Ilo sdtv picture comes on then picture goes to horizontal line in the middle of the screen. it would come back to a full picture but would notice a light green color on the lift and a light red color on the right. now when I turn it on I just get the horizontal line.
  • 12,061 Answers
Your Horizontal Amplifier has gone faulty. So, it is nearly always my professional opinion that one should always get a "Quote" from the manufacturers recommended service center, Ilo, in your case, please contact a local or head office and ask for a referral to an Authorised service center. I cannot stress how important that last point is. It is even worth the cost of shipping. You see an authorised service agent, will have trained staff, trained on their brand, also they have first hand access to parts, original parts. This will actually save you money and ensure you can actually get it back fixed. Of course asking for a "Quote" also gives on the option of repair or replace. Often my clients,do not go through with repair, unless it is moderate, but in some of the more costly jobs they see it, as do i, that a replacement, with a warranty, is a better option. As an aside here, one could then tear the TV down, and sell the Known Good bits. You'd be surprised who needs parts, i myself often must by from third party sources to effect a repair. So money could be recouped, somewhat,and help out someone else.
Posted on May 29, 2010
A thin white line horizontally in middle of screen At first could wiggle the cable conection on back of tv and it would go back to full screen now it won't
it sounds like you have horizontal colapse a very complect repair try hitting the tv if the screen comes up full picture then its a dry joint if not there is an ic or power fault toss it
Jun 18, 2010 | Sanyo DS25390 TV
My ilo tv picture is 1 1/2 inches. How can I fix this??
its a vertical problem could be bad cap or possible vertical i.c. okay take to tv shop is their still a warrany on this set sounds pretty new shad
May 14, 2009 | iLO IWT3206 TV
Horizontal Line through middle of TV screen
This is usually a bad elect capasitor or a bad solder connection on the vertical IC, The capasitors will be close to the vert chip..Sometimes you can clear problem with a light tap on the TV, if so then suspect bad solder.
Charlie
Mar 31, 2009 | Televison & Video
That sounds like simple ring-cracks in the vertical circuit, most likely the vertical Ic itself... On the printed circuit side of the Tv look at the vertical Ic and examine it carefully under some magnification where each pin of the Ic solders to the board. See if you can find any cracks in those solder connections.
Bill
Feb 04, 2009 | iLO V27DMBX Television
Picture on RCA TV shrinks to a horizontal line
Sounds to me you have a cold solder joint ( loose solder connection ) on the printer circuit board around or on the vertical chip or on one of the vertical capacitors. You may also have a bad vertical chip or a bad vertical capacitor, but I doubt it since it did come and go. I'de get a soldering iron and some solder and touch up the connections. I will remind you that you need to always excersise saftey by making sure, before removing the back, unplug the TV from the wall, and use care not to come in contact with the large red wire going to the back of the picture tube as the picture tube can be turned off and still store lots of voltage ( up to 35,000 volts). Always stay safe and when soldering, use care not to run solder across places that will make a short.
Good Luck and I hope this helps
Ed Meshechek ( Radio Man )
NC Electronics
Mills, Wyoming
307-266-4675
Dec 19, 2008 | Televison & Video
Picture reduced to 1/4 on a black screen
Picture is reduced to a straight horizontal line across the center of the screen.
Aug 17, 2008 | Televison & Video
Horizontal blue line
The intermittent horizontal line is cause by a loose solder connection in the vertical amplifier IC.
The IC is mounted on a heatsink nearby or around the flyback transformer.
The way to fix this failure is to add fresh solder where you see some brown spots on the circuitry that were cause by components getting hot.
Good Luck.
Jun 20, 2008 | Sharp 25R-S100 25" TV
Picture goes dead after 5-10 minutes
You may have a loose solder joint causing this problem. If you can take it apart, you mihgt try spraying circuit cooler in various parts of the circuit but NOT in the high voltage or horizontal circuits.YOU MAY CAUSE AN ARC OR A COMPONENT TO SHORT SINCE THE SET HAS TO BE IN OPERATION WHEN YOU SPRAY. If you hit the bad connection the picture will come back on. When the picture zaps to the middle of the screen, is there just a bright line? If so, then you have a loose connection or a temperature problem in the vertical circuit. Stargazer
Mar 03, 2007 | RCA 27F530T 27" TV
Televison & Video Logo
59 people viewed this question
Top Televison & Video Experts
