Question about Sta Rite STA-RITE IGNITION CONTROL MODULE - 42001-0052S
Sta rite pool heater service red light is on. Spa is not heating
Chec gas and is open...water is runing through the system. We followed the troubleshooting guide but we got stuck on finding a board. the question asked is are any red diagnostic LED's on back of board (ags, AFS,SFS,HLS,PS or thermistor) "on"
    Top Expert:
  • Sta Rite Master
  • 5,062 Answers
Check ignitor
Posted on Oct 11, 2017
  • 128 Answers
SOURCE: sta-rite lp heater wont start
Its the top. There is a membrane that controls the circuit board....the button pad is bad
Posted on Aug 30, 2009
Testimonial: "Thanks, I agree. After checking power supply all the way through to control board, placing a jumper from pins 9/8 and 9/7 on J6 I get lights on LED's"
  • 246 Answers
SOURCE: I have a Sta-rite gas heater that has the afs and
SORRY YOU HEATER IS GONE THE HEAT EXCHANGER HAS ALEAK THIS IS DUE TO POOR WATER CHEMESTRY ,LOW PH, OR SOMEONE USING TABLETS ON THE SKIMMER THIS DAMAGE THE METALS ON THE HEATER
Posted on Oct 13, 2009
  • 246 Answers
SOURCE: sta rite heater won't start
TURN THE BREAKERS OFF FO R 20 SEC IF PROBLEMS PERSIST SEE CODE A POST
Posted on Dec 07, 2009
  • 990 Answers
SOURCE: Sta-rite pool heater shuts down as soon as the
Between the two water pipes on the left side of the manifold is a two inch plug. When you take this plug out the thermal regulator assembly will come with it.It consists of "O" rings, a spring and what looks like a thermostat in a car. This is the probal bad part although it could be the spring also. You can get these parts seperatly or in a kit. If this is an older heater the kit is the way to go so you get all the nessary "O" rings and you will be covered on everything you need.
Posted on Dec 08, 2009
  • 990 Answers
SOURCE: Water Temprature read 126 on heater and will not Fire
This is a problem with your thermister (heat sensor) You will find this on the left side of the water manifold about half way down. I'm not sure but I think it is a small tube that slides into the manifold and if you follow the wires back to the board it just plugs in. The part is reasonable priced for a heater part and very easy to install. Good luck.
Posted on Dec 21, 2009
Water Isnt Getting Hot
Could be that the plumbing got clogged while the system was idle
May 13, 2013 | Sta Rite Pool & Spa
Sta-Rite Max-e-Therm pool heater -- cycling and HLS
make sure that you have adequate water flow going through the heater and that your water chemistry is balanced.
Jan 09, 2010 | Sta Rite Sr333na Max E Therm Pool & Spa...
Oct 09, 2009 | Sta Rite Sta-Rite Max-E-Therm High...
Water Temprature read 126 on heater and will not fire. Pool temp @ 72 degrees. Heater set for spa @ 101 degrees. SR400NA Sta-Rite Heater
Oct 04, 2009 | Sta Rite Sr400na Max E Therm Pool & Spa...
Pool heater
If the heater fails to ignite after three attempts, the heater will automatically go into Lock Out. This is a safety feature on the heater.
Things for you to look at to see what is causing the problem are the display panel and diagnostic lights. When you turn on the heater, is it reading the correct water temp? If not, the Thermister has gone bad and will need to be replaced. When you try to start the heater, is there an Error Code displayed? Which of the Service Lights are coming on when the heater will not light? If it is the Serivce System, that is usually low flow of water. You may have a dirty filter, skimmer or pump basket full of debris, or a valve not completely open.
If the Service System light is the one coming on, then you will need to take off the top two halves of the heater and turn over the Display Panel. There are diagnostic lights on the back side of the panel. There may be a red light next to any of the following:
AGS, AFS, SFS, HLS, PS or THERMISTOR
If there is a red light next to one of these, then that is what has malfunctioned. If you need an Owner's Manual for the heater, you can find one online at the following link:
http://www.inyopools.com/owners_manual/sta-rite_heaters_max-e-therm.pdf
Jul 03, 2009 | Sta Rite STA-RITE IGNITION CONTROL MODULE...
Sta-rite gas heater will not go on.
Part of the ignition system is bad. It is probably the ignitor, if you change it shut main gas supply to unit. Also, shut the power to the heater and turn it back on after repair
Jun 08, 2009 | Sta Rite Sr400na Max E Therm Pool & Spa...
Sta-rite gas heater won't ignite
I am not sure if either of these issues have been solved, but with the AGS light on, you will need to check the flow of water first. If it is below what is needed for the heater, this will light up. If the water flow is fine, then check the water temp on the display panel. If it is readin higher than that of the ACTUAL pool water temp, you need to replace the Thermister.
If the water temp displayed is about that of the pool water, then the Automatic Gas Shutoff will be the next thing to check and replace.
You can tell IF a Sta-Rite heater has been converted by the model number. The Convesion Kit is supposed to come with a sticker stating that the heater has been converted, but there are two options for the kit and the one without the sticker is cheaper.
If you take off the top two halves of the heater, on the Junction Box there should be a Tri-fold card there. Unfold it, if the model number ends with NA it is a Natural Gas Heater, LP would be Propane.
Apr 04, 2009 | Sta Rite Sta-Rite Max-E-Therm High...
Sta Rite STA-RITE IGNITION CONTROL MODULE - 42001-0052S Logo
279 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
john h
steve morris
steve morris
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
