Question about GE WDSR2080D Top Load Washer
Final rinse cycle never engages - GE WDSR2080D Top Load Washer
  • 166 Answers
Does all the water drain out? will the machine spin on any cycle? does the timer advance to off?
if the lid switch fails to activate then it would not let your machine spin on any cycle.
you should also check to see if cold water is coming into the machine. most machines rinse on cold water and if the water valve for the cold side fails - this could also be a cause.
Posted on May 29, 2010
Spin not working on final cycle
no rinse at all or just at second final cycle? if so its either bad clutch, tranny, motor coupler, belt broken, or even door switch out? depending on either a belt or direct drive motor
Dec 19, 2014 | Washing Machines
Why won't my washer start a cycle? Start button LED just flashes. All other lights are steady. Door lock sounds like it engaged, but nothing happens.
There should be a way to enter the washing machine into service mode to view an error code. Check your user manual and then you should have your answer!
Jul 23, 2014 | Washing Machines
After rinse cycle won't washer won't spin
Sound like it could be a lid safety switch.
May 24, 2014 | Kenmore 22422 Top Load Washer
Hobart SR24H dishwasher after rinse cycle the same time pampas water in and out of the dishwasher, two pipes are opened and working
Hello.
As per my personal opinion this is normal because for the final rinse you have a small booster or boiler..
When you turn on the machine..it starts fill and also the booster for the final rinse.
You start the machine..wash cycle...rinse cycle..
Now..new water(from rinse booster) is coming on the tank in order to rinse the dishes..on the same time the machine drains the excces water from the rinse(over flowing) and fills up the booster with new water.
Should be like this
Good luck
Jun 29, 2013 | Dishwashers
Please describe a typical washing cycle to me on the RTW4440XQ Roper 3.1 Cu. Ft. Top-Load Washer, please.
The typical cycle is;
fills to selected water level
agitates wash cycle
drains wash water
spins wash cycle
fills to selected water level on rinse cycle
agitates on rinse cycle
drains rinse water
spins final time
end of cycle
Aug 08, 2011 | Roper Washing Machines
The cycle stops at final rinse and water is left in the drum.............until I cycle the knob and depress to activate.
tighten the hinge screws on the top left of the lid. If that doesn't get it started hit the top to engage the lid switch which is hooked into the left hinge on a whirlpool. if its a maytag, its in the center of the rear lid and you must remove the consoles rear to access the lid switch
May 03, 2010 | Maytag MAV7580E Top Load Washer
Fine particles of food/grit left at end of cycle
Open the door and check it with a level. If the dishwasher isn't perfectly level, turn its feet (behind cover at floor) until it is level. If the jet bars can be removed, take them off and rinse them out. Make sure they're engaging with the pump outlet properly. There may be a plastic bushing that the main wash arms rotate on. If this is worn, replace it. It will make a world of difference. Finally, make sure you're using enough detergent. I suggest the cheap powdered type. It seems to have the best cleaning ability. Finally, make sure the rinse aid dispenser is set to dispense enough.
Jan 28, 2009 | Maytag 24 in. MDB5600A Jetclean II...
GE Nautilus won't drain after Rinse Cycle
Check disposer plug. If a garbage disposer has been recently installed, it is possible the disposer drain plug was not removed. The drain plug is a plastic piece in the disposer that blocks the hole where the dishwasher hose connects. Also check the hose connected to the disposal. Mine apparently had a kink in it. When I straightened the hose the dishwasher drained at full speed (I recently had a plumber re-route a hot waterline. He must has bent the hose). Hope this helps. If not go to the GE website. That's where I found my answer.
Nov 03, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
Top load washer
I am having this same issue, has anyone found the solution to this issue?
Oct 14, 2007 | Maytag PAV3240A Top Load Washer
GE WDSR2080D Top Load Washer Logo
76 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
