If this is happing every time you replace the fuse, something is wrong internally that requires attention.
Remember, the fuse blows to protect the equipment. The next step is to find out what is making the fuse blow.
If it's under warranty, don't open it up. just exchange it.
As for the reason it's blowing, you would need to post all the symptoms.
Best regards
Mike
Dec 26, 2009 | JVC KD-LX30 CD Player
NAD C270 amp won't switch from red power/protection to green.
The AH may denote "slo-blo" style as opposed to Fast-acting
A fast-acting fuse will look like a single strand of wire ( maybe wiggly looking) ..A Slo-blo will have an element in it and a spring
Apr 11, 2009 | NAD C270 2-Channel Amplifier
I an RCA TV Modle# 20F512T the fuse keeps blowing . maybe I'm puting in the worng fuse . What is the right size fuse amp and volt.
You might look at this FixYa link:
http://www.fixya.com/support/t244483-tv_will_not_power
Do you still have the original fuse? There is numbering on there that shows the specifications. You probably need a slo-blo type fuse, 3A or so, but I can't be sure on that.
Jan 23, 2009 | RCA 20F512T 20" TV
Denon PMA 520 fuse blown
Check that you are replacing the fuse with the correct type first. Fuses marked with a T following the rating are "slo blo" fuses and if a fast blow is used instead, it will fail again at turn on. Otherwise, the amp will have a fault occurring, probably in the output stages. You should refer this type of fault to a repair guy that knows HiFi. as this sort of repair needs an experienced touch.
Jan 05, 2008 | Audio Players & Recorders
109 people viewed this question
 Grubhead
Grubhead
