Question about Dryers
MDG6200 dryer doesn't dry and clothes aren't warm after cycle. I took off front cover and observed that flame comes on, but then cuts out a minute or two after starting. Airflow/venting not problem, since I disconnected vent and felt solid air flow.
    President:
  • 1,554 Answers
The gas valve is shutting off too soon due to a weak solenoid coil that shuts off when it gets hot. Replace the solenoid coils to address the problem. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
Unplug the wiring harnesses from the solenoid coils then remove the two screws securing the coils holding bracket. Remove the bracket and lift the solenoid coils off then replace it in reverse of the removal steps.
Posted on May 29, 2010
Whirlpool duet gas dryer
The question is are your clothes getting dry? The flame does not stay on constantly, but cycles on and off. Now if the clothes aren't drying properly, then the first thing to check is if you have good air flow coming out of the back of the machine and air flow completely outside where the vent exhaust to. If that is good then most likely your flame sensor has gone bad and needs to be replaced.
Aug 25, 2012 | Whirlpool GEW9250 Electric Dryer
My amana gas dryer seems to be taking longer then normal to dry clothes. I've always used the moisture sensor and one day I noticed it had been running for 10 hours (although the clothes were dry and...
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
May 21, 2011 | Dryers
Dryer doesn't dry (flame cuts out)
279834 is the part number for the 2 coils ( kit ) which mount on the burner . Only 2 screws hold the coil retainer . One coil is opening ( shorting ) after it gets warm . Replaceing both will solve the problem . Easily replaceable .
May 29, 2010 | Maytag Neptune MDG5500AW Gas Dryer
My dryer takes hours to dry one load of clothes. Cleaned all lint from it. It's warm, not hot. Flame is on.
you need to either dismantle the venting pipe ductwork inside the dryer and get inside the duct and loosen all dried on lint which is holding moisture in,otherwise the cycling switch for the flame is cutting out tooooo sooooon and your not drying the load properly per selected load setting
Mar 14, 2010 | Maytag Neptune MDG9700A Gas Dryer
The heat (gas flame) goes out after dryer has been running for about 10 minutes and drum keeps turning but clothes never get dryed. Model is mdg6200
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
This could also be caused by a bad set of coils as well. the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
**The most common problem spot here will be a defective set of gas valve coils.
Jul 08, 2009 | Maytag Performa PAV2200
Dryer does not dry clothes. Flame does not stay on
run dryer for 10 minutes then remove vent hose see if start working mean flame on for while, if it is then you need to clean your vent system.
May 01, 2017 | Maytag Atlantis MDG7400AW Gas Dryer
Dryer gets warm at first but then cools down
Check the hi limit thermostat and the cycle thermostat. They may be opening too soon.
Remove the connecting vent on the rear of the dryer exhaust and see if it cycles normally.
The flame sensor may be malfunctioning.
If the gas valve coils are good, these are the only other possibilities.
Mar 28, 2009 | Whirlpool LGQ8000JQ Gas Dryer
Flame only stays on for five minuts. After start
the flame doesn't stay on the whole drying time, it cycles.The thermal fuse allows machine to work and heat up but the cycling thermostat directs the flame to come on and shut off. Do your clothes dry fine?
Mar 04, 2009 | Kenmore 60172 Electric Commercial Dryer
Roper dryer res7745pq is taking 2 cycles to dry and vent is clean?
check if the thermostats in rear part of dryer are covered with lint. take power off to dryer and remove back panel you will see 2 or 3 thermostats if there is a lot of lint around them carefully remove lint. if that doesn't solve problem make sure clothes are coming out of washer spun dry enough .. check lint screen on dryer. is the vent clear all the way outside ?, in winter little critters like to set up housekeeping in vents where the temperature warms them up. you can also check if heat is cycling open door to dryer and press the door button, start dryer and observe heater , it will come on then shut down and it should come back on in a minute or two, if it doesn't come back on the cycling thermostat may be at fault
Jan 26, 2009 | Dryers
Maytag Atlantis Gas Dryer
I would sstart by replaceing the gas valve coils they are located on the top of the gas vavle . they will weaken over time and will not stay energized to open the primary and secondary vavle
Jun 14, 2008 | Maytag Atlantis MDG6400AW Gas Dryer
Dryers Logo
Top Dryers Experts
