Wife was doing laundry and said the water wouldnt drain and she got error code e20, but i cant find anything online about it.
please help!
thanks,
mike barton
Hello mike means the coin trap is clogged. Here are the steps to fix the problem.
1. Unplug the unit.
2. Remove the bottom front access panel. There are two screws one on right and one on the left towards the bottom of the front panel.
3. Now that the panel is removed look inside on the bottom right hand side there is a black looking accordion thing. This is the coin trap.
4. Clean the drum out with as much water as possible and have towels ready. The next step you will have the remaining water come out.
5. At the top of the coin trap where it is attached to the drum is a silver spring with a silver screw. Loosen the screw and wiggle the coin trap down from the drum.
5. Reach inside the coin trap and clean what is inside of it out.
6. Put the unit back together following the same steps backwards
regards
shaun
Hello John, thanks for your inquiry!
From my understanding your Frigidaire front load washer is displaying an error code of "E20" and you would like to know how to fix it. An "E20" code stands for water is not pumping out fast enough this could be a problem with your drain hose, pump, or control panel. I would suggest checking the drain line to make sure it is not restricted. If the line looks clear it could be a problem with your drain pump or control panel. I would recommend seeking assistance from a professional technician for proper repairs. I hope this information is helpful. -Matt
Hello - Error code "E20" typically indicates that the water is not draining properly or not pumping out fast enough. Is the washer making a humming noise? If so, either the drain hose may be kinked or the household drain is clogged. Otherwise the unit can be experiencing more serious issues, like a faulty pump or Main Control Board. If I was in your position, I will personally consult a certified technician for a proper diagnosis and to move forward accurately.
