Question about Singer CE-200 Quantum Futura Computerized Sewing Machine
The feed dogs will not raise. There is no movement, at all, when I move the switch back & forth.
  • pmnovak2 May 29, 2010
    Yes, once I filtered through all the web sites --- but, I couldn't have fixed it without "Silverdragon's" help.
  • 12,061 Answers
Http://safemanuals.com/user-guide-instructions-owner-manual/SINGER/FUTURA%20CE-200-_S
sewandserge.com/tshoot.asp
www.singerco.com/support/faqs.html
parts.singerco.com/IPinstManuals/66.pdf
OK above is a manual, above that is a support FAQ, above that is a direct answer for your "Dogs" and above that is your user manual. If you need more info, please use below Google search link, below.
http://www.google.co.nz/search?num=100&hl=en&q=Singer+sewing+machine+The+feed+dogs+will+not+raise%3F&aq=f&aqi=&aql=&oq=&gs_rfai=
Posted on May 29, 2010
    None of these "solutions" raise the feed dogs. Any other suggestion?
    thank you, your websites helped ---- all is ok now.
Hi, Janome 124 - top thread picks up the bobbin thread, motor sounds good. Th feed dogs won't pull fabric (or paper) thru the machine - dogs don't stick up much above the plate. Help please! Jan
Remove the needle plate and clean the feed dogs with a brush...remove any lint and bits of thread.
A couple of drops of sewing machine oil might help to loosen the feed dogs up. (maybe let the oil seep in and then turn the handwheel towards yourself to help things along.
One other thought:
If your machine has feed dog lowering capability you might want to move that lever/switch back and forth a couple of times.
The feed dogs might not appear to raise or lower, but some machines will only re-engage raised feed dogs when the machine starts to stitch.
Also...verify that the presser foot tension isn't too strong/heavy...and temporarily try using a longer stitch length setting.
Mar 19, 2017 | Janome Sewing Machines
Raise and lower the feed dogs
the feed dogs are the saw toothed piece under the press foot
they go down move forward raise up move back in time with the needle to pull the material through for the next stitch
the amount of movement ( stitch length) is set by the position of the forward and reverse lever/ knob
Dec 10, 2015 | Sewing Machines
Does this model have a feed dog that can be lowered for free motion quilting?
    A set of feed dogs typically resembles two or three short, thin metal bars, crosscut with diagonal teeth, which move back and forth in slots in a sewing machine's needle plate. Their purpose is to pull ("feed") the fabric through themachine, in discrete steps, in-between stitches.
    Feed dogs - Wikipedia, the free encyclopedia
    https://en.wikipedia.org/wiki/Feed_dogs Wikipedia
Oct 25, 2015 | Sewing Machines
Bar that sewng foot is attached to for raising & lowering suddenly will not drop sweing foot all the way down to plate. Any suggestions on how to fix?
Perhaps you accidently moved the switch that enables free hand embroidery? It's up and under next to the pressor foot lever. Slides forward and backward. Forward the pressor foot will go all the way down to the feed dogs. Slid back and it keeps the foot up off the feed dogs but allows the thread tension to work properly. It would be easy to accidently move it when operating the pressor foot raise/lower lever.
Aug 31, 2014 | PfaFF Sewing Machines
Pfaff expressions 3 feed dogs will not raise when switch is moved right
If the switch feel very easy to move then the linkage to the feed dogs is off somewhere. The machine will need to be opened and checked where and what.
Jan 13, 2013 | Sewing Machines
Hand wheel not moving
Check bobbin area. Clean feed dogs with brush to remove lint balls & any loose threads. Use gentle back and forth motion on hand wheel to see if you can loosen debris. Be VERY gentle so you don't interfere with timing. Usually you will bring up one thread caught in feed dogs and you can sweep it out. If that's case here, I recommend inserting new needle, flat side back and make sure you raise presser foot before rethreading to open tension discs. Good luck. Jimmy
Apr 04, 2012 | Husqvarna Husky 165
The teeth do not pull fabric thru, the teeth move only back/ forth. Is there an adjustment or part to replace, Jesse thanks.
I have limited knowledge but could the feed dogs be in the lower position? If so there should be a lever or slide button to raise them.
Nov 29, 2011 | Brother Sewing Machines
We have a Kenmore sewing machine Mocel 385.1764180 and the material will not move while sewing a straight stitch. My wife says it did this a couple of days ago and corrected itself by moving a couple of...
on my machine, as janome, there is a feed dog lever behind the bobbin are, and a pressure foot adjust on the top of the machine. But idf you have touched those perhaps something is catch in them and thats why it keeps happening ??
Jan 10, 2010 | Sewing Machines
Feed dog
don't know how i did it but it is working now. thanks anyway.
Apr 01, 2008 | Singer 7430 Sewing Machine
Feed dogs
I was having trouble with this too, but found more help online...you have to switch the dog feed back to 'up'....then turn the needle wheel toward you....the feed dog should snap back into place :)
Hope this helps :D
Mar 18, 2008 | Sewing Machines
Singer CE-200 Quantum Futura Computerized Sewing Machine Logo
70 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
