Question about ASUS Computers & Internet
What would would be the Max Memory Specs on an Asus PSG01 VM motherbord
enuro12
  • 116 Answers
SOURCE: lan card driver
Click Here for Asus P5RD1-vm lan driver
Posted on Oct 11, 2007
SOURCE: ASUS P5B-VM DO Motherboard
Please update your BIOS if necessary to do some fixes, optimization, and even hardware or software support.
Posted on May 29, 2008
SOURCE: hi sair mere pas asus a8v-vm se motherbord ka adio
please
Posted on Apr 24, 2009
  • 497 Answers
SOURCE: ram supported by asus motherbord p5p800-vm<green>
Your Motherboard supports DDR SDRAM RAM only and you can install upto 4GB RAM in the Computer.
You can not use a DDR2 or DDR3 RAM in your motherboard.
Check this Link for more information:
http://www.superwarehouse.com/Asus_P5P800-VM_micro_ATX_Mainboard/P5P800-VM/ps/1483860
Good Luck!!!!!!!!!!!!!!!!
Posted on Sep 18, 2009
map9966
  • 2351 Answers
SOURCE: problem with my Asus p5pe-vm motherbord.When i
If your over clocking your CPU settings reset to default. See if you still get the error. If you still get the error than update your bios. There are a couple of way to do this. You can use the software on your Asus CD or you can down load the latest BIOS-Utilities, Afudos BIOS update tool V2.36. Than download the bios file, P5PE-VM BIOS 1501.
http://www.asus.com/product.aspx?P_ID=k3h0ZFVu9Lo1dUvk&content=download
Using built-in EZ Flash to flash BIOS Please be informed that not all motherboards support EZ Flash,
please use DOS flash utility to update BIOS if your motherboard does not support EZ Flash; http://support.asus.com/technicaldocuments/technicaldocuments.aspx?no=960&SLanguage=en-us
Happy holidays!
Mike
Posted on Dec 19, 2009
Compatible memory at 2gb capacity and video card for asus p5pe-vm motherboard
Hi, you can download a manual here at asus:
http://www.asus.com/Motherboards/Intel_Socket_775/P5PEVM/#download
Dual Channel Memory Architecture
2 x 184-pin DIMM Sockets support max. 2GB DDR400/333/266 non-ECC, unbuffered DDR RAM memory
1 x AGP 8X slot.
Hope this will help you.
Aug 14, 2011 | ASUS P5PE-VM Motherboard
Will the ASUS A8V-VM Motherboard Handle DDR2 memory & AMD 64 x2 4000 cpu?
It will not support a DDR2 memory but it will support AMD 64 x2 4000 CPU see specs below..btw your usin socket 939
Memory Supported:
2 x DIMM, Max. 2 GB, DDR 400/333/266 ECC,Non-ECC,Un-buffered Memory, Dual Channel memory architecture
Socket 939 Supported processors :
Sempron / Sempron 64 (1.8 GHz - 2 GHz, or 3000+ - 3500+)
Athlon 64 (1.8 GHz - 2.4 GHz, or 3000+ - 4000+)
Athlon 64 X2 (2 GHz - 2.4 GHz, or 3800+ - 4800+)
Athlon 64 FX (FX-53 - FX-60)
Opteron (1.8 GHz - 3 GHz, or model 144 - model 156)
Dual-Core Opteron (1.8 GHz - 2.6 GHz, or model 165 - model 185)
Jun 29, 2010 | ASUS A8V-VM Motherboard
Asus motherboard( A7N266-VM)
FOr reset motherbord settings to defaults you can reset with 2 methods.
(1)Pull cmos cell from motherbord for 10 minutes so all settings defaults.
(2) Find jumper on motherbord named "Clear cmos" It has 1-2-3 pins.Put jumper in 2-3 position and thne power up then again put pin in 1-2 position thne all settings defaults.
Refix RAM memory.Clean dust from all parts.
Open processor and processor fan.
Remove pci cards from motherbord then check.
Make sure motherbord not ground with cabinet.
Let me know if you need further assistance.
Nov 11, 2009 | ASUS A7N266-VM Motherboard
Ram supported by asus motherbord p5p800-vm<green>
Memory should be same as the one that is in the motherboard . Each motherboard support only one type of memory. Search on the internet for the type of motherboard for memory supported with it. If it says other than DDR2/ DDR3 then the motherboard wouldn't support the memory. Do some searching like motherboaed p5p800 and see few websites for specification for the motherboard, check the memory specifically for the details.
Sep 18, 2009 | ASUS P5P800-VM Motherboard
Memory problem
The ASUS web site shows only two ram slots on the motherboard. Sounds as if the booklet has a misprint. Specifications on the web site list memory as: Dual Channel Memory Architecture
2 x 184-pin DIMM Sockets support max. 2GB DDR400/333/266 non-ECC, unbuffered DDR SDRAM memory. So, 2GB is max.
Jun 10, 2009 | ASUS P5PE-VM Motherboard
Vista memory test stuck in loop
hello..the vista is recommended memory is 1gig and hard drive is 40gig..so if your specs is lower..win vista cannot run properly..
May 11, 2009 | ASUS P5PE-VM Motherboard
Compatiblity issue..
You may install up to 4GB of DDR RAM in this motherboard. It does not use DDR2.
This is from your manual:
Dual-channel DDR400 memory support
Employing the Double Data Rate (DDR) memory technology, the motherboard supports up to 4GB of system memory using DDR400/333/266 DIMMs.
If you would care for the manual, here is a link:
Asus P5P800-VM Manual
Thanks for using Fixya.
Apr 03, 2009 | ASUS P5P800-VM Motherboard
Replacing Asus CUV4x Motherboard with Asus p5vd2-vm-se motherboard? I have my old computer that i want to replace with new set of motherboard. My old computer has the following specification: Asus CUV4x...
Hi eibral2345, sorry but there is no chance the motherboard, Asus P5VD2-VM-SE will run the Samsung memory. It’s the old style 3.3V PC133/100 SDRAM. The new Asus motherboard,
P5VD2-VM-SE uses Single-Channel DDR2 - 667MNz or 533MHz memory. Here is a link to the specs of the Asus CUV4X: http://www.pcstats.com/articleview.cfm?articleid=314&page=3
Here are the specs for the Asus P5VD2-VM-SE MB: http://www.asus.com/products.aspx?modelmenu=2&model=1787&l1=3&l2=11&l3=369&l4=0
Will the new Asus board fit in your case? It should!
The larger measurement is the height of the board.
The Height + Width of the new board is smaller than the older board.
Have more questions?
Good luck eibral2345!
Mike
Sep 26, 2008 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
Lan card driver
Oct 11, 2007 | ASUS P5RD1-VM Motherboard
Computers & Internet Logo
539 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
