Question about D-Link DIR-625 (790069292637) Wireless Router
Hi there...wherever you are...i cant get my d link 625 to work..my 2 wire modem failed so i put back in my old action tec and the router wont work..plus it keeps asking me for a password and i dont remember putting one in..i hit reset adn that didnt work either...if i put the cable directly in the computer i have internet..but when i put it in the router..no internet..thank you for your help
    President:
  • 1,768 Answers
The default password is left empty
the user name is "Admin" then press enter
If you have entered a password follow these instructions:
The following reset procedure will completely restore the default settings on your device, including your password.
Step 1: Locate the reset pinhole on the back of the unit.
Step 2: With the unit powered on, press and hold the Reset button.
Step 3: Hold the Reset button for about 10 seconds.
Step 4: Release the Reset button.
Step 5: The unit will reboot. Allow 20-30 seconds before reconnecting.
Step 6: The device is now at factory defaults.
Note: Do not recycle power during the reset procedure.
The default user name for the router is admin and the password is left blank.
go here for further support for you version ( router)
Posted on May 29, 2010
My router stopped giving wi-fi to my computer. What can i do?
you can try reseting your wireless network.
It is a soft reset so you will not loose your configuration.
Unplug power on your modem and on your router.
Wait 20 seconds then put power back to the MODEM FIRST.
Wait 30 seconds and then plug power back in your router. Wait 20 seconds again and try your connection.
If not, try restarting your computer after doing the steps.
Hope this helps!
Feb 21, 2011 | D-Link DIR-625 (790069292637) Wireless...
Con't connect to internet through d-link dir 625 router
  1. Reset the router and your modem.
  2. unplug the router's power
  3. unplug the modem's power
  4. wait 15 seconds
  5. plug in the modem
  6. wait until you have several lights and not too much blinking
  7. plug back in the router.
Try logging going to website. Give it a couple of tries (refreshes). Sometimes it takes the router time for the first attempt.
Report how that goes.
May 24, 2010 | D-Link DIR-625 (790069292637) Wireless...
I have excellent signal strenght but wont allow
try to restart it with a pin, if that doesnt work log into your systems ip address and address the issue there
Mar 01, 2010 | D-Link DIR-625 (790069292637) Wireless...
My wireless hp says router cannot find host name
Double check your physical connection. It should be this way
Modem > connected to Internet Port of the router
PC > connected to port 1
Laptop > can be wireless
Now you must power cycle your router and modem. Turn off router first then modem. Wait for 30 seconds. Power on modem first, then the router. You must configure the wireless settings on your laptop it doesn't connect automatically.
Jun 14, 2009 | D-Link DIR-625 (790069292637) Wireless...
I have an issue with my Dlink DIR-625 wireless and cable modem
it isn't syncing up with your modem, try a hard reboot, disconect everything, even the cable, after 5 minutes , first screw the coax cable back to the modem, that will re establish the cable connection, plug everything back in, and if that pc light still is still doesn't work, the router may be bad, look on the Dlink site and download the latest firmware, as a last resort, but also reset the router first before trying anything, there is a reset button on the router. Sometimes certain routers don't work with certain modems, if you try the reset, then the hard reboot, and the firmware, you have covered all the bases
Mar 30, 2009 | D-Link DIR-625 (790069292637) Wireless...
D-link dir-625 still cant acces wirelessly
If your laptop has a wireless capability you should be able to connect to the wireless network of your router, just view the available wireless network select the wireless name of your router and connected to it if it already say connected try to disconnect the ethernet cable from your laptop and access the internet wirelessly..........
Nov 01, 2008 | D-Link DIR-625 (790069292637) Wireless...
Cannot configure D-Link DIR 625 wireless router
Hey Raj - Unplug your modem and router. After 60 seconds plug your modem back in. When the lights return to normal (except the activity light) , plug your router back in. Give it 10 seconds and try it. If this solves your problem PLEASE rate this as fixed. If not, DO NOT RATE YET. Just add a comment letting me know what happened and I'll be happy to assist you further. Thanks.
Jeff
May 31, 2008 | D-Link DIR-625 (790069292637) Wireless...
D-link dir625
When your laptop is working, check the ip address.
Open your DOS PROMPT, type iconfig then click enter. If your ip address on the laptop is 192.168.x.x, that means that you are getting your internet from the router. If your ip address is (just an example:68.x.x.x, that means that the router is not functioning properly.
If the laptop ip is 68.x.x.x(just an example), make sure that your comcast modem is connected to the INTERNET PORT of your router.
You just bought your router so the best way to deal with this problem is call Dlink tech support so they can walk you thru the router configuration.
Good Day
Mar 15, 2008 | D-Link DIR-625 (790069292637) Wireless...
D-Link DIR-625 (790069292637) Wireless Router Logo
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
